Kingcat rudder twitching
MA
We have a Kingcat that has the right rudder twitching. We changed the extentions that feed the servo, but it still quivers. I plugged another servo into it but it still shakes. What else could it be? I have a JR matchbox on that circuit, could that be it?
Dan
Dan
RE: Kingcat rudder twitching
Dan,
Unplug the rudder servo connector from the matchbox and plug it back in. The twitching should go away. I have the same problem and sometime have to unplug and plug it back into Matchbox to get it to stop. Hope it works.
Mike
Mike
I have had the same problem with my KingCat since it was built last year. I tried everything and finally gave up. A couple of weeks ago, I was just doing routine checks / maintenance and plugged in another extension ( thinking it was the continual problem ) but accidently put in one with a buffer / amp ( from Electrodynamics ) and the rudder servo suddenly went silent!!!!!!!!!!! Perfectly solid ever since.
Dean Wichmann
www.helijet.ca
Dean Wichmann
www.helijet.ca
MO
I had the same problem with the KingCat I just finished building and I cured it with the application of Stabilant 22 on all the servo plugs, extensions and receiver contacts. I use this stuff a lot at work and its magic.
Read about it here:
http://www.stabilant.com/techt02h.htm
When this stuff is applied to the contacts of a electrical plug it provides the conductivity of a soldered joint. There are no doubt many sources but I bought my bottle at the loca Napa store, part # CE1. An eye-dropper sized bottle is about $70 but that same bottle will last through 10 models or more. You only need to apply it once..........then forget it, regardless of how often you unplug the connector.
John F.
Read about it here:
John F.
