The Jacknife-new mega jet out of S.Texas
#54
My Feedback: (60)
RE: The Jacknife-new mega jet out of S.Texas
Sorry to bring up an old thread, but I spent a few days with Jack this past weekend at the B-17 flyin out at Bomber Field and the Jacknife was there in all its glory. Still every bit of the incredible machine I saw three years ago at MAB. Sung, if you see this, I'm jealous, I saw your airplane and it looks OUTSTANDING!
Over a bottle of Jack Daniels my partner and I started writing checks to get three of these, hopefully by the end of the year.
And for those concerned about my Knapp Rolling paint jobs, I kindly asked Jack to paint mine!
Jets in 2009 is going to be INCREDIBLE!
If you are in the market for a 100% Composite airplane in this size range, you might want to look into this airplane. Since this thread, Jack has made wing molds, and his work is quite excellent, I'm not expert when it comes to glass work, but I'm pretty good, and I went through all of his work I could see, and it is impressive for sure! More than half the fuse is 5.7 ounce Carbon Fiber. And only weighs 6 lbs. The last fuse I laid up on the megabar was almost 5 pounds and is not nearly as large, Jack once again has shown me I have a lot to learn!
#56
My Feedback: (7)
TX
yes i will take credit for naming this plane over a patch of margaritias with jack at the austin fly in......after brain storming with jack gulp after gulp of the " ritas " and jack strumming his banjo...boom it came to me......
and what a plane it is too......im amazed at how much authority it has in the air cutting through the sky at full power while still being able to glide for what seems for ever.... just like a bandit....the plane comes in for landing at a very nice slow speed which i never expected as one might expect it to have to come in on the fast side due to it`s size however this is not the case making landing a breeze......tuff plane to with the jmp gear which you gotta love
jack you hit it big on this one.....and cant wait to see more of them on the flight line
gregg bingham
gregg bingham
#58
TX
Hi guys,
Here's new contact "hotline" numbers. 956-650-0602 cell, call anytime before 10:00 pm (2 babys in diapers hopefully sleeping) or 956-357-7868 only after (9:00pm-free minutes then-no limit...everyone knows how long winded we can be.
On another note, Bomber was a BLAST this weekend. A ton of stuff to look at, old friends we haven't seen in years, and made some new ones. A big thanks to Sean and Roger for the hospitality, the kind words, and for coming "on board with team Jacknife". I received a huge warm reception from everyone on the Knife. Speaking of the Seanmeister and the Megabar, you have to look past the paint to see this kids talent with his machine work. Throw him a chunk of titanium or aluminum, tell him what you want, and jump back. Retracts, struts, etc..swiss watch man!! great stuff! Our schedule is the finish of Sung's Jacknife in a nasty finish for his birthday in October. As Sean mentioned, his and Roger's before Christmas. I will building a parts inventory to cut down on turn-arounds on the semi kits. I'm offering to the builders a semi -kit for $3500.00. You order your gear from Tom Cook. This jet will handle the UB bypass and tailpipe from BVM, or use your favorite. A 30lb turbine is all that is required.
Thanks to everyone for the support and kind words,
Jack
Jack
#59
TX
Ooops,
The semi-kit consists of fuse, wing, tail feathers, clear canopy, wing tanks/pylons, 3 fuel cell system(pre-assembled/pressure checked-nearly 2 gallons) inlets installed, inlet coupler. Wing mounting is done, as well as tail. Hinging is robart, gear mounts are set up for Cook's gear.
Jack
All calls welcome for questions
Jack
#61
My Feedback: (60)
Buck, the main formers are glued in while the fuse is still in the mold. I can't remember the exact count, but it was around 3. From the inlets back, the layup was 3 ounce glass to the mold, layer of 6 ounce, and a layer of 5.7 ounce carbon fiber. It was incredibly stiff, yet light weight. There was no puddling of resin anywhere, I looked for problem areas, and there were none. I first saw this airplane around 5 years ago, and Jack has really worked hard on this thing. It was awesome to have him walk me through all issues of development of the airplane we had time to go over. There are even carbon fiber strips supporting the nose of the airplane to the main fuse. I have seen this Jet in person 3 times, and I guess that is what it took. I was getting jealous seeing some Ultra's and the Outlaw jet out there that are a little bit bigger than the Mega, and I had forgot about the jacknife, when I saw it Saturday, I just knew I had to work something out.
It should be quite some time before a bigger jet comes out And this one flies so good!
#62
My Feedback: (21)
thanks for the info amigo. i've got my eye over the horizon "so to speak" always looking for the next jet. Mig29, F4, Mig21, Me262 have always been favorites of mine but a good old fashioned big butt sport jet might scratch the itch also.
i've just got to get a real job that can support my addiction.
cheers
cheers
#63
My Feedback: (12)
FL
That looks sweet!
See Sean...thats the kind of tail the Megabar should have LOL
I bet you already have the Titanium gear in the works for it. That is going to be one nice ride.
Hmmm how about some winglets??
BC
BC
#66
TX
You said the magic word. I always admired the great Tom Dodgen and his winglets. I'm tooling plugs(carving/sanding the heck out) for winglets that will be molded to add to the beast. A balsa ply combo in the molded wing tip,some zona saw action, and save the cut away part as you can finish it out and have a choice of standard wing tip or winglets-plug style with a pair of carbon rods/set screw as BV has proven on various projects. Have some cool scoops and blisters already molded for fuse vents and various effects. It a big jet that allows you a blank carvas for your ideas.
Jack
Jack
