Avonds F15 gear
My Feedback: (7)
Avonds F15 gear
In need of gear for this plane but not sure what size Spring Air retracts and what size Robart struts 3/8" or 1/2"? I will be using BVM T33 wheels. This is being built as a ducted fan with turbine in mind later. Thanks Rick
My Feedback: (9)
Avonds F-15 gear
I'm on my second Avonds F-15. Both models were first flown in ducted fan and now fly in turbine. I used the Robart retracts with BVM T-33 wheels and the combo have worked flawlessly. Robart makes a set of retracts for the Avonds F-15. I am not experienced with the Spring Air F-15 retracts.
AZ
Avonds F15 gear
Jet Hanger Hobby makes a good set of gear for the Avonds F-15. Mine sat around for a few years and when i tried them again sure enough they worked very well. And plus they are scale gear as well.
AZ
Avonds F15 gear
Hey Vin,
Yeah i won a couple of plaques 1 for military and 1 for peoples choice both with the 15. I think i am starting to have fun with the 15 rather than just worry about flying. But i really enjoyed watching you with the 262 and a4. Did you ever fix what was wrong with the 262? Anywho i will talk to you later if not i will see you at the Arizona jet rally
My Feedback: (61)
F-15 gear
Jeff,
I got left with the crumbs!!! You got the 1st place stuff. Anyway it was a good time. The last flight on the 262 was a reall nail biter, when switched over my radio from the A-4 last flight to the ME-262 program I forgot to "center" the rudder which is mixed on two channels. Don`t ask me HOW I did not notice my rudder was full deflected to the right the whole flight!! Now I know how effective the rudder is on that jet. As I was taxing back to the pits I saw the rudder banged all the way over and said sh*t!!! How stupid can I be here!!!
Vin...
Vin...
OK
Re: F-15 gear
Originally posted by Vincent
Jeff,
Vin...
Jeff,
Vin...
I wonder how it would fly on one engine (OK, electric is not well adapted to that test... ). I wonder, cause i have been extremely surprised, reading the monumental study in 4 volumes about the plane, to see that many pilots reported flying 2 or 3 hours, searching a field, then doing go-around, with an engine dead ! I guess those pilots were not bad, but the plane must be damn good to allow that ! When I don't dream about the 3 meters Fouga Magister, I dream about a 3 meters Me 262 !
Bernard
Avonds F15 gear
If you get the weaker Spring Airs, you'll get real good at taking them out, straightening the wire and putting them back in. Once you do it a couple times, you can plan on doing it every other flight or so after that. They're nice and flexible. So flexible, they may even take a chunk out of your gear wells.
My Feedback: (61)
one motor out
Bernard,
This my second AW ME-262. The first was powered with some different motors and fans than I have in this latest one. I had several one engine out situations with the first one. I was able to continue level flight with full opposite rudder and feeding in some ail as well, the good motor was at full power too. I typically shut down the elec motors on final so its not a big deal if you lose a motor and have some altitude.
I have a handfull of ME-262 books but do not remember reading about any one engine "go arounds" the real jet was quite under powered until it was at cruise.
My ME-262 was covered quite a bit in an e-zone thread.
http://www.rcgroups.com/forums/showt...ir+world+me262
Vin...
Vin...
OK
Re: one motor out
Fw Becker flew his firts operational mission in W.Nr.500075, coded "red 7", he shoot down at very close range a P-38, and debrits from the P-38 end-up in his port turbine, that he his able to shut down. "this forced me to shut the engine down again, and I trimmed the figther so that she went into normal single-engined flight."......"Now I was cruising above the clouds with one engine. The flight controls were amazingly intact, but my speed was much reduced"...." At a heading of 270 degres, I went straight into the approach, waiting for ground visibility. Then came my first indication of my proximity with the ground, small wooded areas and, to teh right, a road with trees and telegraph poles. I was very low at this time, the darkness and increasing rain combining to reduce visibility to almost nil. Instinctively, I pushed the throttle of the good turbine forward and pulled up in a left turn. I was in the clouds again, and, at 400 km/h, soon pulled out above the cover. The sun was almost on the horizon at this time, but a few contrails were still visible in the distance"....
he went to land in a field were he had some visibility, after literraly flying on trees top.
I may have to look longer, but I am pretty sure that I saw at least another guy talking about a go around with a Me 262 on single engine flight. I remember it, because I was VERY surprised!
Bernard
