Reload this Page >
Propjet, mig 27 target drone
Old 10-17-2008, 09:09 PM
  #226
huck1199
huck1199's Avatar
Default RE: Propjet, mig 27 target drone
Kyle,
Thanks for the info. I just got one from him but thought it was a little pricey. I was hoping to find a cheaper source for a second one.
Huck
Old 10-17-2008, 09:39 PM
  #227
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
Huck,
You are welcome, i met him when i picked up my 2 planes, nice guy and has literally hundreds of these planes in storage. I would have gotten more but i could barely fit 2 in my 4 door saturn..lol
Kyle
Old 05-01-2009, 12:57 PM
  #228
Yakflyer
Yakflyer's Avatar
Where dide everybody go? I'm just getting started and looking fwd to some lessons learned to borrow from.
Old 05-01-2009, 02:11 PM
  #229
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
Yakflyer,
What questions do you have? Mine still flies great!!
Kyle
Old 05-04-2009, 08:36 AM
  #230
Yakflyer
Yakflyer's Avatar
Thanks!
Well first thing is CG, what have you found to be a good starting point?
Also looking for any construction tips.
Ideas on the installing the landing gear other basic construction tips.
Love to have a manual/directions to learn from. Do you know if there is anything out there?
Also I would like to see a few videos &/or pictures.
Only found two videos on YOUTUBE on this model flying.
I will appreciate any help you can offer.
I am not a beginer, but a novice +. Been building and flying for 5+ years so i have some know how.
Finishing up with my first Air Retract system on a Seagul Dual Ace & looking foward to working on the Drone next.
Old 05-04-2009, 08:25 PM
  #231
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
Yakflyer,
Email me at: [email protected] and i'll send over a nice manual and some video's i have of mine flying.
Kyle
ID:	1192464   Click image for larger version
Old 05-07-2009, 07:50 PM
  #232
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
Here is the video of mine: http://www.youtube.com/watch?v=coUt7-YhH5c
Kyle
Old 06-09-2009, 07:14 PM
  #233
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
I've had a few question on my set up, so here are some pictures of my bird.
Specs:
Engine - Thunder Tigre .75BB
Servos - 5 (throttle, nose wheel steering, 2 ailerons, elevator)
-Sullivan onboard glow driver (battery located next to rx batt in aft port bay)
-Bomb drop (detachable unit mounted on rail)
-Wing lights (batteries and switch located on aft center wing root)
Kyle
ID:	1215434   Click image for larger version
ID:	1215435   Click image for larger version
ID:	1215436   Click image for larger version
ID:	1215437   Click image for larger version
ID:	1215438   Click image for larger version
ID:	1215439   Click image for larger version
ID:	1215440   Click image for larger version
ID:	1215442   Click image for larger version
ID:	1215443   Click image for larger version
ID:	1215444   Click image for larger version
Old 06-14-2009, 10:31 AM
  #234
robopop
Greetings toAll and WOWAM I Impressed!!!
I was given this link from a fellow rc chat-member andI am glad to see somany people using this plane. I have been in the hobby for about 30 years and about 25 years ago I bought and flew one of these and was the center of attention at the field. I bought it from the Connecticut Rams show and remember it had the aluminum Spars, Side mounted Motor, Venetian blind plastc ailerons, I do remeber landing gear but not sure if i modified the kit myself. I vagely remember gluing a plywood plate under the belly to screw the main gear to. I dont remember the nose wheel setup.The fuel tank was also side mounted and exposed and tie wrapped to the fuse. I used a OS 61 gold head motor which barely pulled it.
The loops and rolls were a breathtaking feat with such minimal power. The greatest part of owning one were the takeoffs offs and landings. The plane would lean back on the mains for most of the runwaythen gently leave the ground. The landings were the same, reclining on approach and holding the nose up on the mains for most of the runway until gently rotating the nose down to finish the landing. No plane I ever had did that so effortlessly. I painted it fuel proof camo and may find a pic if im lucky. if so I will post it.
Of all the planes ibuilt and flew, this onestill brings people over to me from so long ago saying" remember that flogger you had??"
Enjoy the season !!
Old 01-01-2010, 12:29 AM
  #235
torkrollin
torkrollin's Avatar
i and a few other folks at the field have these mig drones and have found that the best way to paint them is either use kilz primer and then spray paint only problem is the paint will get gooy after exhaust oil gets on it. or a oil base paint that can be brushed on, then sand with 320 grit when dry to get the brush lines out. oil base paints wont be affected by oil from exhaust. or you can use oracover with low heat.
these migs can still be found on ebay!
http://cgi.ebay.com/Carl-Goldberg-Mi...item20ae8298fe
Old 10-25-2011, 11:24 AM
  #236
duvaloutlaw
i have a drone or two if someone in north florida, south georgia area wants to trade for some used gear for a foam biplane, i need a motor esc and battery, would also trade for used tx and rx. im do not want to make a cent, just trying to hook somebody up with a mig and hopefully get one of my smaller planes in the air..just putting it out there, all the best. bruce in jax.
Old 11-11-2011, 04:30 PM
  #237
flyinthepark
Bruce,
Do you still have the flying FQM-117B?
I would be interested if you still do. I do not have much to trade but I am sure we can find something that would make both of us happy.
Nic
Old 11-20-2011, 09:34 AM
  #238
duvaloutlaw
yes, Istill have one complete extra plane and a few parts in the rafters,,lol. let me know what your thinkin, later, bruce.
Old 07-20-2012, 12:35 AM
  #239
buzzallnight
This has been a very interesting and informative thread.
Just wanted to say I have two bare bones Carl Goldberg MIG 27s
available cheap for pick up in MN
but shipping costs too much.
Old 09-10-2012, 11:41 AM
  #240
chingon
FQM 117A RCMAT...
ID:	1799907   Click image for larger version
ID:	1799908   Click image for larger version
Old 09-10-2012, 05:55 PM
  #241
buzzallnight
Can we see a picture of the bottom????
Old 05-17-2013, 04:35 PM
  #242
stuk_at_work
My Feedback: (111)
stuk_at_work's Avatar
... and if you are near central/south NJIhave a couple in the Marketplace right now too. LPU as has been mentioned earlier in this thread, way to big to ship!
Old 06-07-2013, 05:04 PM
  #243
brentguevarez
HI I GOT A QUESTION FOR YOU, I HAVE THIS MIG-27 TARGET DRONE THAT I GOT FROM A TRADE SCHOOL WHO GIVEING THEM OUT. SOME TOLD ME THAT WAS PROBELY PROPERTY OF THE US MILITARY, IS THAT TRUE BECAUSE I HEARD THAT THESE THING WERE DECOMMITIONED IN THE 1990s. I GOT THE PLANE FOR SALE ON THIS WEBSITE IF YOU WANT TO SEE PLEASE EMAIL ME BACK MY EMAIL IS ON THE CLASSFICATION AD. THANK YOU FOR THANKING YOUR TIME TO READ THIS
Old 06-07-2013, 05:34 PM
  #244
buzzallnight
These planes are big and expensive to ship.
I have two in Minnesota.
$60 each no engine.
Old 06-07-2013, 06:26 PM
  #245
SHANEC
SHANEC's Avatar
I still have one in the box, "boxes" I never opened Wonder if the foam termites got to it
Old 06-07-2013, 06:30 PM
  #246
buzzallnight
you should probably ship it to a safer location!!!!!
Old 06-07-2013, 06:39 PM
  #247
SHANEC
SHANEC's Avatar
ORIGINAL: buzzallnight
You already have 2 plus there expensive to ship
Old 06-07-2013, 06:44 PM
  #248
buzzallnight
I don't think there is any creature that would get hungry enough to eat that crappy foam the drones are made out of,
so....
your safe!!!
Old 07-12-2016, 10:17 AM
  #249
Pecanpatch
Pecanpatch's Avatar
Originally Posted by rsbwing
Everything you wanted to know about the Goldberg Version of the FQM-117B can be found here. http://www.tpub.com/content/operator...14-P/index.htm
Wow, thanks for posting that!
I picked up a Pristine one at Joe Nall over a year ago........ it still had the servos and Nicads in it....
I am trying to find out what the true paint scheme the military actually used looked like.
Old 07-12-2016, 02:58 PM
  #250
WHIPLASH45
Default 30+ Year Anniversary of the Prop Jet Mig 27
I have placed some video links and some historical images for the FQM-117B , RS Systems original Mig 27 target on RC Groups. Some years ago I posted some of this information in this RCUniverse thread, most of the new information has not been posted before. The first video link is of some flying I did last year with the last Mig I have. The airplane is stock with the exception of the landing gear and modern radio equipment. It also has the only clear canopy I ever made for these as a demo for the commercial version of the 117B. RS made about 5,000 of these all blue foam versions. The second video is from a live fire excercise that Art Pesch (also involved extensivley in the Goldberg FQM117B-1 program) and I did in 1987.
http://www.rcgroups.com/forums/showthread.php?t=2698916
Name:	RS Systems Report a.jpeg
ID:	2172733   Click image for larger version
Name:	RS Systems 6 month Report 1984 back.jpg
ID:	2172734   Click image for larger version
Name:	Bic Green Mig launch 1985.jpg
