What jet guy like to be built?
My Feedback: (14)
Hello
I am woundering wish jet be liked to be built from a plan?What size and power?Wish you cut your self or a short kit laser cut?
How much guy is ready to pay around?
Thank for your time guys!
ERIC
Banned
My Feedback: (67)
RE: What jet guy like to be built?
ORIGINAL: rhklenke
Personally, I didn't understand quite what you were asking? BTW, I cut myself once, and afterwards, REALLY wished I didn't...
Bob
Bob
LOL !!!
Banned
My Feedback: (67)
ORIGINAL: FLYTICOUN
no one have a dreaming jets?
[8D]
[8D]
Ok since you asked, how about making a Nice Mig 29 under $4000.00 "complete" without having to hack it to make it airworthy ?
Size of an Avonds F-15 or slightly larger.
Power, P-120 size or comparable
From the words "build", "plans" and "cut yourself" i take he wants a wood shack to self-assemble like in the good old prop days (remember those thin longish rotating parts up front that made a lot of noise and really hurt your fingers?).
My opinion is that most jets are not suited for a wood construction, at least not when it is supposed to look like the real thing. Scale jets seem to get really crowded really fast...not much room for formers, stringers and supports as would be neccessary. In order to achieve the strength necessary at the room available, composite fuselages are probably the best way to go....taking all the wind out of the all-wood-at-no-cost-thinking.
While this probably holds true for most jets, there are some that wold probably be "doable". Thinking of an Dassault AlphaJet, Aermacci or similar...they offer the space needed, plus a layout that would be favorable for some woodworking.
But then again: composite gives you a great almost ready to paint surface, potentially with panel detail, right out of the mold, at less weight and higher strength.
Just a thought...
regards
Just a thought...
regards
My Feedback: (14)
How about a Douglas A-4 skyhawk 1/5 scale from ply and balsa is no problem many kit are made from ply and balsa and fly with a turbine for power 12 lbs to 38 lbs is ok!!!
example: Arv8,F9F,SU-27,FACET 2400T,FACET 2300,FACET 1200,REACTION 54.
Hello Guys,
well I am building 3 Jets in the moment....
the L29 Delfin is already done
the T2 Buckeye is almost ready
and the Eclipse jet also is prototype done.
So very soon we have 3 new jets in town...
Well,
the Eclipse is ready, The T2 is redy....
If Mike Lin from Globaljetclub get them Released he will have an L29 and an T2 Kit on Fölorida Jets....
Anyone thinking of producing a Jet kit from wood, really needs to think about how difficult it will be to actually build.
What you don't want is something with multiple curves , that require tedious and slow planking with 1/4" wide strips, look at the Zirolli Panther nice framework but lots of difficult work to sheet it.
Something like the F15, F14, Tornado that can be built with more square lines & flatter sections.
You want a ply framework of formers and stringers that can be basically put together in your hands then sheeted with 3" wide balsa, something that will be easy to build and not take a year of gluing on planking and tons of sanding.
