NEED HELP WITH THE PST 600R ECU
My Feedback: (51)
MS
HELLO I AM USING A FUTABA 9C AND A PCM RX. WHAT I AM TRING TO DO IS SET THE THROTLE START USING THE RADIO BUT THE ECU HAS NO R/C ON THE PROGRAM. THIS IS MY FIRST TIME SETTING THIS UP FOR MY BOOMERANG INTRO. AND I NEED ALL THE HELP THAT I CAN GET. ALSO I HAVE NOT RAN THIS ENGINE YET BUT IF U HAVE ANY INFO. ON THAT PLEASE ADVISE.
THANKS
THANKS
RE: NEED HELP WITH THE PST 600R ECU
G-Rookie,
The guy you need to communicate with is Kelly Williams. He is the best PST tech in the business and he will get you fixed up. His e-mail address is [email protected] .
He is a good guy and will return your inquiry promptly.
J. Swanson
J. Swanson
My Feedback: (69)
G-Rookie
Best to post this in the PST turbine support forum. The link is:
http://www.rcuniverse.com/forum/forumid_164/tt.htm
Dave
Dave
CA
Yep. Kelly is the man when it comes to PST ECU problems. There have been a couple of different times when my ECU needed repair and Kelly came through in a big way. He has lots of knowledge in every facet of the PST.
Hi Vincent,
I replied to your email with a few questions and tests I'd like you to try. Just want to make sure you got it...
For future reference, you can reach me by phone/email if you follow the service contact info on the new [link=http://www.pstna.com/service.htm]PSTNA[/link] web site. If I'm not there, leave a message and I'll get back to you the same day. If this is a new ECU that and we can't sort out the problem I'll swap it out for a new one, then have this one serviced and entered back into North American service stock.
Kelly
PS: Thanks for the support guys!
ORIGINAL: G-ROOKIE
THANKS
THANKS
My Feedback: (51)
MS
HELLO KELLY LAST NIGHT I CHANGE OUT THE RX WITH A FUTABA 7CH. FM PPC AND THE NO R/C WENT AWAY AND I STARTED THE ENGINE FOR THE 1ST TIME AND IT RAN PERFECT EVERY TIME IN THE BELOW 50'S AT NIGHT. BUT WHEN I PUT IN THE FUTABA 8CH. PCM THE ECU READS NO R/C IN CHANNEL 3. I THEN PLUG UP AN SERVO AND THE CHANNEL WORKS FINE. NOW WHEN I GO BACK TO THE PPM RX AND THE SAME JR.6V 3000 MAH IT WORKS FINE WITH ONLY THE ECU PLUG UP ONLY. THE PCM RX HAS ALL THE SERVOS PLUG UP AND STILL NO R/C READINGS COMES
My Feedback: (51)
MS
ALSO BE ADVISED THAT I USED THE SAME JR. 6V 3000 MAH BATTERY EACH TIME BUT I JUST CHANGE FROM A PCM TO A PPM FM AND THE NO R/C GOES AWAY WITH NO PROBLEM, ALSO THIS ENGINE RUN'S PERFECT
My Feedback: (51)
MS
JUST TO LET YOU ALL KNOW THAT KELLY AND THE PST GANG ARE AWSOME AND WONDERFUL. THEY CALL AND RESPONED TO MY PROBLEM REAL QUICK. THE ECU AND THE HAND TERM WILL BE SENT IN FOR AN UPDATE TODAY. THE PROBLEM OF USING A 6V CHANGING TO A 4.8V WEN'T AWAY WITH NO PROBLEM. SO IF YOU GUY'S IS THINKING ABOUT BUYING ANY PRODUCT FROM PST THAT'S THE WAY TO GO, THE SUPPORT IS STRONG LIKE THE JETCAT GANG. SO THANK'S AGAIN AND NOW I FEEL LOVED.
