*** Large F-4 Phantom owners ***
#52
RE: *** Large F-4 Phantom owners ***
Johnny, I flew this particular model for at least 4 seasons in it's previous life as a ducted fan. It was powered by two BVM .91s with Viojets and BVM F-16 ducting. I believe it came in around 27lbs dry. It flew like a trainer plane! It was very forgiving and even with many engine out's it still had no problem. The C.G. was perfect when I flew it, but I'm not sure of the location. On takeoff it did not jump or lurch off the ground like some F-4's. I would ease up on the speed to be safe. I think with a little weight as a turbine, it will fly even better.
Good Luck!!
Larry
Good Luck!!
Larry
#54
My Feedback: (21)
Johnny
it's probably just the angle of the photo on deck but it appears to me that the incidence on deck is too flat. that could delay rotation, causing severe pitch up at take off, or worse yet exceed tire speed.
a slight positive stance on deck wouldn't hurt, especially with the Peggy trying to push her down the runway possibly compressing the nose strut and worsening an already flat AOA.
I'm sure the bro's out in Germany have better guidance and look forward to hearing / seeing the first flight report. paint job looks sweet, that's one sexy bizatch!!
good luck
Buck
good luck
Buck
#55
My Feedback: (85)
ORIGINAL: yeahbaby
Johnny
good luck
Buck
Johnny
good luck
Buck
Kevin
#56
Banned
My Feedback: (67)
I do agree with Buck and Kevin, the AOA has to come up. As far as this Jolapy being scale, it is not even close to scale. This thing was made to fly, they tweeked all they could for it to fly, kinda like Byron did with that big F-15. I'll make sure that the AOA changes this weekend and try to fly it.
Thanks again.
Thanks again.
#57
Johnny,
This may help
http://homepage.eircom.net/~skycam/L...its/videos.htm
Take a look at the CJM big F-4 video of my 1997 model. As you can see not much AOA there, but got off fine.
Cheers and best of luck with the maiden.
This may help
#58
My Feedback: (85)
ORIGINAL: Jetflyer 24
----It sure looks good though, Johnny!!! I wouldn't mind havin' 'er in my hangar!!! Let us know how the flight goes...
Kevin
#59
WI
My JHH F-4 is only 68-inches long, but it is probably among those closest to scale. There are a couple of points that might apply to your larger F-4:
1st, The main gears are quite far back. In elevation view, if you draw a line from C of G to ground contact point (estimate its height above wing), I get about 43-degrees instead of the 20-25 for easy rotation. Beside increased AOA setting mentioned in above post, I would make sure you have the recommended tailplane deflection to get airplane nose up. And don't forget to put back on hi-rate when landing, if dual rate elev is used, or it tends to come in hotter even with flaps.
2nd, my F-4 need flap to elevator (for nose up) mix for landing. Again enuf elev travel is helpful so you can still control attitude. You probably know these already from your smaller F-4. Good luck with your maiden.
Phil
Phil
#60
Banned
My Feedback: (88)
Here are some pics of me and Tim with General Cherry who flew Phantoms back in Vietnam. He flew a camo scheme F-4 very similar to mine and Johnnys. I love my Phantom more and more after each flight. -Patrick
#61
Hm, i've always been wondering why everyone is making such ugly high alpha nosewheel struts on the F-4. It just does not look right...
Johnny, don't worry about the alpha, leave it as it is, it works out just fine. All the phantoms here are flying with scale length and scale alpha. (The one on the far right in the white and blue was done by my comrade according to McDonnell factory drawings, it has scale strut length and aoa). Noone has any sorts of problems and they all rotate smoothly.
One more flying hint, coming from a full size F-4 driver. The real thing usually does aft stick takeoffs. Line up with runway, spoolup, release brakes when passing 80% and pull full aft stick. Wait until nosewheel unsticks and then smoothly release on the elevator. Hold the nose up until the plane flies off on its own.
It works for the models just like it does on the real thing. Key is to hold up elevator during the entire taxi run to unstick the nosewheel as early as possible. Give it a try, that way you don't have to pull tricks with an ugly nose strut setup :-)
I'll get back to you with throws and CG tomorrow
Best regards
Hank
Best regards
Hank
#62
My Feedback: (85)
ORIGINAL: Miniflyer
#63
Banned
My Feedback: (67)
Those are some cool pictures Hank, thanks a bunch. I'll be doing the maiden in the next few days and try to have or post a video of it, if not some pictures. Once again, thanks for all the help. Hopefully, Michigan Jets will be the first meet for this beast
#64
Kevin you're right, but i've seen the strut a lot on the long nose F-4E and F variants....that's just off and looks bad. My opinion...and it works scale if flown correctly :-)
Johnny, i'm standing next to my comrades plane now. Locations and throws as follows:
CG: 31cm from wing root on fuselage (very front, not the front of the small part that is molded on!). +/- 1cm makes no difference. DO NOT go beyond 33cm or it will get mushy and tailheavy!
Throws:
Aileron 2.8cm up, 2.4cm down
Elevator +/-3cm on LE, slight "up trim" for neutral
Rudder 7cm both sides at TE bottom
Flaps 5.6cm. Elevator goes UP (!!!) 0.7cm for full flaps down
Good luck on the maiden
Hank
Throws:
Hank
#65
WI
Hank aka Miniflyer, can I bother you with also getting the root chord measurement at the fuse junction? I'd like to see how the deflections in a different scale F-4 compare. TIA!
Phil
Phil
#66
My Feedback: (85)
ORIGINAL: Miniflyer
Hank
Hank
Kevin
#67
Phil, i'll get back on that as soon as i speak to him again, in the next few days.
Kevin, i think you got me wrong on that. The E and F versions (the one with the gun and the long nose) never had the extending strut. You can get along without it just fine, and there is also no need to make it longer, the short strut will rotate just fine if takeoffs are performed correctly.
Greets
Hank
Greets
Hank
#68
Banned
My Feedback: (67)
Ok everything is set ( throws, AOA and CG ). We're having terrible weather down here so as soon as we get a break, maiden will take place. Thank you all for your help and I will post the end result.
#72
Banned
My Feedback: (67)
ORIGINAL: pbusa1400
nice flying jet johnny
The Beast finally flew today in the more than capable hands of pbusa1400 [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif] ( i left my b@l$$ at home, I was waaaay too nervous to do the first flight ).
First we had some issues with one of the wheels that was locked and everyone jumped in and got it loose. The jet was very very slow, I mean the only high speed pass I would say was at 35 MPH TOPS, we all thought that it was history but she hung in there and climb to about 200 ft after 3 minutes at Full throttle than POOOOFFF ( Deadstick ) ran out of fuel, we all said bye bye.......
She glided to a beautiful landing, we were all shocked to see that its such a baby. My BV F-4 would've been so history, its not even funny of how slow this thing flies. We have to find out what the problem is because everyone at the field was saying that it wasn't pushing more than 25 lbs max.
So there you have it guys, after almost 5 years the Jolapy is a keeper[8D]
Thank you Pablo so much for the great job you did tonight.
#75
My Feedback: (12)
FL
Proof it finally flew. All I got was the takeoff since I pushed the wrong button and it only recorded on the small memory card. What do you expect from BlackCloud anyway? LOL
Congrats J. Now lets's figure out why you tried to fly it on a P-60 thrust?
http://media.putfile.com/Johnnys-Large-F-4
