Elevon Linkage On Top Or Bottom Of Roo's Wing?
CA
The valves us a processor that has a maximum recommend voltage of 5.5V If you are using a 5 cell pack, it may not function properly unless you reduce the voltage to the valve. This can be done by a diode junction drop place in series with the power input to the valve.
I personally use these in my HotSpot and I use a 5 cell pack. I also use a 5.6V regulator and never had the programming lost. I am pushing it however at 5.6V
Bob Wilcox
JetCat USA, LLC
No promotional signature needed!
Bob Wilcox
JetCat USA, LLC
