Boomerang XL II
#701
RE: Boomerang XL II
I would use crow braking more to increase washout at slow speeds rather than actually slowing the jet down so I would use it no matter how slow it comes in without it, think it can be a great benifit to most jets
#702
RE: Boomerang XL II
The XL had its first flights today flew perfect, just few clicks of trim, CG at 340mm from TE seems ok, 25deg of crow braking is very effective on the Jet much more so than on the Intro.
Plenty of power from the big AMT Pegasus
Pic beside my Intro which shows the size difference, the XL is a big aeroplane! (lost a red stripe on port wing on first flight!)
#710
RE: Boomerang XL II
The XL II is still popular, and selling very well in the USA. It is arguably the best jet trainer around. At speed it is like any other jet, deceptively quick due to its 90"size (quicker than it looks!) and a real kick to fly, but for flying at low speeds, in my opinion it is unbeatable. As I always do, I aimed to design a jet that did more than just go fast. Have a look at this;-
[link]http://www.youtube.com/watch?v=UDxwbbNHQ0o[/link]
#712
RE: Boomerang XL II
This model stil gives me great pleasure. Thanks for posting that video. It was delightful flying and an example to us all.
When the wind is bit strong and gusty, then I pick up my XLII. Yesterday being a case in point, with wind gusting 25-30mph swirling every whichway around the trees beside our field, she handled every problem and landed so gently you would have thought it was a calm evening. In my view she remains a truly great model. I am amazed it is not still available from Boomerang Jets here in the UK as it still is in the USA. I would recommend it as a first jet to anyone who has a 120-160 engine.
#713
RE: Boomerang XL II
My Boomerang XL with Simjet3000 a windy day at Lista airfield Norway. GoPro camera facing forward until battery died so landing is from trip number 2 with camera facing backward.
The XL is perfect in windy condition. Stable an with crow during landings it settle down perfect. No bouncing.
http://www.youtube.com/watch?v=seIWDsOxc0o&hd=1
#714
RE: Boomerang XL II
A few years ago there was a bit of a heated argument in a Boomer thread about Alan Cardash's designs calling for the use of Servo screws to mount the retracts to the rails. I defended Alan at that time, railing against a rude know-it-all who insisted the practice was folly, and suggested that because Alan had designed and sold quite a few jets in his time that he was probably on to something.
It dawned on me today that the topic is worth revisiting, because since then I have had the opportunity to *thoroughly* test Alan's methodology and reasoning.
Even in my sincerely overweight XL II (I added a bunch of crap I didn't need to and it weighs 40 lbs wet), on grass, and with several "firm" landings plus a short one in the dirt off of the approach end (against the freshly plowed crop rows, mind you)....the puny little 9/16" servo screws have held up very well. On the totally dorked up short landing my jet came to a stop in about 5 ft (!) and the screws did exactly was they were supposed to do: they gave way enough to prevent ripping out the rails! A few drops of CA to firm up the screw holes, two cents worth of new screws, and all was well again.
I do have trailing link gear, and that helps a lot, but I suspect the method is even MORE valid with straight legs, since there is less give built into the gear, and the screws can act as a "fuse", blowing themselves out and saving the rails and/or pins...
Hope this helps someone !
Don.
Don.
#715
RE: Boomerang XL II
I have had a blast with my Boomer for a few years and this winter I decided to change the look a bit. I glassed the wings , center section and the elevator. Then I flite metaled a good part of it then painted the rest. It's not perfect but I have had a lot of fun. I also did a full cockpit and changed the canopy to an ultra flash one.
#719
No more love for the XL II? This was a great thread. I picked up one used that needed some TLC and this thread was a great resource. Is there a more currently used thread on this XL II design?
Woketman (04-11-2021)
#721
Looks good Carlos.
Approximately where is your 'empty' fuel CG at and weight? Mine's had some repair work done with some carbon and fiberglass stiffening up in the forward fuse area. Total weight of mine without fuel is probably about 32 to 33 pounds.
What are your low and high rates at (did you end up using differential on the ailerons)?
If you have a low and/or high rate crow mix, what did those come out at?
how many degrees of FULL flaps do you use and in what conditions do you use flaps and how much for no wind vs windy days?
#722
I've had them. Nice model easy to fly.
alas a wing exploded in the air, probably overtaking the VNE! 600 flights to his credit.
the CG is shown in the attached drawing, it's a very front CG, can be backed up to 20mm. good flights with.
