Sophia J-850 ECUs settings
Banned
I reset the ecu to its base menu by holding down the menu button for about 2 minutes,
all three lights were flashing together.
I found out afterwards it deleted many of the menus that were accessable and adjustable.
peristalic pump menu... cool down menu...etc.
I wrote them down before I did this rather stupid thing:
this is what I had on it :
min rpm ---53000
max rpm-- 130000
temp------celsius
Battery 7 cells
low battery --enabled
fuel tank --1500
low fuel limit --250
fuel checking -disabled
glow plug power 2.60
Spd Ctntrl SWO ACT-hold speed
Spd Ctntrl SW2 ACT- lin speed
max limited airspeed-- 330
max airspeed-250
min airspeed- 100
speed reg val I-18
speed reg val-p-500
speed red val-d-200
max temp-- 850C
min temp ---240c
Time at max temp --5.0
max start temp ---900C
cut off temp 950C
min fuel flow 90
max fuel flow 280
oil pump power (deleted menu)
lo-65
hi 70
oil pump on rpm --14000
(deleted menus)
speed sensor- opto
kp -lo 7.0
ki -low.080
ramp fakt 3.0
ingition end 25000
DT ingit--5.0
ingt temp 500C
Dr accelr-- 10
run temp chk --enabled
start temp chk disabled
rpm chk -enabled
cool down temp 250
cool min ppm 5500
cool max --6000
auto optimiz--enabled
pump voltage lim 7.83
ramp up time 3.5 (seems short)
ramp dn time 3.5
u-low-----.095
u-high--3.45
ignt air off rpm 11000
u ignite 1.3
ingnite time 6.0
u accel 1 .975
u accel 2 1.575
accel ramp 13.0
I did try the battery on
ign
lim
lim
run
no change
if you have a running engine I would love to set it up the same as yours.
min rpm ---53000
max rpm-- 130000
temp------celsius
Battery 7 cells
fuel tank --1500
max airspeed-250
min airspeed- 100
speed reg val I-18
speed reg val-p-500
speed red val-d-200
max temp-- 850C
min temp ---240c
cut off temp 950C
min fuel flow 90
max fuel flow 280
lo-65
hi 70
(deleted menus)
speed sensor- opto
kp -lo 7.0
ki -low.080
ramp fakt 3.0
ingition end 25000
DT ingit--5.0
ingt temp 500C
Dr accelr-- 10
rpm chk -enabled
cool down temp 250
cool min ppm 5500
cool max --6000
ramp dn time 3.5
u-low-----.095
u-high--3.45
u ignite 1.3
ingnite time 6.0
u accel 1 .975
u accel 2 1.575
accel ramp 13.0
ign
lim
lim
run
no change
Banned
RE: Sophia J-850 ECUs settings
Thanks for the help Mick, sorry no change or original or addition menus appeared.
jettronics v.2.0 may not have had a way to recover the original programs.
peristalic pump menu still missing,
cool down menus
I think Ive collected enougn info and settings to try running it again.
to bad DR Hoya did not just toss an electric starter on the front...
these engines were years ahead of jetcat at the time.
cool down menus
Hi JOhn!
Try to contact Horst Lenerz. He and MArkus Zipperer developed the Sophia ECU. You can find him on www.jet-tronics.de
David
David
Banned
I will try this also, Thanks in advance....
I have never ever seen the "Boss" menu ,
so this will be a new and good development if I can get there.
There is very little info out there on these engines.
Lets help get the rest of those door stops up and running....
Banned
Already emailed jet-tronics..de,
waiting reply,
no answer yet....out flying.
No rush, its fun to tinker and collect info,
only some of this info was out on RCU before.
The more info, the fewer door stops there will be.
waiting reply,
Banned
Thanks guys
Success.... all the menus are back,
hold manual button on gsu down while turning on reciever,
press
ingition
limit
limit
menu
run
do the sequence twice to get all the menus back
basic menu ....returned along with oil pumps, cool down,etc..etc...
Now I just need a verified know good set of ecu settings to run the engine with.
anybody with a know good running set .
press
ingition
limit
limit
menu
run
My Feedback: (25)
John,
Instead of going back and re-typing everything, I will just put my parameters highlighted in red that differ from your settings beside the ones you have already given. Mind you, these are the original settings as it came delivered to me from the dealer (Planes Plus) 7 years ago. The engine has never been run by me( 13 minutes factory time only) and none of the settings have been changed that I'm aware of. The parameters given are for comparison purpose only.
When you power up by just switching on the receiver, make sure the display shows 21/22 Celsius. This is about normal room temp. If not, you will need to re-calibrate.
min rpm ---53000 ..... 51000
max rpm-- 130000..... Same
temp------celsius
Battery 7 cells....6 cells
fuel tank --1500
glow plug power 2.60.....2.40
max airspeed-250
min airspeed- 100
speed reg val I-18
speed reg val-p-500
speed red val-d-200
max temp-- 850C
min temp ---240c
cut off temp 950C
min fuel flow 90
max fuel flow 280....200
oil pump power (deleted menu) Oil Pump Type> Peristalt 15/20
lo-65....75
hi 70....85
(deleted menus)
speed sensor- opto
kp -lo 7.0
ki -low.080....140
ramp fakt 3.0....2.5
ingition end 25000
DT ingit--5.0
ingt temp 500C
Dr accelr-- 10
rpm chk -enabled
cool down temp 250
cool min ppm 5500
cool max --6000
pump voltage lim 7.83....7.80
ramp dn time 3.5....4.0
u-low-----.095....1.00
u-high--3.45.... 4.50
u ignite 1.3.... 1.60
ingnite time 6.0
u accel 1 .975.... 1.25
u accel 2 1.575... 2.00
accel ramp 13.0
temp------celsius
fuel tank --1500
max airspeed-250
min airspeed- 100
speed reg val I-18
speed reg val-p-500
speed red val-d-200
max temp-- 850C
min temp ---240c
cut off temp 950C
min fuel flow 90
lo-65....75
hi 70....85
(deleted menus)
speed sensor- opto
kp -lo 7.0
ki -low.080....140
ingition end 25000
DT ingit--5.0
ingt temp 500C
Dr accelr-- 10
rpm chk -enabled
cool down temp 250
cool min ppm 5500
cool max --6000
ingnite time 6.0
accel ramp 13.0
I will go to LosAngeles from Japan in July.
Can I purchase with a credit card the J-850 engin directly?
Thank you to contact you.
[email protected]
hashimukai
[email protected]
hashimukai
