Nitro models pusher Bobcat?
Reply
Old 12-13-2007, 10:59 PM
  #2701
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nitro models pusher Bobcat?
Yup, not a big deal.
Just sand down the wing roots and the fuse until they are even.
I had to do this on two of these planes.
A circular sander makes short work of it.
opjose is offline
Old 12-14-2007, 11:12 AM
  #2702
AGR413
AGR413's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: wflineman2
I got my Bobcat the other day, put the main wings on bar and pushed up against fuse and they did not line up, one hit the front first and the other hit the back first with a gap on each. The holes in the fuse is at an angle. Has anybody had this trouble.
I had some of what you are talking about, I installed wing bolts, when they are tightened down the gaps go away. Well all except the ones at the trailing edge, I used some crystal clear duck tape to eliminate the gaps at the rear. Yes I'm a fan of the KISS principle.
AGR413 is offline
Old 12-14-2007, 08:28 PM
  #2703
Stick Jammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you talking about the wing tube or the anti-rotation rod?
Stick Jammer is offline
Old 12-14-2007, 10:04 PM
  #2704
wflineman2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing tube is out of line, when I measure from wing tube to anti-rotation rod there is 1/8" difference.
wflineman2 is offline
Old 12-14-2007, 11:00 PM
  #2705
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can someone tell me where to get the wesson pusher pipe in the USA
Meekskin is offline
Old 12-14-2007, 11:38 PM
  #2706
fw190pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shouldn't be too difficult to straighten out alingment of the wing tube. Dremel out the holes in the fuse to get wings lined up correctly and glue in some plwood plates with the correct size hole inside the fuse (oil or wax the tube first). Cut two or three sticks slighly longer than the fuse wedge between the plates to use as clamps while the glue cures on plywood plates. Tape the wings in place to insure alignment. When that cures fill in holes on outside of fuse.
fw190pilot is offline
Old 12-15-2007, 05:10 PM
  #2707
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The left wing was off a little. I used a round file and elongated the anti-rotation hole in the fuselage and the wing slightly and everything was OK. No need to make it complicated at this point. After everything is together alignment can be more easily checked and then adjusted.
Bill
BillS is offline
Old 12-15-2007, 06:03 PM
  #2708
Stick Jammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good advice from fw190pilot. This would be my method as well. I wouldn't do any sanding of the wing roots or fuse as these areas are not the source of the problem. Just be sure to try fitting the wings without the anti-rotation rod to make sure it is the wing tube holes that are off.
Old 12-15-2007, 06:14 PM
  #2709
Stick Jammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Meekskin
Here's the website:
http://www.westonuk.co.uk/index_090.htm
Based in UK but USA orders get shipped from Chicago branch so you only pay USA shipping rates.
Old 12-15-2007, 06:17 PM
  #2710
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Stick Jammer
Did I misunderstand the problem?
I though that he referred to the wing not sitting flat against the fuselage, in addition to the alignment pins being off.
opjose is offline
Old 12-15-2007, 08:20 PM
  #2711
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that sounds good..Thanks for the link and I'll order the pipe.
Meekskin is offline
Old 12-15-2007, 08:30 PM
  #2712
Stick Jammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: opjose
The way it sounded to me, one wing is touching the fuse at the leading edge of the root with a gap at the trailing edge and the other wing is touching the fuse at the trailing edge of the root with a gap at the leading edge. This would indeed seem to be a misalignment of the wing tube holes in the fuse. I forgot how far back into the fuse the wing tube actually sits, so fw190pilot's method of gluing in the plates may not be too easy. If the wing tube holes are indeed misaligned I would definitely find a way to get them where they belong but at this time I can't suggest an easy method without being in those shoes.
Old 12-15-2007, 09:13 PM
  #2713
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
I misread it then.
opjose is offline
Old 12-20-2007, 07:39 PM
  #2714
serge760
serge760's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.youtube.com/watch?v=oEFBtqjmIuM
very funny, bobcat was the winner
serge760 is offline
Old 12-21-2007, 08:20 AM
  #2715
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also tapped the wing rib and used 1/4-20 nylon bolts to secure the wing to the fuselage. As the wing tightens up any fit inaccuracy is hidden. The nylon bolts go in from inside the fuselage and knurled bolts were used. I used one bolt for each wing.
Bill
BillS is offline
Old 12-21-2007, 11:34 AM
  #2716
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone purchased the Gensis pusher pipe from Weston in the UK. I bought one and cannot get the company to reply to any emails about the shipping date. I have sent them an email each day for the past week....no replys at all..not very good company at this point.
Meekskin is offline
Old 12-22-2007, 09:45 PM
  #2717
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you guys balanced your bobcat, did you balance up side down or right side up...I have retracts in mine and assume it needs to be balanced up side down with the retracts up. what you think??
Meekskin is offline
Old 12-23-2007, 03:15 AM
  #2718
bigplumbs
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Always ballance upside down
Dennis
bigplumbs is offline
Old 12-23-2007, 11:47 AM
  #2719
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had some glue in a blind nut holding the nose gear steering. With a little tap, tap the former came loose and out. It was good to get the former out to replace the blind nut. It was not good that the former came out so easily.
Consider reinforcing the former to fuselage joints or at least inspecting the joints after the initial flights.
I balance in a string cradle and it doesn't matter which way is up.
How much weight did the retracts add?
Bill
BillS is offline
Old 12-23-2007, 12:34 PM
  #2720
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bills,,,,I'm really not sure but my total weight ready to fly is 7lbs 12oz. I am using Robart retracts (older ones with hard plastic housing) which is lighter than the all metal retracts. I could lose a oz. or so by getting a smaller air tank. Some mods to the firewall former were required like taking out the factory installed rails and putting in a plate that allows the retract to sit lower in the plane. This allows the wheel to retract inside the plane. I am using the Magnum 52 engine with a Weston pusher pipe. This engine turns 16,500 with the stock pipe and will easily turn 18,000 plus with the weston pipe. I am really please with the way the jet went together and plan on the maiden flight soon after the new year.
My first attempt at balancing the plane shows it to be nose heavy with the battery up in the nose but this was trying to balance using my fingers and I don't know for sure its nose heavy.
I have gone over all glue joints that I could reach. The glue and the coverage from the manufacture is not good. I have the Bobcat 25 that I am flying with a OS32 and its a great plane to fly so I am expecting the 52 to fly even better. With the weight under 8 lbs. and the great motor, I am expecting level flight speeds to be over 100 mph. Other than the mod for the nose retract, I built the jet stock. The mains fit perfect and work fawless. I'm using 3/16 wire for the mains and 5/32 for the nose and when they are in the up position the jet looks really clean.
I will post some pics now that I'm almost finished.
Meekskin is offline
Old 12-23-2007, 05:03 PM
  #2721
Stick Jammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bigplumbs
Dennis
When you say "always", do you mean any plane or this one? General rule of thumb is to balance with the bulk of the plane facing down for the simple reason of having more mass below the point of balance which tends to make the process easier. Other than that it doesn't matter if the plane is upright or inverted. I balanced my Bobcat upright with no trouble at all.
Old 12-23-2007, 06:21 PM
  #2722
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is now balanced and I did it upright. I just held the plane at eye level and used one hand. Also a few pics of the gear tucked away.
ID:	832408   Click image for larger version
ID:	832409   Click image for larger version
Meekskin is offline
Old 12-23-2007, 06:27 PM
  #2723
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a very good idea to use the carriage washer as you've done, to spread the force out over the surface.
I'd recommend doing so to anyone else as well. You can find these specialty washers in most hardware stores.
They have a relatively small hole but are large in area.
opjose is offline
Old 12-23-2007, 07:04 PM
  #2724
Meekskin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Opjose, I agree with you on the carriage washer. I also put a metal tube inside the wing which allows the screw to be tightened down really tight. No movement on the booms. I also recommend everyone to use locktight on all metal to metal screws. There are 3 members in our club that's building the Bobcat and we will all maiden the same day....at least thats our plan. I will take pics and post them here when we fly. Also hope to get Radar gun to check speeds to see who is the fastest. Course, is its not me, I will be disappointed.
Meekskin is offline
Old 12-23-2007, 07:48 PM
  #2725
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good looking pictures. Hope the maiden is very successful.
Bill
BillS is offline
Contact Us Archive Advertising Cookie Policy
