Nitro models pusher Bobcat?
Reply
Old 08-28-2006, 07:36 PM
  #251
MarkF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nitro models pusher Bobcat?
I flew mine this weekend . I converted it to electric and got one flight in. First off I used what I had laying around for power. Neu 1521 2y with 12s 1p 3700 evo batteries. This set up is a little to hot because I could only swing a 9 X 6 prop. It tacked out at 26000 on the ground and it felt and sounded really good but it just wouldn't get up and go once it was up in the air. I think you need at least a 10 inch prop at minimum but an 11 would be better. My cg was at 9 1/2 but I think 10 would be better. My batteries need to be all the way back as far as I could get them. I had to dremmel out all the bulkheads so they could slide all the way back to the wing spar rod. I got rid of the front wing rod and drilled it out to 1/4 20 to hold the wings on. I think this was the easiest way to secure the wings. She wieghed in at 9 lbs ready to fly and I felt she handled this weight with ease. Now I just need to get a different motor or less batteries before I can fly again.
Mark
MarkF is offline
Old 08-28-2006, 07:59 PM
  #252
mugenkidd
mugenkidd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark it sounds like your prop maybe flattening out at high rpm at 26000rpm on a 9x6 prop you should be able to make even a 12lb plane haul ass. Mathmatically speaking a 6 in pitch prop should be pushing air out at about 147 mph. What type of prop are you using?
mugenkidd is offline
Old 08-28-2006, 09:35 PM
  #253
MarkF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was using a regular apc pusher gas prop. I see SJN didnt like his 9 inch prop either. This air frame is going to need a bigger disc to get the performance we want. I also posted in this forum because some of the people wanted to put bigger motors and they wanted to know if it could handle the weight. I found this plane easy to land at 9 lbs. I will be changing my set up to handle an 11 inch prop.
Mark
MarkF is offline
Old 08-29-2006, 11:45 AM
  #254
B58
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the question on the .75 engine. If it is a Tower .75 it will have a little less power than an OS .61, at least that is what I experienced on an Enforcer. I then went to an os .91, and it had about twice the performance. I will have the .91 powered Bobkitty flying in a week or so. Bob
B58 is offline
Old 08-29-2006, 03:06 PM
  #255
bassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I decided to go with a Saito 72 instead. It just fit better back there and sould swing a three balded prop easily. If that dosen't give me what I want I can alway do a little surgery and put in the 75 2S. I also have a 91 2S In another plane that could move over is necessary.
Bassman
bassman is offline
Old 08-29-2006, 03:34 PM
  #256
XJet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bassman
A 4-stroke in a jet-ish plane?
Dude, that's wrong, just plain wrong :-)
XJet is offline
Old 08-29-2006, 05:20 PM
  #257
bassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I'll tell ya, anything other than a turbine on a jet is kinda back woods isn't it. I think the real dirver on this one was the big 2 stroke muffler sticking the wrong way. I just like look of the four stroke on the plane better and the 72 should swing the 3 blade 11-7 without any problems.
Bassman
ID:	515490   Click image for larger version
ID:	515491   Click image for larger version
bassman is offline
Old 08-29-2006, 10:04 PM
  #258
topper5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
now i have never flown a jet with a 4s, but to each there own, and as we are all in this for fun! that's what it's all about!, right????
i think as long as it gets off the ground and fly's he's cool,
(good to go), it will sound funny, kinda like a small flying tug, but it will look like the rest, very cool.
just sound funny!
the plane looks great best of luck BASSMAN.
topper5 is offline
Old 08-30-2006, 01:02 AM
  #259
noahb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bassman, I like it. I think four strokes sound killer and I do like the idea of the muffler. I have a saito 100 that would fit nicely on the back of one of these. I just wish I could find like a 10X10 pusher or 11X9 pusher. I had a saito 91 with a high pitch prop and that mustang was just as fast as my Shrike with my rossi on it. The only problem is the limited selection of pusher props. I emailed APC about it and have yet to hear from them. I would be cool if they would make some high pitched ones.
I do have a few of these kits, one has a Rossi 45 on it, the others are back up. However, i think one with the saito 100 would be cool.
noahb is offline
Old 08-30-2006, 01:13 AM
  #260
noahb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it looks like Zinger has an 11x10 pusher that would be a good match for the Saito 100. Might have to try that.
noahb is offline
Old 08-30-2006, 04:10 PM
  #261
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the 4 stroke idea.
so I instaleld a Magnum/ASP 65 in mine.
I hope it performs better.
ID:	516161   Click image for larger version
ID:	516162   Click image for larger version
ID:	516163   Click image for larger version
SJN is offline
Old 08-30-2006, 05:00 PM
  #262
noahb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that looks cool. Let us know how it comes out.
noahb is offline
Old 08-30-2006, 05:29 PM
  #263
bassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How have you guys been handling the take down of the Bobcats for transport? Are you removing the booms only? Are you leaving the booms on the wings and taking the wings off? It makes a difference in how I set up the servo extensions coming off the boom servos. I really like to keep the connections to a minimum when I can.
Bassman
bassman is offline
Old 08-30-2006, 05:32 PM
  #264
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hehe, mine just fits in my car in one piece.
a pic of my chipmunk in the trunk
SJN is offline
Old 08-30-2006, 10:19 PM
  #265
GotSky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would really like to pick one of these Cats up. But Nitromodels can not give any ETA's as to the next shipment. Are there any fellow modelers out there with an extra BOBCAT 50 "YELLOW" kit that they would like to part with. Please let me know : jwmclean@dslextreme.com
GotSky is offline
Old 08-31-2006, 04:07 AM
  #266
roo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why not go the whole hog and put a steam engine in it ? (smirk). Paul.
roo is offline
Old 08-31-2006, 04:29 AM
  #267
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You underestimate the power of the dark 4 stroke force
SJN is offline
Old 08-31-2006, 05:22 AM
  #268
bassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh come on now we all know that rubber bands are the untimate power souce.
As far as take down. I have a small puickup and I like to take three planes when I go to the field. Therefore I need to take the wings off so that I can fit them in my rack. I am going to keep the booms mounted to the wings and upgrade the canopee attachment little so that I can get at the wing bolts inside.
Bassman
bassman is offline
Old 08-31-2006, 09:47 AM
  #269
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
grrrr..... got disapointed again with its performance. Just not enough speed for satisfactory flying.
I only had a 12/6 pusher prop for the 65 4 stroke, and it flys as bad as the 46 with a 9/7.
I just bought a 11/8, and will try it soon.
Which prop would you use on this plane with a 4 stroke 65 ?
Its much easier with a jet engine......
SJN is offline
Old 08-31-2006, 10:36 AM
  #270
bassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an 11-7 three blade on mine. I haven't flown it yet so I can't tell you what it's gong to do. The chart says that @ 10,000 rpm a 7 pitch should be capable of 80 mph. You need a 9 pitch prop turning at 10,000 rpm to break 100 mph. With the Zinger props you have to get into a 12" prop before you can get into an 8 or a 10 pitch. Then you start to run into ground clearance issues.
Bassman
bassman is offline
Old 08-31-2006, 11:06 AM
  #271
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, i changed my mind.....I isnatalled a Magnum 65 GP 2 stroke.
This engine will hover my falcon trading cessna which weighs a ton, so it should move the bobcat.
Ill toss over the 4 stroke into the cessna instead.
ID:	516552   Click image for larger version
SJN is offline
Old 08-31-2006, 05:09 PM
  #272
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haha I had told you sonnich Move on to the .90 class !!
Strykaas is offline
Old 08-31-2006, 05:40 PM
  #273
noahb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zinger makes a 11X10 two blade. I would stay away from three blades unless you have to use them. They are not as good as a two blade. I have a rossi in mine. It will turn a 9x8 apc at 16000, but they don't have that in a pusher.
So i am going to run either a 9x7 zinger or a 10x6.
Now I have my saito 100 which should be a great match for the 11x10 zinger.
I would like to get a Dub Jett motor, but they are very expensive. the good thing is you can get them rev. rotation for $25 more and then you can choose any prop you want.
noahb is offline
Old 08-31-2006, 05:43 PM
  #274
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
are zinger props of wood ?
I cant use wooden props on our grass field, as they get damaged too easy in this plane.
I only had wooden props, but they only last one flight.
SJN is offline
Old 08-31-2006, 06:15 PM
  #275
G-ROOKIE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you guy's should try the os 91fx, That should make you very happy.
G-ROOKIE is offline
Reply
Display Modes
