Nitro models pusher Bobcat?
#2851
RE: Nitro models pusher Bobcat?
Those look pretty nice. I was thinking of using them for another project.
BTW: Anyone here running the Graupner 11x8 props?
I noticed that the warnings from Graupner indicate that these props should not be run faster than 12,275 RPM lest they break apart!
With the GMS or Tower engines, we can crank them up WAY beyond that.
#2852
CA
ORIGINAL: opjose
Yeppers on that opjose.....after trying all the other available pusher props (and that includes the 3 bladed props)....came to the conclusion that I was getting the most speed with the Graupner 11x8 prop....
#2856
ORIGINAL: patzane
So them retract should work on this bobcat. What about motor. OS 55 vs Tower 75 which will give you the most speed
If I remember correctly the OS 55 does very well especially when combined with a pipe.
However it's performance is about on par with the much cheaper Tower 75 or GMS .76, so you can save your dollars if you wish.
The latter two work fine with the included muffler.
#2857
ORIGINAL: CrashPro
According to their included warnings, we should NOT be spinning the prop that fast lest it break apart.
#2859
I would offer the Magnum 52...cheap but very good motor....look at my pics on eariler post. You can get 16k with regular prop and 15500 with pusher prop. You will like the speed.
#2860
IL
ORIGINAL: airborne14830
I am thinking about getting the 50 - 51" bobcat. I see it take 8 servos and are folks using standard or high torque servos? Also, for the elevator, can you do a one servo installation (joining the elevators halfs with a joining bar) versus using two servos? My experience with dual elevator servos have not been good at all. In addition, I'm thinking about using an evolution .61 for power that I have already broken in. If I need more pwoer please advise.
The elevator is one piece, the rudders are separate. The stock servo configuration is set up for dual mini's on elevator and rudders. Go back to page 99, post 2461 for an option using a single standard servo for elevator and rudders.
#2861
IL
ORIGINAL: doubledcom
Opjose.......Thanks for the info. Maybe I'll try them for all the control surfaces as I was thinking about going with just 1 servo for the rudders and connect the rudders with a control rod as others have done on this thread. They should also be ok I would think for the elevator as well if they have that kind of torque. I don't want to spend a fortune on servos for a 100.00 plane. thanks again
I modified the tailboom servo bays for standard servos and went with a single on elevator and a single for rudders. I used Hitec HS-475HB's all around. With a 5-cell pack they are rated at 76 oz/in torque. 100 bucks gets you all six, big savings over the stock set up using mini's.
#2862
My Feedback: (49)
Opjose....Just got the graupners....but have not used them...It's going to be quite a long time before I get to test them out .....we just got another 12 inches of snow and gusting winds of 30+ miles per hour....couple days ago we had temps of 20 below zero......I hate winter....
#2863
CA
ORIGINAL: opjose
Have you had any indications that I should pay attention to Graupner's warnings about the max RPM speed on the 11x8 prop?
ORIGINAL: CrashPro
Haven't had any props come apart on me opjose....I had canopy screw come off and hit the prop and take a chunk out of the prop,...but it still didn't break.
#2865
The canopy looks good. I am attempting to come up with a better method to attach the canopy and am interested in your approach.
Bill
Bill
#2866
My Feedback: (927)
Bill,
I have used the rear catch and pin thru the nose method on mine. It is simple and very strong. My Bobcat is turbine powered and the canopy has never even shown signs of being loose. Also allows quick entry to the interior, a must for a turbine powered jet.
There is a conversion article on my web site which shows how it's done. check it out. [8D]
www.southfloridajettogether.com
#2867
ORIGINAL: BillS
Bill
Bill
The magnets are unneeded. They are holder-overs from my first attempt which did not work well.
#2868
WI
Oh yeah. I found out magnets do not work well when in the shear position. I used 2-pairs of 3/16" dia rare earth magnets which worked well after changing them to pull against their flat circular faces. Always had a nagging suspicion that the added stray magnetic field might cause Rx problems close by so had the Rx wrapped around with alu foil; & was able to have good Rx performance.
@Opjose, care to give a bit more detail on your electric version?
Phil
ps: @Opjose, I like the way you mounted your canopy.
Phil
#2869
IL
ORIGINAL: BillS
Bill
Bill
#2870
ORIGINAL: PhilLin
Phil
Phil
This turned the little Bobcat .25 into a little screamer of a plane.
It draws about 700+ watts 38Amps, so it is roughly the equivalent of a .40+ glow engine.
Unfortunately it is a non-retract plane due to it's size.
The canopy mount I used above enables quick access to the battery packs.
I had to remove one of the formers to get both of the batteries to fit.
The clips I used are from Dubro. Two pairs could be used to firmly attach a canopy for the larger sized Bobcat.
#2871
Thanks for the canopy mounting information. Parts of both ideas will be used.
The South Florida Jet site was very interesting. The canard's were particularly interesting.
Bill
Bill
#2872
ORIGINAL: CrashPro
ORIGINAL: opjose
ORIGINAL: CrashPro
#2873
ORIGINAL: patzane
going to stay with the TH 75 as it has been great so far. I will look for a nice tune pipe hope to get more RPM with the 11x7 prop. Last time I check I was 13000 RPM
Nobody stands near the prop!! I can tell you that! it screams!! I run 20% ys fuel and run it on the rich side, just as it begins to lean. It will unload more in the air, so be careful when turning this prop fast, the blades are a bit too wide for speed as it will unload more than an APC. But it pulls like a truck.
I cannot find a better pusher prop for my ST.90 either. I wish someone made an 11x9 pusher.
#2874
I've been asked twice how I did the mod for the GMS or Tower engine exhaust, ( an improved version of what you see in the picture below ) so I'm posting this here.
I mounted the muffler in place with the exhaust facing down.
I obtained the longest stock exhaust deflector I could find.
I used the Venom deflector. This one: http://www3.towerhobbies.com/cgi-bin...?&I=LXRHS9&P=7
I temporarily installed the deflector on the muffler.
I drilled a hole the same size as the deflector just past the "bend" on the deflector. The Center of the hole was just past the bend point about 1/8".
I removed the muffler, then using a GP engine center hole marker/finder ( so as not to rip up the wood ) I marked the center point on the lower wing drilling through it with the GP Hole finder tool.
I then opened the hole up to size from the bottom of the wing.
I then CA'd the wood around the now open holes, by dripping in THIN CA from the other side. This hardened the wood for the next step.
I had on hand some brass snap rivet rings of the right size which II ended up using but I had ordered these, which should work as well.
http://www3.towerhobbies.com/cgi-bin...?&I=LXRHP4&P=7
The rings were epoxied in place to prevent the wood from cracking with any vibration from the deflector.
Once dry I installed the muffler and deflector ( through the rings ) back onto the plane.
I wire tied the deflector to the muffler.
I then put silicon canopy glue on the deflector both top and bottom to prevent fuel from seeping into the inside of the wing.
Canopy glue is removable but impervious to glow fuel...
The top and bottom had to be separately done as the canopy glue runs... so the top was done first one night and the next I did the bottom.
The deflector was exposed about 1/8 to 1/4" of the deflector UNDER the wing. The first time I flew it I found that some fuel would end up smearing across the wing itself, which I did not like...
soooo....
I got one of these: http://www3.towerhobbies.com/cgi-bin...?&I=LXRHR9&P=7
And epoxied it just to the stub of the deflector ( not the ring ) that was sticking out of the bottom of the wing... that way if I ever want to remove or replace the deflector I merely cut the deflector from the top of the wing, then pull it through.
The coupler angles back.
The whole thing looks pretty good and it keeps the plane perfectly clean.
soooo....
#2875
Opjose, Nice looking system but how fast does it fly. I flew mine today and could not believe the radar gun reading. Top speed today was 122mph....this is with my magnum 52 weston pipe and of course retracts. I really like the way my bobcat flies and I know it will go faster. If I could enclose the wheel wells I'm sure my speed would go up. Anyway, the 122 mph is the fastest for our club. Lets see what other bobcat owners are getting. POST your speed here.....
