Nitro models pusher Bobcat?
#1576
RE: Nitro models pusher Bobcat?
ORIGINAL: dragonpilot
I should clarify that by saying stock locations not gear. I threw out the chrome stock struts after about the 2nd or 3rd flight. I made up several copies of the struts using better metal. I think I posted this a while back with a picture. Post #353 page 15..
#1577
I don't know about holding the nose off since I fly on a grass field. The grass tends to force the nose down. I would guess that the nose would stay up as it does with some of my jets, which also have gear well behind the CG.
#1578
Ordered a white canopy. Thanks for the posting!
I've been attempting to carve a replacement in order to stretch a plastic replacement. This is FAR easier, even with the shipping, lol...
Incredible, the # of postings on this airframe. I've read just about every one and I've yet to even begin mine other than drilling the mounting holes for the aluminum landing gear under the engine plate.
Keep up the great work, y'all!
PM
PM
#1579
HEY!
just got my BOBCAT, i have the OS55AX, what prop size is recomended for this combo? (2/3 blades)
THANKS!
TAMIR.
THANKS!
TAMIR.
#1580
Banned
ORIGINAL: GSK
Guess stickjammer has not flown his yet , he will find out when he tries to fly it .
after seeing mine fly there are 4 more being built In our club.
Might even turn up at Tok In the weekend
I've got a TT46Pro or an ASP52 to throw in it (and a tuned pipe if I can knock up a header in time).
#1581
IL
ORIGINAL: tamir_250
HEY!
THANKS!
TAMIR.
HEY!
THANKS!
TAMIR.
#1582
FL
I ran a 2 blade 10 X 8P APC brand on mine. Got good top end speed. We radar gunned it at 103mph and this is with the stock gear. I have to ad that this was with the wind (not very strong one). Just make sure you get the darned low end and top end settings right, or that transition will eat choke it out and you'll have a rather dented bird to deal with. Keep the speed up, and your lines straight or with gentle curves until you get the feel for it. Trust me, I made all of the above listed mistakes and now my new BobCat in being shipped to me as we speak....LOL
Bruce
Bruce
ORIGINAL: tamir_250
HEY!
THANKS!
TAMIR.
HEY!
THANKS!
TAMIR.
#1583
i saw a very fast flight on this video, you guy's can see the setup at the begining of this video.
what do you guy's think, this is a faster setup?
THANKS,TAMIR.
http://media.putfile.com/Nitro-Model-Planes-Bobcat
THANKS,TAMIR.
#1584
Having a little problem slowing mine up even with the MW44 on idle, and flapperons induce a big pitch change, so looking for alternatives.
Anyone tried using the rudders as air brakes, i.e putting them both inwards to try and bleed of the speed?
J
J
#1585
My Feedback: (8)
ORIGINAL: J.F
J
J
Mark
#1586
ORIGINAL: NM_Mark
I will be pitching them out, instead of in (don't want to fry the edges of the rudder with turbine blast!)
#1587
When using the ailerons as flaperons have you tried moving them up a little when setting up for landing ,
( not down as you would think at first )
this will allow you to slow the model down to just above the stall and produce nice nose high landings with full control
#1588
Hi,
I have 2 possible power options to power this model:
1 A very nice MVVS 49 rear exhaust,I was considering trying to put a mini pipe through the rear fuz somehow to keep it very streamlined.... build as light as possible.
2 An old Super Tiger 61 which I could set up for reverse rotation however this would be with some sort of exhaust/pipe combo outside the fuz ect as normal.
Question is which to go for ????
any suggestions?
any suggestions?
#1591
ORIGINAL: hapyjac2
Did you add Flaps? I split the alerons and made flaps. She slows to a walk when coming in for a landing. I'm using a SimJet 700.
#1592
ORIGINAL: Crazy4Flight
I think you may need to install a speed brake like the Kangaroo~Rookie~Harpoon.
#1593
I have an MVVS screamer .40 with pipe on my Balsa Nova. I can imagine the .49 RE!
Lighter, more economical, (FAI fuel) and a better selection of prop sizes and pitch to choose from. I have a Bluehead 60 ST and it weighs a ton, son, lol...
I would think running the pipe into the rear fuselage and exiting out the bottom pointing to the slipstream would be an optimum install.
Now I wish I had rotated my cylinder exhaust to the rear prior to breaking in my .40 :-)
Let us know whatever combination you choose...I'd like to see a few photos!
PM
PM
#1594
FYI,
I bought a bobcat and it came with a red canopy, red is for the yellow version. I was thinking about ordering a second one so thinking the same thing could happen again I ordered two silver canopies when Nitro got some canopies in stock. When I placed the order I put in the comment section that I wanted silver not red, white, orange or any other color, only silver. I received my order today and it had two orange canopies in the box. WAY TO GO NITRO ! They make spraypaint for plastic but I read in this thread that others had problems with the paint flaking off and I can't match the silver/light grey color. Now I have three canopies of the wrong color that I don't want to use. I have not talked to nitro yet to see what they say about it. I think i will end up being stuck with them and having to make them work.
Two canopies- $14.00
Shipping - $11.01
Total - $25.01 = Three canopies of the wrong color.
Shipping - $11.01
#1595
Speaking as one who destroyed his canopy trying to replace the rosey tint, I'd think that you'd be able to unload your 3 with other modelers like myself.
I ordered a white replacement and its on its way. I'll let you know if I get a silver instead. Maybe we can work out a possible trade, LOL...
PM
PM
#1596
ORIGINAL: PointMagu
PM
PM
#1597
OH
My canopy came today it was the right color [red] where does the orange come from ?? they dont sell a plane that those go on its red white or silver !! oh well gl with that
Jason
Jason
#1598
ORIGINAL: dragraces
Jason
Jason
#1599
I have the orange and black scheme........It came with a red canopy!!!!! I ordered another with the same scheme and it to came with a red canopy.....I orded the grey canopy and they came in orange...... The red canopies were painted black and it worked good.... The orange ones match the scheme well so I guess i am lucky.....Mark
#1600
WI
JF, can you program some flap to elevator mix on your xmitter? I had a plane with flaperons that had a severe nose down tuck when full flaps were applied, which I was half anticipating. keep dialing in additional flap/elev mix with each flight until the tendency was neutralized at about 35 to 40% setting. Landing flair was good & slowed down from that point. Good luck!
Phil
Phil
