Skymaster F-18 Chippy Ho
#151
My Feedback: (7)
RE: Skymaster F-18 Chippy Ho
As a rule of thumb the shorter the better.
Install servo arms in order to have the desired control surface travel with the least amount of distance from the servo center to the push rod.
This wil reduce the torque needed at maximum displacement.
Better known as the famous mechanical advantage.
#152
Thanks Juan,
Which did you use? The elevator servos are close to the tailpipe. I saw on Jeff's they were somewhat longer than standard.
Pete
Pete
#154
Thank you Juan, Thats exactly what I needed to see.
BTW, Did you encounter any slop in the elevator pushrod? I was told there may be a little if it is not reinforced with carbon fiber or the rod is changed to titanium.
Pete
Pete
#155
My Feedback: (7)
Yes Pete:
Is a very good idea reiforce this area.
I did it with F. Glass and hi strength epoxy.
C. Fiber is better.
Also this area will need some reinforce.
See photo.
You will see some failure in time.
This is because F-18C is nose heavy aircraft by nature of design.
Titanium rods are always better than steel but you can live with stock ones.
Have had no problem with them.
Juan.
C. Fiber is better.
See photo.
Juan.
#156
Juan, Thank you for your help and pictures.
I'm going to my LHS today to buy my extensions.
I'm figuring 4 @ 48" for elev and rudder and 4 @ 36" for aileron and flaps.
Does that sound about right?
Pete
Pete
#158
My Feedback: (57)
Pete, you still buying extensions man? go to www.cheapyharnesses.com and buy the crimping tool, some servo lead and gold plated connectors. It will make your installations so much neater man.
#159
Thanks Juan,
David, Yeah Im still buying them, The JR's have not let me down yet.
BTW I just picked up an 8611 for my NWS, I heard the 18 is very hard on the nose wheel.
#160
What are you guys using for air valves? Particularly the nose wheel? I was informed that mechanical valves such as the UP series would not have the volume needed and may cause problems with the forward retracting nose wheel?
Other than that the UP series or robarts looked good to e and I like the needle valve setup. If I have to get a EV5 I will but I want to know what you guys think first.
Thanks! Pete
Thanks! Pete
#161
My Feedback: (7)
I'm using stock valves from SM. and Robart for the retracts.
They all work good. "0" Leak.
You can use an EV5. The set up will be easier.
The only reason I did'nt employ it, other than I alrredy had all stuff for my actual set up is that my air circuit for the G. doors rams is isolated and operating at just 40 to 45 Psi.
Retracts at 100 Psi.
This is because the G. doors hinges went broken in this particular aircraft if you are not very precise with the installation. And this is not easy.
So I opted for the split.
Also I'm using Tam hinges.
They are enought flexible and don't break apart under reasonable pressure.
EV5's share the air from both retracts and G. doors; Well as far as I concern at the time of my set up.
If you can split these circuits using EV5 you are blessed.
Hope you can put your F-18 in air.
Juan.
Juan.
#162
Juan, I am totally interested in the EV valve but keep hearing strange things about them..
Of course I am reassured that the ratio of issues to non-issues is negligible but, There are some pretty experienced guys I have spoken with that do not trust them..
#163
My Feedback: (7)
Well my friend all I can tell you is that conventional method with a Jetronic sequencer works very good.
I do not have experience with EV's so I can't say a word.
But, yes I'd like to have one only for the convenience.
Good luck each way you decide.
Juan.
Juan.
