Yellow F-4
#52
RE: Yellow F-4
I have to finish this first then it's off to the Hornet. Thought I'd throw a pic of my Angel flight box in there - Mini Fat Albert. Are you going DF again with the F4 or taking the leap to turbine?
Dan
Dan
#54
RE: Yellow F-4
If you fit Spring Air 301s, which are drilled for piano wire leg, are you fitting robart oleos over the piano wire stub or making the whole leg from piano wire? If fitting robart oleos, straight or offset leg to fit in the wells?
Harry
Harry
#55
RE: Yellow F-4
according to yellow you can't use a strut, you have to use just the wire because the wing isn't thick enough for both. RC crafters makes custom gear for this plane
, but its not cheap. $495.00 for struts and $695.00 for strur and retracts
John
John
#60
My Feedback: (48)
RE: Yellow F-4
dshults,
These look like the tanks that were in my F-4.
http://www.rcgroups.com/forums/showthread.php?t=633079
Just curious aren't they available from Yellow any longer?
Joe
Joe
#62
RE: Yellow F-4
I have over 2000 flights on yellow F-4's....For the ducted fan version the wires are fine. If you go turbine I like the strut and shock for full fuel take offs and heavier landings. The mods are easy to do to have doors and all. Check out my pics on page 1..
Kevin
Kevin
#63
RE: Yellow F-4
I did a turbine conversion of the JHH Skyhawk and originally used wire legs. It was awful, it was barely controllable due to flexing of the wire and the model wobbling about because of the higher weight. I changed to robart oleos and it made a big difference. Problem is that the minimum length of the robart offset leg is a bit too long for the F-4, RC Crafters looks nice but I don't want to spend that much on 3 legs! With postage and import duties and taxes charged here on their arrival, it will come to about $670.
H.
H.
