Fei Bao 1/8 Scale F-18F Super Hornet
#227
IN
RE: Fei Bao 1/8 Scale F-18F Super Hornet
Has anyone experienced the aileron servo (HS 5245MG) sitting too high in the aileron servo well. The way it sits right now my hatch doesn't fit flush with the top of the wing. Could someone send a pic of how they mounted their aileron servos? That might explain it better..Thanks, Rick
#228
My Feedback: (30)
here is how it looks, I did have to shave some of the wood from the inner side of the cover.
Also the "L" brackets are mounted with a screw thru the wood former but I did glue in a reinforcement of carbon fiber which the screw goes thru.
Paul
Paul
#229
IN
Thanks Paul, that's exactly how I did mine as well...I may try and shave some off the hatch for a better fit...I'm installing the control horns tonight..I had one of the Pre-slot locations that was wrong from the factory so I'll have to fix that..Thanks for the help!! Rick
#233
My Feedback: (13)
udi,
It does not matter which brand do you use for the F-18. Pick one that you know you can get support and service from your dealer. Both of the brands you mention are good. I do have a preference for Jet Central, so that will be a the Rhino.
The thrust for the F-18 is another matter. I will fly my FeiBao F-18F with a 30 pounds Super Eagle (not sure how many newtons, > 120N but less than 160N). I think this should be ok. A 160N turbine will be excellent
#234
My Feedback: (18)
edgar
thank you for your answer
i want the best turbine that i can get to that bird
i know that two off them rate high
but i want the most relibale and the stornger on to that size
as we all know the merline have better thrust and accelaration
but what about relibilety and service
thanks
thanks
#236
Yes I had a SM F18c with a Merlin. Performance was similar to a missile. I now have the SM F18E Superhornet which I am building for the same engine. I expect this to be just a little slower but should still easily exceed 200MPH. Fantastic engine.
Regards,
John
Regards,
John
#238
IN
Paul, Is the elevator position at neutral exactly horizontal??? I'm setting up the radio and wasn't sure if it needed a slight bit of up elevator....Also did you split your elevators on the F-18?? Running on two separate channels?? Thanks,
#239
ORIGINAL: udi maman
is ther any one who use the merlin 160 with the f 18 f
i got the fei bao one
thanks
udi
thanks
udi
Cheers- Marty
#242
Hi Dave
I don't belive you will have a problem with that. Don't drill the carbon shaft. I have mine that way.
If you have a problem with that put 5 hinges instead of 3.
Regds
Nuno
Regds
Nuno
#243
Can someone tell me the correct angle for the airbrakes when fully deployed? As delivered mine only deflect around 30 degrees up.
Malcolm
Malcolm
#246
Hi
I am using 135mm and it flew fine last weekend, again. Measure it at the wing leading edge near where it joins the fuse.
Also when flying the plane I found it to be kind of sensitive with 50mm elevator throw and 15 mm aileron throw. 50 and 30 expo respectevely.
Good luck
Nuno
Good luck
Nuno
#248
My Feedback: (15)
anyone have a picture of their bypass install? Mine seems to sit too high in the aft part. Wondering if the flange on the bypass goes below the mounting blocks for the turbine mount (which seems to correct the thrust line/center of intake/exhaust)?
Dave
Dave
#249
Hi
I have 25mm for take off and 50 for landing. I only use half by-pass. used to use all the bypass but I guess that the turbine works better with just half bypass.
Also I believe that the pipe runs cooler that way
Good luck
Nuno
Good luck
Nuno
#250
My Feedback: (15)
Hi Everyone,
Well I am working on replacing all of my door hinges and installing the retracts and struts. However the drilled position for the retract (main) will not allow the strut to pass through when retracting without hitting the fuse.
Has anyone else noticed this? What did you do to fix it? I can onl imagine grinding part of th emount out and sliding the retract towards the midline of the plane.....
Thanks for your help,
Dave
Dave
