I hate rivets!!!!
My Feedback: (85)
I hate rivets!!!!
Kevin,
Looks great!!! I can see plenty of rivets and know all about the crosseyed late evenings and the numb fingers that you must have went through. Never mind David as he wears glasses so he must be blind---Sometimes I wonder if he's deaf and dumb too!!! I guess that he can't be all that dumb as he moved from the great white north down to God's country. I noticed the BobCat on the dining room table----your house looks like mine! I've got an Avonds F-16 being built on the dining room table, a HotSpot being built in the guest bedroom, and an Air Magic F-15, BVM Super Bandit, and Trim Aircraft F-86 being built in the garage. My wife is running out of patience with me. I told her that spring is right around the corner and that everything will be in the garage soon.
I know you are proud of your plane and I know what you went through to modify that kit so that it would be turbine airworthy. I'm glad to see that your several months of hard work has paid off. I wish that I could go to FJ to see it fly. Have fun!!!!
Kevin
Kevin
Rivets
Kevin,
WOW -- now I understand why so many rivets are used on your models.
Great workmanship !!! I would be afraid to fly it.
Nice airplane -- thanks for the look.
I hate rivets!!!!
So where's the rivets???
Thanks for the compliments, I guess it really has come a long way from the way it looked for it's first flight in Mississippi last year. Hopefully the weather will cooperate and I can put more flights on it in Florida next week.
My Feedback: (7)
TX
I hate rivets!!!!
>>>>>>>>>I had to move some furniture around in the living room to be able to put it together, but here is a full side view>>>>>>
kevin
mmmmmmmmmi have to object to the above.......who needs furniture when you have cool planes like you do.........let me remind you that you only need furniture when you have a wife.....and who needs one of those......been there done that
hornet driver
kevin
hornet driver
#31
I hate rivets!!!!
Kevin,
Think we'll be able to see that thing in the air with those little wing tanks? Sure does look good. I am still partial to the Krylon job we did on that wonderfull morning in Miss. last year.
Mike Jensen
Mike Jensen
#32
Macchi
As for those tip tanks, I have been having to wear my blue blockers just to work on the darned thing. Hell that flourescent red is so bright Dave Brown might even OK this jet for night flying.
Except for the coffe table, that is what I eat off of since the dining room table is "in use".
#33
NJ
question about those rivets
When you all apply those rivets, are they burnished on from a sheet? Are they decals or dry applied? Are they applicable for a warbird--different sizes? I am working on an Ziroli AT-6 now and that's why the questions. Finally, do you put them over the paint, or paint over the rivets?
Thanks for the help, Tim
#34
My Feedback: (7)
TX
I hate rivets!!!!
>>>>>>>>>Did you not see the Bobcat on the dining room table???? The furniture is for storing the jets on. Sheezzzz!!!
Except for the coffe table, that is what I eat off of since the dining room table is "in use".>>>>>>>>>>>
good man kevin ................sounds like my house.....errr hangar
#35
I hate rivets!!!!
Tim,
The rivets I use are from Pro Mark. They are dry transfer graphics and are simply burnished onto the surface. Pro Mark's marketing says that there is no need to put clear over the top of any of thier graphics, but I always do just to be sure that they stay put.
After painting all of the colors onto the airplane I wet sand the entire thing, then do all of the panel lines with a .060 Rapidograph pen (I use this because you can mix your own ink color in it), then I apply the graphics, and put all of the rivets on last. This airplane was a bit more of a PITA for the clear since most of it has a flat finish but all of the flourescent red is shiny, so I had to tape off all of the red to shoot the flat clear on it. Inevitably when I un-masked it many of the rivets came off with the tape, so I had to go back and re-apply them before taping off the flat surfaces and then shooting the gloss clear.
#36
NJ
thanks for the rivet information
Kevin,
Where do you buy this dry transfer rivet material (Pro Mark?) Is this the preferred method over the adhesive "drop" method with the syringe? Thanks Again, Tim
#37
I hate rivets!!!!
http://www.pro-mark.com/
"Preferred" is rather subjective, it all depends on who you ask.
My answer is yes, I prefer to use the rub on graphics but then again I am lazy.
The other thing to consider is that the adhesive drop method is going to give you a raised (3 dimensional) rivet, dry transfer rivets have virtually no thickness to them (not enough to be noticable with your finger anyway). Since most full scale aircraft built since the late 1930's have flush rivets, the graphics are probably more realistic.
#38
rivets
WOW - not only are you guys terrific builders and pilots. You are also Artists to boot.
I am impressed. I will have to go to one of those meets to see these aircraft
