If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 226
  1. #101
    FalconWings's Avatar
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: JetLegend F-16 (1/8) Testflight
    Guys, I used a JR-9411 for the rudder and it barely fits, had to grind some material off of the support bracket. Use that as a reference.
    Man can't wait to fly mine!
    .......by Mennen.
  2. #102
    Jim Cattanach's Avatar
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Asif
    Guys,
    I would like to know if anyone is using flap for landing?
    Regards
    Asif
    I used the ailerons as flaps & the elevator as elevons. I found that flaps did not help the landings, in fact they made it more awkward. It lands easily without flaps. I still have the flap/elevon setup, but do not use the flaps.
    One point to watch. I did not like the rudder control setup. I had bad rudder flutter on mine & could not fix it. I ended up removing the servo & glueing the rudder in a fixed position. The JL L39 uses the same type of control & a friend at our club had flutter & lost the rudder on his. Some alternative control is required.
    JET FLYING:- Resistance is futile. You will be assimilated.
  3. #103
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can't do that here in the US. Rudder is required
    www.hobbiesxtreme.com
  4. #104
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sweetpea01
    An alternative pull pull wire setup would be better.
  5. #105
    Join Date
    Oct 2004
    Edmonton, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jascat100,
    Thanks for your reply. Basically you have servos in the wing that are not being used as neither aileron nor flaps? If you have fixed you rudder, how do you combat cross wind? I used my rudder in cross wind. Is there an alternate to rudder mechanism?
    I want to stick with concealed control throws, I will want to avoid pull pull, simply because of aesthetic looks.
    Regards
    Asif
  6. #106
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The rudder linkeage is similar to that of Tam's F-16. It works pretty good. The flutter must have been casued by the control pin not being properly lined up or not enough contact. Or........big gap between rudder and fin.
    .......by Mennen.
  7. #107
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Asif
    Jascat100,
    Regards
    Asif
    You can do a pull-pull internally. Stick an auminum .25 rod at the rudder leading edge. The rod should extedn down all teh way to just above the tailpipe inside the fuselage. You will have to drill a .25 hole for the rod to pass trough. Once the rod is inside the fuselage just be creative and make the pull-pull.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    .......by Mennen.
  8. #108
    Moderator
    Join Date
    Apr 2002
    Belton , MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I made a longer pin and used a METAL ARM. The new pin sticks 3/8 of an inch deeper than the stock pin.
    AMA #70046 Jet Junkie!
    Without Gravity, Your Lockout Jet becomes Space Junk.
  9. #109
    Join Date
    Oct 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    drdoom,
    can you post picture of you rudder mods?
    Asif
  10. #110
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    prvious post, I added a graphical representation of what I had in mind.
    .......by Mennen.
  11. #111
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Asif
    drdoom,
    Asif
    ditto
  12. #112
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can anyone suggest what JR servos will fit in this plane?
    I've got lots of 8411 and 8611A's laying around.
    I know the wings are thin
    I don't fly any other type servo so please don't suggest other brands
  13. #113
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I then suggest you go for an Avonds or a Yellow Aircraft!
    I have 8717's (freaking lightning fast!) on elevators. Had to trim the bracket some to make them fit. 8411 on rudder.
    And as for the ailerons, go get an Avonds or a Tam !!
    .......by Mennen.
  14. #114
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So are you saying that no JR servo will fit in the wing? Tell me it ain't so!!!!
    what is an 8717 and 9411 from your posts #101 and #113?
    Did you actually mean 8711 and 8411? Or are these the foreign versions?
    Ok, so for the wings what servo is fitting? And does anyone happen to have the dimensions of the servo along with speed/torque
    I'm not buying another jet so I'll have to do some searching (and soul searching) to find something or mod the plane to fit.
  15. #115
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I could only fit an HS-5125's (thin wing). There seems to be a JR foreign servo that WILL fit. It's on an issue of Jet Mag. I'll try to find out for you.
    JR8717 is the fastest servo so far I know of. .05 sec at 150 oz-in. Perfect for Elevators!! it is a little bit larger than an 8611. 8611 should fit almost perfect.
    .......by Mennen.
  16. #116
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info. If you can find the JR foreign servo I'd appreciate it......I don't have any jet mags to research
  17. #117
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is what I found so far
    JR
    DS168 Digital Thin Wing MG Servo Specs
    Torque: 47oz @ 4.8V ; 53oz @ 6.0V
    Speed: .17sec/60Β° @ 4.8V; .14sec/60Β° @6.0V
    Dimensions (WxLxH): 0.34 x 1.33 x 1.18 in Weight: .7 oz
    Bearing: Dual
    Motor Type: Cored
    Gears: Brass, Alloy, and Plastic combo
    Deadband: less than 1us
    Hitec
    HS5125MG Digital Super Slim Wing Servo
    Motor Type: 3 Pole Ferrite
    Bearing Type: Dual Ball Bearing
    Speed: 0.17 / 0.13 sec @ 60 deg.
    English Metric
    Torque: 41.66 / 48.60 oz.in (4.8v/6v) 3.0 / 3.5 kg.cm
    Size: 1.18" x 0.39" x 1.33" 30.00 x 10.00 x 34.00mm
    Weight: 0.84oz 24.00g
    This JR servo appears to be very close. (infact smaller)
    JR Hitec
    53oz Torque 48oz Torque
    .14speed .13speed
    1.18x.34x1.33 1.18x.39x1.33
    so if your Hitec is fitting than this one should as well (I hope)
  18. #118
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Found it, sorry bro, thought it was JR. They used an S3150 (Futaba). I thought S was for foreign versions. That's how much Futaba I know.
    Yes your shall fit. The 5125 is a comfortable fit.
    I also purchased this from Dreamworks (Saves you 3 servos and 3 valves):
    .......by Mennen.
  19. #119
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I saw that.........was thinking about it very closely. I'm going to order up the JR wing servos and use 8611A's on the other surfaces
  20. #120
    Join Date
    Jan 2004
    Irvine, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sam,
    Try these servos for ailerons.
    http://www.horizonhobby.com/Products...dID=JRPSDS3301
    DS3301 Digital Wing Servos
    Mike
    Global Jet ARF PRO, Air-C-Race-Germany, CNC-Italy, Feibao, Der Jet, Jet Legend, Flying Legend, Xcalibur, Skymaster & more - globaljetclub.com, we keep our members flying
    UAS CERTIFICATE NUMBER: FA34E9PRFE
  21. #121
    Lasse Palm's Avatar
    Join Date
    Dec 2003
    Stockholm, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Andrew!
    Send some pictures on my JL 1/8 F-16
    I have flown JL F-16 approximately 150 times and are really happy with the model.
    Regards
    Lasse Palm
    Team Jet-Sweden
ID:	974595   Click image for larger version.
  22. #122
    Moderator
    Join Date
    Apr 2002
    Belton , MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: FalconWings
    Im using 125 Analog. in the wings, work very well
    Let us know how well you like that new valve setup.
  23. #123
    Join Date
    Jan 2004
    Irvine, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Lasse,
    Really nice looking photos.
    How did you set up the background? Looks like a studio quality photo.
    The golden canopy looks really nice. Could you tell me how to do that, please?
    Mike
  24. #124
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm going to do the plumbing tonight so I can test the EV5U. I can tell you this, it will make the setup simpler, but you will not save weight. The valve weighs at least tas much as 3 mini servos and 3 small independent air valves put together.
    If there are no signs of a Rabbit soon, I will test fly mine with my P-70. I cn't wait any longer! [8D]
    David
    .......by Mennen.
  25. #125
    Moderator
    Join Date
    Apr 2002
    Belton , MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    David
    Did you get the Festo version or the hose barbed?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
