JetLegend F-16 (1/8) Testflight
Reply
Old 06-20-2008, 03:13 PM
  #126
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JetLegend F-16 (1/8) Testflight
Is the brake proportional on that Airpower device?
Mike-Lasse posted awhile back in this thread that he used spray can (lexan paint) on the inside of the canopy. Just touch off on the shade but it does look very good.
Lasse can you post your reccommended throw settings for each surface with expo and where you put the CG?
sweetpea01 is offline
Old 06-20-2008, 03:20 PM
  #127
drdoom
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has what is called BRAKE or ANTILOCK.. Either way. Not sure how it works.
drdoom is offline
Old 06-20-2008, 03:34 PM
  #128
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw the antilock in the online ad........I was hoping someone out there has some real-world experience on that
Old 06-20-2008, 03:48 PM
  #129
Lasse Palm
Lasse Palm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The pictures are taken in a studio (for my home page)
I painted the canopy from the inside with yellow clear cote.
My initial elevator set up is with 40 mm movement each way with 25% exponential.
Ailerons these are set to 20mm each way with 25% expo.
The rudder movement is set to 13mm each way with 30% expo.
Centre of gravity Approximately 160mm from front edge. see previous photos!
Regards
Lasse Palm
Team Jet-Sweden
Lasse Palm is offline
Old 06-20-2008, 04:15 PM
  #130
FalconWings
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ASKED TODD, HERE'S THE ANSWER:
"Antilock pulses the brakes, otherwise it is just on/off.... "
FalconWings is offline
Old 06-20-2008, 06:04 PM
  #131
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Lasse and Falcon. Let me know how it works out for you.
Old 07-17-2008, 11:26 PM
  #132
Achillesfilho
Achillesfilho's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys we just finished our JL F-16 and would like to share with you some pics.
We can´t wait for the maiden flight
ID:	992749   Click image for larger version
ID:	992750   Click image for larger version
ID:	992751   Click image for larger version
ID:	992752   Click image for larger version
ID:	992754   Click image for larger version
ID:	992755   Click image for larger version
ID:	992756   Click image for larger version
ID:	992757   Click image for larger version
Achillesfilho is offline
Old 07-18-2008, 08:51 AM
  #133
drdoom
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very Nice.
drdoom is offline
Old 07-19-2008, 11:00 AM
  #134
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very nice indeed.
Do you have a photo of how the rudder linkage is supposed to hook up stock? I've never seen that yet.
Old 07-19-2008, 04:42 PM
  #135
xurifle06
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thought i would post some photos of my 16. Its not finished yet but i thought i would drag it out and snap some photos in the nice weather.
Rich
ID:	993709   Click image for larger version
ID:	993710   Click image for larger version
xurifle06 is offline
Old 08-29-2008, 05:18 AM
  #136
bukeym
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Lasse,
I have a question about the panel lines. How do you make them visible ?. What kind of paint do you use?.. Is it just black pencil?
I appreciate your advice.
Best Wishes,
MURAT
bukeym is offline
Old 08-29-2008, 11:50 AM
  #137
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the model has not been painted.........
while in prime you lay out the panel lines with tape (chart tape comes in various sizes). Then you spray a few coats of primer over the chart tape. You don't have to do the whole plane since its already primed. Pull the tape up and then lightly sand the plane, clean it up and your ready for your primary colors. The lines should be there.
If its already painted then I guess you can draw them, not sure how else you would get them on there.
Old 08-29-2008, 11:57 AM
  #138
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still looking for someone to show me the rudder linkage hookup
Old 08-29-2008, 04:30 PM
  #139
FalconWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bukeym
Hi Lasse,
Best Wishes,
MURAT
Murat, the panel lines are already molded in this model.
If you have a kit version like mine (all white) you airspray black lines along the molded panel lines, yes black and they do not have to be true nor perfectly aligned. You then use light coats of gray paint over and the "black" lines will now show off as moisture marks.....making the panel lines look 3D.
If you have an ARF Gray model, try to match the gray colors as best as possible, then add a few drops of black paint to make the paint darker, but not too dark. You then airspray the dark gray along the panel lines. Again, this technique will give you a "dirty" panel look. In the case of the F-16, it will look like the typical moisture marks.
Hope I answered your question?
David
Old 08-29-2008, 04:31 PM
  #140
FalconWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sweetpea01
Hey sweetpea, what exactly do you need to see??
Are you looking for a stock rudder instl or a mod? I have the stock setup.
Old 08-29-2008, 06:00 PM
  #141
bukeym
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi David,
Thanks a lot for your sugestions. You answered my question in the best way as possible. I have the camouflage F16 1/8 ARF version. However I'm a little scared to use my airbrush on top of it... How thin do I need to set up my airbrush?. Shall I use some kind of cleaning thinner afterwards?....
I do appreciate your suggestions
MURAT
bukeym is offline
Old 08-29-2008, 06:07 PM
  #142
bukeym
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi David
Another question:
How about the the scale look of the rivets?.. Is it still done with an airbrush?..
MURAT
bukeym is offline
Old 08-29-2008, 11:38 PM
  #143
FalconWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rivets are a different story. Unless you have a 1/6th scale kit, I'd stay away from them. On a 1/8th scale, the rivets would truly be very small, you shouldn't be able to see them from 2 feet away!
But in any case, you buy the rivets from www.pro-mark.com. These are dry transefers that you can cut into lines, or bascially any shape you need. You then have to shoot clear coat over them once applied.
As for thining, I use acrylics so it is very different than what most people use. I only thin about 20%, as anything more the paint will run. Since you have the ARF, which has a glossy finish, I'd leave it the way it is. The paint you will have to use for the panel lines is typically flat, so you would need to clear the whole model either gloss or flat when you are done.
Old 08-30-2008, 12:25 AM
  #144
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FalconWings
I'd really like to see the stock method.
Old 10-05-2008, 05:36 AM
  #145
Lasse Palm
Lasse Palm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Swedish AircraftTechnician
Hello
Here is a movie of a testflight on JetLegend F-16 1/8 scale
powered with Jetcat P60.
The movie was taken at LaxĂĄ jetmeeting in Sweden.
I hope that you will enjoy it.
Tomas Eklund
[link=http://www.youtube.com/watch?v=EObUSNkQWrM]Testflight JJ F-16[/link]
Hello JL Guys!
I have about 200 flights! With my Jet Legend F-16 and are very satisfied with the model.
But!
The construction (design) of landing gear should be a little better than it is!!
My solution!
I mounted fixed the landing gear mechanics in front of the carbon fiber duct.
see photos,video!
Video Flight 200 http://www.viddler.com/explore/drhanke/videos/180/
Lasse Palm
Team Jet Sweden
ID:	1046207   Click image for larger version
ID:	1046208   Click image for larger version
ID:	1046209   Click image for larger version
Old 10-06-2008, 04:30 AM
  #146
bukeym
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Lasse,
I am also building my JL F16 and your construction is great inspiration for me . Congratulations... One question : Where can I find the carbon duct that you are using?. Is it home-made?.
Murat Bukey
JL distributor in Turkey
bukeym is offline
Old 10-06-2008, 11:14 AM
  #147
sweetpea01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bukeym
Hi David
Another question:
MURAT
Easy with the F-16. It does not have rivets. Most modern jets are done with fasteners, not rivets.
Old 10-06-2008, 12:06 PM
  #148
Lasse Palm
Lasse Palm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bukeym
Hi Lasse,
Murat Bukey
Murat!
That’s great,if my construction can contribute with something!
The carbon duct is homemade for protect the turbine from grass, crap, stones.
Lasse Palm
Team Jet Sweden
ID:	1046942   Click image for larger version
ID:	1046943   Click image for larger version
ID:	1046944   Click image for larger version
ID:	1046945   Click image for larger version
Old 10-27-2008, 11:45 AM
  #149
xurifle06
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Lasse, what light system did you use in your jet? Looks nice and im thinking of doing the same to my JL f-16. Was it easy to install? Thanks
Rich
Old 10-27-2008, 06:03 PM
  #150
Lasse Palm
Lasse Palm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Rich!
I use the Beacon mini from flugmodellbaue.de
Led combination! white,red,green and lead cover (drop style) Bestell-Nr BMLE
That’s easy to install these lights!
But they are not scale! Because the green and red lead are flashing,
But for me, they are quite Ok!
I think the price is 60 Euro.
Lasse P
Reply
Display Modes
