Bob Cat Copy Falcon 120 Jet
Reply
Old 05-09-2009, 12:37 AM
  #2626
Launch Pad McQuack
Launch Pad McQuack's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Cat Copy Falcon 120 Jet
Airspeed I did not have that issue. All 3 of my batts are under the canopy. One after for the ECU and 2 forward for the radio. However I am running a fairly heavy motor with the Golden West. Your tail weight does sound exsessive compared to the few other Falcons I have seen.
Launch Pad McQuack is offline
Old 05-09-2009, 04:07 AM
  #2627
Jetpilot24
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Airspeed
I too had to add lead to the stab. I don't remember the exact amount but I think it was 8 or 9 oz. I was able to get some in the vertical fins in the cut out that the horizontal goes into. The lead will end up on the vertical post that the hinges for the rudder are into. Be sure to leave enough room to get the stab into the cut out. The rest went into the servo bay. I used one servo on the bottom of the stab with a hatch.
Hope the helps.
Joe
Jetpilot24 is offline
Old 05-09-2009, 06:06 AM
  #2628
tim777jet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, it seems strange that you have problems with balancing. My home made engine will be around 1 lb heavier than your engines. The old version Falcon, was more tail heavy than the new version. I had my ecu and rx batteries mounted on rails as far as physically possible on the old one. The new one has the rx bat by the nose wheel well and ecu bat by the front spar. My nose leg with its extending mechanism is slightly heavier than original one and still i have no problems balancing. tim
tim777jet is offline
Old 05-09-2009, 07:05 AM
  #2629
Jetpilot24
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tim
If you read back thru the post, I am not sure where, the fuse on some of these planes where heavier than others. One person had 2 of them one being white and orange and the other being black and orange. He weighed both and the black and orange fuse was hevier according to him.
I have the black and orange and my batteries are all the way in the back of the fuse. I also used the stock fuel tank for a smoke tank and it is mounted right under the canopy. This may have mad the differance for me. The only thing up in the nose is the air tank. I really did not have problems balancing it I just had to add tail weight.
Joe
ID:	1194910   Click image for larger version
ID:	1194911   Click image for larger version
Old 05-09-2009, 07:41 AM
  #2630
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Airspeed,
Based on the pictures you posted earlier I'd say your main problem is that your engine is mounted too far forward. I'd suggest making a new mount that moves your engine back far enough that the starter no longer sticks into the fuse.
My engine is mounted such that half of its weight extends beyond the back of the fuse. I don't have a real good picture of it, but you can get the idea from these.
Joe
ID:	1194920   Click image for larger version
ID:	1194921   Click image for larger version
joeflyer is offline
Old 05-09-2009, 07:58 AM
  #2631
Jetpilot24
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joe
I like the RedBull color scheme.
Did you use Monokote and the matching Lusterkote spray paint?
Have you flown the new paint job yet?
Joe
Old 05-09-2009, 08:15 AM
  #2632
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Joe,
The covering is Monokote. They do not make a matching paint for metallic blue. I used Duplicolor spray cans from my local auto parts store and was able to come up with a pretty good match.
It flies great, five flights so far.
Joe
joeflyer is offline
Old 05-09-2009, 09:00 AM
  #2633
aquaskiman
My Feedback: (46)
aquaskiman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Airspeed I had to cut a hatch in the bottom all the way back, I put three 2000 mah batteries in it to balance. George
aquaskiman is offline
Old 05-09-2009, 09:07 PM
  #2634
airspeed917
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes thats what I ended up doing, I just extended the cutout on the bottom of the fuse to install the batteries, then I just made a longer hatch to cover the whole opening.
also I must of mis-measured or something went wrong when I measured the 13" for the CG,, I re-measured it with a metric tape at 330mm and I was about 1/2 inch to far back
I went from having to add 11oz to 7oz. So while the jet was on the stand I opened up two small holes in the bottom of the rear stab and I was able to glue the lead in there.
It balanced well just slighty tail heavy,, that should equal out when I fill the UAT. Well she's ready for her maiden,, but I dont think my wife will appreciate me going tomorrow...
I wish it was Fathers day instead, oh well it will have to wait till next weekend.
yes
airspeed917 is offline
Old 05-11-2009, 01:22 PM
  #2635
TURBINATOR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had twelve oz's of lead taped to the stab with my Airpower retracts, had an in-flight air leak and had to belly it in on it's maiden flight. Went back to the Springair's and had to remove 6 oz from the tail to re-balance. What a difference in weight between retracts.
Hey Joe,
Of all the Falcon color schemes I've seen to date. Yours is by far the best yet for me. Nice job once again on it. I wish I had the motivation to do mine up like that.
TURBINATOR is offline
Old 05-11-2009, 02:43 PM
  #2636
aquaskiman
My Feedback: (46)
aquaskiman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jramirez, whaat didn't you like about the air power? I have heard great things about there gear. George
Old 05-11-2009, 02:52 PM
  #2637
tim777jet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, have you seen this guy with a pulse jet fitted, http://www.youtube.com/watch?v=A5Rqh...eature=related
Old 05-11-2009, 04:33 PM
  #2638
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Jeff. Since this is my second Falcon I didn't want orange and white again. Ten guys (no kidding) in my club so far have bought these. I'm sure a few will never be converted but we all had to come up with different schemes so we'll be able to tell them apart. Right now there are two flying and two about to maiden. It should be an interesting summer.
Joe
joeflyer is offline
Old 05-12-2009, 10:32 AM
  #2639
TURBINATOR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: aquaskiman
Aquaskiman,
I had the springair's in my original Falcon which worked flawlessly for 80+ flights. I lost the plane to dumb thumbs. I bought my second Falcon with the Airpower retracts already installed by another gentleman. He was having problems with air leaks on set-up and got frustrated with it so he sold it to me. I fussed with them for many weeks, re-plumbing, removing leaking quick connects etc, etc. I finally got them working or so i thought. Then had them not come down on the maiden flight which caused me to belly in a brand new plane. I was not happy to say the least. Had to repair broken servos, flaps, etc. So i pulled them out not wanting another mishap. The springair's are air up spring down which gives me confidence again. Maybe i just got a defective set, but i even put wire around the connectors and still had air leaking. I have had many different types of air operated retracts and never had the issues i had with these.
Jeff
Old 05-12-2009, 02:21 PM
  #2640
airspeed917
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, Is any one flying a Futaba 10C with the F6014FS rec in their Falcon,, Just wondering if there were any issues.. I did have a problem getting the Hitec digital rudder servo's to work with a Y connection though. They worked one at a time ok, but chattered like mad with the Y... I know about the low signal voltage on channels 3-14..
I installed the electro dynamics amplifer buffer and that solved the problem... I have the ailerons on a Y connection with no issues, channels 1 and 2 put out the full 3 volt signal.
I was just wondering if anybody had expierenced any inflight issues.
Old 05-12-2009, 03:41 PM
  #2641
airspeed917
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres a few more pics,,, she's ready to fly.....
ID:	1196927   Click image for larger version
ID:	1196928   Click image for larger version
ID:	1196929   Click image for larger version
ID:	1196930   Click image for larger version
ID:	1196931   Click image for larger version
Old 05-13-2009, 04:15 AM
  #2642
jet junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Home made Trailing link struts
called em Pro Strut!
made for the Falcon! who wants some?
jet junkie is offline
Old 05-13-2009, 04:57 AM
  #2643
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jramirez
Aquaskiman,
Jeff
we sold a lot of the airpower units and all have worked ok for the job..
for the falcon we use the 250 series .
a few things i would like to mention :
1. use correct tubing no play or they WILL leak.
2 . bearers must be strait if not the frames will bend and cause friction and your gear will not work ok..
3 . trunion blocks , we see a lot of customers really over tighten them with the result that thr trunion blocks will bend and crack.
the bend also will cause the trunion axle to bend ,and cause frinction.
4. a good tip is to use green zap ca and put it on your oleo,s , slide them in the trunion blocks and Fasten them the ca will settle.
or even better use Locktite 648 this is a sort of glue we use to set also the oleo,s..
if you have any questions about them mail us
digitech is online now
Old 05-18-2009, 04:47 AM
  #2644
Mavrik!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pic of my Falcon 120 Rabbit powered on the weekend flying at Maitland NSW Australia.
Unlimited vertical and very short take off!!!
17 flights now. Have my eye on another project so may be up for sale shortly less turbine!!
Cheers,
Mav
Mavrik! is offline
Old 05-21-2009, 04:32 PM
  #2645
RAPPTOR
My Feedback: (41)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BEST MOTOR FOR GLOW FAST!!!!!!!!!!!!
RAPPTOR is offline
Old 05-24-2009, 11:00 AM
  #2646
noray1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Airspeed.
I also have the 10C but have not set up yet.
Where are the Electro Dynamics Amps available?
Would like to know in case I need.
Ray
noray1 is offline
Old 05-24-2009, 11:07 AM
  #2647
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.electrodynam.com/rc/index.shtml
joeflyer is offline
Old 05-24-2009, 11:12 AM
  #2648
noray1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Launch Pad.
Where did you find the interior?
Ray
noray1 is offline
Old 05-24-2009, 11:19 AM
  #2649
noray1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Joe...
noray1 is offline
Old 05-24-2009, 12:47 PM
  #2650
noray1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Airspeed.
I also have the 10C with the 14FC Rec.
Had a problem with Y Harness on flaps &Rudders.
The Y harnesses I used had the buffers built in (JR Products)
I made up Y Harnesses without buffers and that solved the problem you described.
This is my setup...
Ch-1 Ail. #1
Ch-2 Elv. 2 servos with JR Match Box
Ch-3 Thro
Ch-4 Rud With Y Harness
Ch-5 LG Retracts
Ch-6 Flaps With Y Harness
Ch-7 Ail. #2
Ch-8 Nose Gear Steering Turns off with retract Sw.
Ch-10 Breaks
This leaves a spare channel - #9 which could be used for retracts FreeingCh. 5 for flaps or rudder.
Hope thishelps.
Ray
noray1 is offline
Contact Us Archive Advertising Cookie Policy
