Bob Cat Copy Falcon 120 Jet
Old 11-19-2009, 05:00 AM
  #2901
Strykerstriker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Cat Copy Falcon 120 Jet
ORIGINAL: BaldEagel
Dave
Had a look at that, they look just like the Digitech disc brakes if so they aren't that unique LOL the only thing I would question is if you are going to fly off grass, in which case I would recommend going for the Digitch trailing struts rather than the Dreamworks Olio's, the traling struts transfer much less stress into the fixing points and wing on bumpy ground the Dreamworks Olio's can only disipate any bending load straight into the airframe.
Mike
Do you have a link to the digitec??
I've tried the oleos and have problems on our rough grass strip[&o] would like to try trailing links....
Strykerstriker is offline
Old 11-19-2009, 05:03 AM
  #2902
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This link will take you straight to the Falcon set: http://shop.digitech-turbines.com/pr...31rrh07cdmtqh7
Mike
BaldEagel is offline
Old 11-19-2009, 05:32 AM
  #2903
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ticketec
Thanks Baldeagel, it will be good to see a comparison.
This is the dreamworks gear i am talking about. It's all airpower stuff, which according to the info, included disk brakes..
http://dreamworksrc.com/catalog/prod...oducts_id=1382
dave
Dreamworks struts = 99 grams
Digitech struts = 100 grams
Intairco wheels and brakes = 131 grams
Airpower wheels and brakes = 97 grams
It looks like Dreamworks have now gone over to the same brakes as Digitech i.e. Airpower so its only the comparison between the struts that's worth making, don't forgett these are the comparitive weights of a Boomerang Elan set of gear, I would think that now Dreamworks have changed their brake and wheel supplier the comparitive weights are about the same, so its only the difference between straight Olio's and trailing link struts that your choise will be based on, personaly I will never use straight Olio's again, its a bit like upgrading to Kero start once you have done it, you will not go back.
Mike
Old 11-19-2009, 05:38 AM
  #2904
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BaldEagel
Dave
Mike
All i have ever seen myself is grass strips in OZ. well i have seen pic's of some jet meet's were they have proper runways to fly from, but that's rather uncommon
I spoke with a number of the jet guys after our last meet here and next to no body flew with trailing link legs. all had straight legs. they said no dramas flying of grass especially if you can land nicely Been flying for a while now so i might just be ok.
I think Digitech also sell airpower items so they might very well be the same thing. seeing as they both use the airpower retracts, the only difference is the leg's them selves, in which case the digitech offering is all that more expensive, or so i thought until i found this:
http://dreamworksrc.com/catalog/prod...oducts_id=1291
They also pro-lynx gear (legs), different wheels and brakes ( looks like your intairco items??) for $599, compared to digitech which converted into USD is $665. not sure if the digitech stuff at that price comes with airline, valves, etc..
dave
ticketec is offline
Old 11-19-2009, 05:41 AM
  #2905
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the figures, so one can make an assumption that if they are running the same brakes and retracts, and there is only 1gram of weight difference per leg, that the price and quality of the items is the only major differences.
dave
ticketec is offline
Old 11-19-2009, 05:45 AM
  #2906
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One other thing to take into account is that Dreamworks are Imperial and Digitech are Metric so Allen keys for one will not fit the other, I find that very annoying having to have two sets of tools just to accomadate an outmoded measuring system. TVFIC
Mike
Old 11-19-2009, 05:50 AM
  #2907
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BaldEagel
Mike
ticketec is offline
Old 11-19-2009, 10:21 AM
  #2908
resjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the paint is a polyester base,good stuff but not cheep here is a link to R-M paint www.basfrefinish.com
resjets is offline
Old 11-19-2009, 10:31 AM
  #2909
gio
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there, Can someone tell me what size of main wheels are used in the falcon, What I have now are two 2.75 and I dont now iff they are to big.
I dont have the plane yet, thats wy I am asking.
gio is offline
Old 11-19-2009, 12:34 PM
  #2910
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 70mm mains and 57mm nose wheel on mine.
Mike
Old 11-19-2009, 12:51 PM
  #2911
sweetpea01
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok......I seriously going to start the build on this plane. Actually last night I tore the covering off the wings and I have the nose gear installed but not the steering, so I'm at least started.
Here is what I'd like all you Falcon 120 flyers to post so its all together. I'd like to see a condensed section so its all right there for me to find. If I have specific questions I'll PM (if you are willing to answer).
1. Former mods to fit fuel tanks
2. Canopy attachment methods, both stock canopy or the stronger aftermarket one
3. If you did a cockpit, show that
4. Mods to the fiberglass section that holds the turbine
5. Bracket system to hold the turbine (if anyone sells one I'd be willing to discuss) and how the degree of downthrust
6. If you made mods to the wings (for me I plan to reglue formers and install CF tubes, then cover the holes and fiberglass the wings)
I think having a few posts of these 6 things will help me (and others) have all that info at a quick glance. I plan to do the same with mine as well as I build it over the next few weeks.
sweetpea01 is offline
Old 11-19-2009, 02:35 PM
  #2912
gio
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to page 52-57-61-68-69-70-72.
gio is offline
Old 11-19-2009, 04:27 PM
  #2913
new2jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: sweetpea01
go to page 39
ID:	1317047   Click image for larger version
ID:	1317048   Click image for larger version
new2jets is offline
Old 11-19-2009, 05:41 PM
  #2914
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do what most others have and trawl through the thread, you will find what you want.
Mike
Old 11-19-2009, 05:46 PM
  #2915
sweetpea01
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been going through the thread. I just figured someone who already built one and is flying it could post in one spot the 6 most important parts of building this plane for a turbine. No big deal. I'll do it when I have mine done. It only helps those who will be building it in the future. Kinda like a mini instruction manual.
Old 11-19-2009, 09:47 PM
  #2916
derrickxp8103
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres my super highly modified Falcon 120se. Its awsome !!! Ultra strong airframe !!! All composite airframe. Automotive paints.
I have 5 flights with a P-120. Super fast !!
125oz total fuel with wing tanks.
!!!!! WAIT TILL YOU SEE MY NEXT PROJECT !!!!!
ID:	1317214   Click image for larger version
ID:	1317215   Click image for larger version
ID:	1317216   Click image for larger version
ID:	1317217   Click image for larger version
ID:	1317218   Click image for larger version
ID:	1317219   Click image for larger version
derrickxp8103 is offline
Old 11-20-2009, 04:07 AM
  #2917
Aussie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike, my Falcon120 set from Dreamworks are definately trailing link and look very similar to the Digiteck ones. Dave, I'm using Trim Aircraft brakes and wheels, which are very well made and also half the price of similar quality other brands. As a guide my total undercarriage solution cost me about $650 AUD
http://dreamworksrc.com/catalog/prod...oducts_id=1305
http://www.trimair.com.au/index2.html
Aussie1 is offline
Old 11-20-2009, 05:02 AM
  #2918
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EDIT:
Old 11-20-2009, 05:03 AM
  #2919
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ticketec
dave
This post shows them as Olio's and not trailing links, I can only comment on what is shown to me.
Mike
Old 11-20-2009, 07:32 AM
  #2920
Woketman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Derrick, that paint job is too cool!!!! VERY NICE!
Woketman is offline
Old 11-20-2009, 08:14 AM
  #2921
gio
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: derrickxp8103
What are the trows you use one the ailerons and elevator and what % of expo do you use on them, I ask because I am working on the Falcon and I also be mounting a p120.
Thanks.
Gio.
gio is offline
Old 11-20-2009, 09:08 AM
  #2922
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Derrick that Falcon looks great well done.
Xairflyer is offline
Old 11-20-2009, 10:36 AM
  #2923
derrickxp8103
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have about a .65 inch up and down on the ailerons and .85 inch on the elevator. Max flaps is 85 degrees. 10% expo on the elevator.
I think it weighs somehwere around 20 lbs dry. Then it holds 125oz of fuel.....so all up weight might be near 26.5lbs with fuel.
Vertical is excellent with the P-120. I would say speed is around 200mph.
I use A123 for the receiver and ECU.
I balance it 13 inches back from the inboard leading edge .......level plane, no fuel.
Going to put a Titan SE on it for next weekend....... should be cool !!!
I still have fuel cells if anyone needs them.
Derrick
Old 11-20-2009, 10:37 AM
  #2924
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Derrick
Nicely done, I see a Fromeco Kodiak switch in your install, are you using A123's, if so how did it ballance with that extra weight at the back?
Have you verified the speed of it yet?
Mike
Old 11-20-2009, 11:58 AM
  #2925
derrickxp8103
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I use A123's.........they are awesome...period!!! I never thought A123's would work so well. I use a CellPro 10s charger.
I didn't have to add any wieght anywhere for it to balance. Everything came out perfect. Both ECU and radio packs are in the nose.
Not sure what you mean...extra wieght in the back?
As for the speed......I know for sure my Euro, powered by a Titan SE, on a good day is around 200mph...... verified by an on board GPS. It seems like the Falcon is a little faster than my Euro.
I will put the GPS in the Falcon 120 one day just to verify. We shall see.
Derrick
Contact Us Archive Advertising Cookie Policy
