Bob Cat Copy Falcon 120 Jet
Reply
Old 02-11-2010, 12:59 PM
  #3251
gio
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Cat Copy Falcon 120 Jet
More of the canopy.
ID:	1376499   Click image for larger version
ID:	1376500   Click image for larger version
ID:	1376501   Click image for larger version
gio is offline
Old 02-11-2010, 03:33 PM
  #3252
sweetpea01
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
interesting method.
sweetpea01 is offline
Old 02-11-2010, 05:17 PM
  #3253
tim777jet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Gio, another different and great idea for the canopy latch. Ref the servo in the tailplane, I found a standard size servo just fits inside the tailplane without having to increase the depth or profle of the tailplane at all. I see you are using a plate on the bottom, not sure how much that will disturb the airflow over the elevator. I did find that the Newer Falcon requires a little more down elevator travel than the older model did, to get the same responsivness, despite the CG being in the same place,strange.
Ref Flaps, I do not use anywhere near the travel of the flaps shown in the above pictures and I find they slow my model down really well. I think you will find them really effective. Cant see in your picture, the position of the servo arm, when the flaps are fully deployed, but best to make sure the servo arm is nearly in line with the control rod that operates the flaps when fully down, this will take the load off the servo and reduce battery drain.
Ref the engie mount, yes the engine mount is not the best design in the world, but it is pretty strong and will take the punishment for many many flights, before showing signs of fatigue, typically around 60 or so flights, depending on how many hard landings you do, in fact I havnt been home too much for around 12 months and still havnt beefed mine up yet, with around 60 flights on her, still no sign of fatigue yet, maybe 61st flight though, best get the glue out.
Another item i would like to add to the model, just for fun, is an airbrake on the top of fuse, like the fighter jets, I think it would interfere with airflow over the tailplane and might not be the best idea, but worth a try, would look pretty cool, I think a nice high altitude test in landing config would be neccessary though. I thought of a small door pneumatic ram, operated when flaps selected to full down to lift up a simple door hinged at the front. When you think about it we have as many, or even more operating hardwear on this simple model, than some more exotic models like the F15, incredible really. Thats what i like about the model, it is very versatile and simple, but can be operated wih a really high spec and many design changes. The guy who converted his to a float plane and the guys who have removed the booms and tailplane and electrified the models have done some excellent work. I always look forward to checking this forum to see what is comming up next, full marks to everyone who posts.
Cheers Tim
tim777jet is offline
Old 02-11-2010, 07:19 PM
  #3254
noray1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hay Dave.
I have wheel well liners. They have a dia. of 2 7/8" (7 centimeters) and 1 3/8" (3.4 centimeters) deep.
I also have replacement canopy
Contact me @ norray9963@att.net
Ray
ID:	1376694   Click image for larger version
ID:	1376695   Click image for larger version
noray1 is offline
Old 02-13-2010, 06:15 AM
  #3255
haisanjafri
haisanjafri's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello guys,
my friend just bought this Nitro Models Super Falcon 120 but he he couldn't receive its instructions manual from the seller.
Can you please guide the exact and recommended center of gravity (CG) for this model?
thanks,
haisan.
haisanjafri is offline
Old 02-13-2010, 11:44 AM
  #3256
fireblade5437
fireblade5437's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haisan
Cof G for the Falcon 120 is 330mm/13" behind the leading edge measured at top wing centre line: as per manual.
Alan
fireblade5437 is offline
Old 02-13-2010, 12:03 PM
  #3257
haisanjafri
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks much Alan, now we may test flight with peace tomorrow..
Old 02-27-2010, 06:19 AM
  #3258
Aussie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: gio
More done on my Falcon,ruder servo and elevator servo.
Next will be the canopy.
Hi all, haven't been on here for awhile, but still enjoy catching up with this world wide group of Falcon flyers! Gio, I went the small turbine, light weight airframe approach with mine, because I just feel that light models fly better. I use a small PST600 and the total weight is around 14lbs with all the mods done. My tank is a 3 litre juice bottle which gives about 14 minutes of flat out flying. I always think about landing after my timer goes off at 8 minutes, though. I think you need to watch your model weight, as you appear to be building it very strong (heavy?). It will go absolutely ballistic with a P120, though! One down side of useing a small engine is the model turns out nose heavy. I now have 1/2lb of lead bolted to the underneath of the engine mount. This is with everthing put as far back as possible.
Aussie1 is offline
Old 02-27-2010, 07:54 AM
  #3259
tim777jet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Aussie, great you are still enjoying the Falcon thread, a little slow just recently. Ref the lead weight, I would rather upgrade my elevator and rudder servos, to heavier or metal geared servos, or add the weight construvtively in strengthening the tailplane or something at the rear. There is a massive lever at the tail, so not much weight would be needed to rebalance, rather than carrying dead weight.
I did manage to get a few flights in while i was home a week or so ago. Temp was 4 degs C, and true to form my ECU throttle input failed again. Had to shut down and fit a 1.5 volt AA battery in my home made internal ECU heater, next and subsequent flights perfect. Plane flew really well and plenty of power on the cold day. Grass was really wet and muddy, didnt realize that half way down the runway, it was completely water logged and flooded. I was heavy with a full tank of smoke fluid and just a s she was getting light, hit the water. The plane disappeared in a wash of water and she slowed dramatically, I kept the power on and she crawled off the ground. No damage and the engine kept running throughout, amazing. On subsequent flights i kept to the side of the runway and didnt carry smoke fluid, she lept off every time, well pleased.
Another fellow modeler had recently built a Hawk with a large jet in stalled. He had 5 flights and decided to sell it due it being a pig to slow down and land. Our field is quite short and he was there watching the falcon fly. He couldnt believe how slow she was on landing and in general just how good it flys.
chers tim
Old 02-27-2010, 09:08 AM
  #3260
gio
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all, I slowed down a bit on the Falcon, but I am still working on it.
I finished sheeting the wings and they all covered up, and now the big job is on the way,glassing everything.
About the weight of the plane , here in Curacao Caribbean we fly in 15 to 20 nots wind so the plane will fly better on the heavy side.
I will put more pic later on the progress of the plane.
Gio.
gio is offline
Old 02-27-2010, 10:09 AM
  #3261
derrickxp8103
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine wieghs around 26 lbs with fuel
Fuel capacity is about 1 gallon.
The Falcon has the same dimensions as the BVM Bobcat and wieghs about the same as the Falcon with fuel.
My Falcon flys very well.
Derrick
derrickxp8103 is offline
Old 02-27-2010, 05:16 PM
  #3262
Aussie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: derrickxp8103
Derrick
Derrick, I had no idea that this plane has such a huge flying weight range. It just goes to show that it has a really nice wing, plus I reckon the big flat bottom fuselarge helps with lift, much the same as the F15. Tim, I am using metal geared, hi torque Hitec servos throughout the plane and have 2 1500ma lipo packs in the rear of the fuselarge. I was reluctant to put the lead on the booms, because a slightly firm arrival would put alot of stress on the boom attachment points. It's still a light model and flys like a overpowered powered glider!
Aussie1 is offline
Old 02-28-2010, 07:11 PM
  #3263
mnsi
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello,
I just started construction on one of these Falcons and I noticed that the small aluminum spar tube is missing. Can anyone tell me the diameter and length of this tube, I am going to install CF tubes.
Hey Derrick, I read in one of the later post you made that you mentioned you did not need formers (I think you said that) because you re enforced the fuselage with fiberglass, How heavy was the cloth you used and how many layers if you do not mind me asking.
Thanks, Joe
mnsi is offline
Old 03-01-2010, 06:40 PM
  #3264
atomicx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Iglassed my current falconwith 1.4 oz cloth and coated with gelcoat. I previously builta falconwith 1/2 oz cloth but it actually ended up being heavier by the time Isurfaced it smooth enough for paint. Icompiled my build processinto a downloadable .pdf posted a few pages earilier: http://www.rcuniverse.com/forum/fb.asp?m=9287830. There is some helpful information there if you are interested in doing a composite build.
atomicx is offline
Old 03-01-2010, 06:47 PM
  #3265
noahb
My Feedback: (67)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Atomix, what kind of fittings are those on your tray where you put the kero in, gas and smoke?
noahb is offline
Old 03-01-2010, 06:54 PM
  #3266
atomicx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I purchased those from dreamworksrc.com. I have been really happy with them. They are lightweight and easy to use, although a touch pricey. Here's a link: http://dreamworksrc.com/catalog/prod...roducts_id=962
atomicx is offline
Old 03-01-2010, 06:56 PM
  #3267
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And in the Europe you can get them from Sandor at Digitech Turbines.
Mike
BaldEagel is offline
Old 03-01-2010, 07:08 PM
  #3268
mnsi
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Atomix,
Did you also re glass the outside of the fuselage?
Thanks, Joe
mnsi is offline
Old 03-01-2010, 07:31 PM
  #3269
atomicx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I didn't reglass the fuselage.I just stripped all the paint down to the fiberglass. Once the plane was assembled I coated the entire surface with a thin gelcoat, then painted. I did however add a 3 inch strip of 6 oz carbon fiber cloth down the length of thefuselageon both inner sides. They were epoxied in with the same West Systems epoxy used in the fiberglass.The weight was negligible and added a lot of rigiditty, especially around the canopy.
atomicx is offline
Old 03-01-2010, 07:35 PM
  #3270
mnsi
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, Thanks
I downloaded your PDF and I am going to go with the same approach on the wings and booms. I think I am going to have to re enforce the aft inside part of the fuse, I just purchased one of the newer Falcons and the glass work is paper thin and horrible looking seams, much different in quality than the first one I bought a few years back. Very familiar with the West systems, I use them to repair the yatchs I service here in Florida (very good stuff).
Thanks again.
P.S. Derrick I just recieved the fuel tank, Top Notch quality man!! Thanks!
mnsi is offline
Old 03-03-2010, 11:42 AM
  #3271
videopilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All,
Just starting a Falcon 120 as my first jet with a Wren 54, spent hours reading this thread, great info!
Regarding fuel tanks, if using a LENOR or COKE bottle would it be beneficial to fibreglass the bottle for extra durability or a waste of time?
Cheers, Paul.
videopilot is offline
Old 03-03-2010, 12:16 PM
  #3272
mnsi
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You should take a look at Derricks tanks, they are very reasonable considering the quality and fit. I believe he has an ad running in the for sale section under the jets page
mnsi is offline
Old 03-03-2010, 01:06 PM
  #3273
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a waste of time. 2 liters will give you about 7 minutes flight time.
Joe
joeflyer is offline
Old 03-04-2010, 04:54 AM
  #3274
Aussie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: joeflyer
Joe
I'm using a 2.4 litre juice bottle plus a 300ml header tank and this gives around 12-14 minutes on my PST600. It moulds to the fuselarge really well and sits right over the C of G. Plus it comes with a handle for easy removal! Pic 3 shows where the c of g is in relation to tank position (black line on tank). It is almost at the mid point of tank, which is ideal because the trim does not change much as fuel is burnt off. I have tried many different types of PET bottles and this one is by far the best. I rarely fill it completely, as I find a 8-10 minute flight on a jet is plenty for me for one flight.
Hey Admin, the new Beta Multi-file upload bar works great!
ID:	1390880   Click image for larger version
ID:	1390881   Click image for larger version
ID:	1390882   Click image for larger version
ID:	1390883   Click image for larger version
Aussie1 is offline
Old 03-06-2010, 08:09 AM
  #3275
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I droped a tool onto my canopy in my hobbyroom, cracking it.
Just got it bondo`d and painted. Looks ok...at lest different to the stock color
SJN is offline
Contact Us Archive Advertising Cookie Policy
