If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 133 of 198 FirstFirst ... 3383123131132133134135143183 ... LastLast
Results 3,301 to 3,325 of 4928
  1. #3301
    Join Date
    Jan 2005
    Sao PauloSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Bob Cat Copy Falcon 120 Jet
    Hi Dave,
    Thanks for watching and for the tip.
    You have a very accurate vision. You must be right, I need do add more down thrust. I have 6 degrees, but will change to 8 degrees. Thanks to remember me that. I was so anxious and with so much adrenalin that I forgot some plane behaviour to be corrected. It was my maiden on jets too.
    Its CG is also behind the manual position. ItΒ΄s 355 mm from leading edge with only UAT filled. I felt its elevator too sensitive.
    Now it will go back to the bench and I will do the following changes:
    1) More down thrust;
    2) Bring CG forward to 330mm;
    3) Install wheel brakes;
    4) Change fuel tank from 2L to 1.5L coke pet. I flew 5 minutes with 2L pet and landed with a little more than half tank.
    Ricardo
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #3302
    Join Date
    Jan 2005
    Sao PauloSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ttt
  3. #3303
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice flying Ricardo [sm=thumbs_up.gif]
    Good video.
    Sonnich Johannesen
  4. #3304
    Join Date
    Dec 2001
    Plymouth, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Six degrees should be the right amount of down thrust for that engine. First, I suggest that you put the CG at 330 mm. and set your elevator trim for straight and level flight at your normal flying speed. Then adjust the down thrust if needed.
    Joe
  5. #3305
    Join Date
    Jan 2005
    Sao PauloSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Sonnich Johannesen and Joe!
    Joe,
    I used 6 degrees based on your past posts. I followed many tips from you and have much confidence on your experience.
    Dave noted a little up/down instability on my Falcon but he did not know I had a rear CG, so you may be right, it may be CG, may be down thrust or both things.
    So I will do one change at a time, first CG and then down thrust if needed.
    Your Red Bull FAlcon is a state of the art!
    Ricardo
  6. #3306
    erbroens's Avatar
    Join Date
    Nov 2003
    Curitiba, Parana, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Excelent flight Ricardo, parabens!
    did you shut off the turbine at landing?
    Enrique
  7. #3307
    Join Date
    Jan 2005
    Sao PauloSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi, amigo Enrique!
    Yes I did shut off the engine at landing. I did command a shut off after touching but, as turbine has a delay on shutting off, the engine only stopped middle past runway. I did that cause turbineΒ΄s idle was producing much thrust and the plane couldnΒ΄t stay stopped. Also did not have brakes. So, for safe, we decided to shut it on landing.
    To try to solve that "problem" we lowered turbine idle rpm from 45000 rpm to 40000rpm, but it still couldnΒ΄t stay stopped. I did this with some fear, but the turbine was reliable all the time. I intend not to do that anymore and install brakes.
    Abraço
    Ricardo
  8. #3308
    erbroens's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, there is always residual thrust in any turbine so brakes are needed in jets, in both main wheels. You can use a simple on/off switch air valve with plenty of silicone grease on the wheel hubs for excelent results or a proportional jettronic type valve for smooth stops as well.
    Again, congrats on your flight and specially for the landing without brakes!
  9. #3309
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lowering the turbine idle can result in a low speed compresser stall and flame out, it you need to do that again I suggest you put a mix on with your retract valve to keep the idle at the manufactures settings whilst in the air and having the lower idle only available on landing. Do remember to re-teach your ECU the new settings.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  10. #3310
    Join Date
    Jan 2005
    Sao PauloSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Enrique and Mike,
    Your tips are really helpful. I will choose the cheapest brake system (on/off switch with grease on hub) and hope I will not need to low the idle anymore. If itΒ΄s still needed I will do as suggested by Mike, thatΒ΄s a really good idea.
    Ricardo
  11. #3311
    Join Date
    Jul 2003
    Brisbane, QLD, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey guy's
    I have been working away at my Falcon120 and she is getting closer to being finished. I thoguht i better put someone in the office so here is my slapped together cockpit. I just made up some Vac from molds to keep the weight down. Not all that easy to see with such a tinted canopy but I need the nose weight so why not?
    dave
ID:	1397744   Click image for larger version.
ID:	1397745   Click image for larger version.
  12. #3312
    erbroens's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, I donΒ΄t think that is a good idea to use a low idle landing mix on a turbine plane. The residual thrust reduction will be very small and the spool up time and turbine reliability will be worsened at landing, when it is most needed in case of a go around. Worst case scenario would be a flameout, based on how difficult is for the turbine go from idle to full power specially in hot and humid conditions and at some altitude, like the one I presume Ricardo is flying (Sao Paulo).
    I know it is a extreme example but interesting anyway: in carrier landings the pilots gives 100% of throttle just before touchdown in case he didnΒ΄t makes the wire so he can do a safe go around.
    So I think that having a good pneumatic brake system, with grease or a smooth stop valve and a reliable spoolup idle is a better option for our models.
  13. #3313
    Join Date
    Nov 2007
    West Palm Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ill take one mate.
  14. #3314
    Join Date
    Dec 2001
    Plymouth, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ricardo,
    Looking at your video it doesn't appear that you're using a lot of flap. I use about 45 degrees, and some guys use more. By using the flaps as air brakes you need more throttle on your approach and you have very good control over your speed and decent. The plane is very stable and it is possible to come in and land at almost walking speed. Try more flap instead of lowering your idle speed.
    Joe
  15. #3315
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As I said it can lead to a low speed compressor stall and flame out, so not a good idea, just an idea to get over a problem, in fact I have my turbines set up the exact opposite i.e. higher idle with gear up, gives an amazing responce time with the 120SX I would go as far as saying as fast as any IC I have.
    As Joe says use more flap, anything beyond 45 deg will act like an airbrake and will need higher throttle to keep flying, my flaps go to 90 deg and the control on landing is excellent, but then I have reflexed ailerons as well all controled on a side slider to give me something else to play with, first half of the slider gives me flap only up to about 45 deg and the second half gives me up to 90 deg of flap and about 30 deg of up aileron, fun on slow fly byes as the turbine is still in the upper range and once you put the flaps and things away the acceleration is instantainous, well it impreses me.
    Mike
  16. #3316
    Join Date
    Nov 2004
    Provo, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey atomicx I bought one of these a while back. havent gotten to building it yet but i live in provo and would like to see what you did on yours if you dont mind. would you please drop me an email at beisele@hotmail.com? thank you
  17. #3317
    erbroens's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BaldEagel
    Mike
    Perfect.[sm=thumbs_up.gif]
  18. #3318
    Join Date
    Jan 2005
    Sao PauloSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think I have 40 degrees or almost that.
    I loved your flap configuration, Mike. I think I will copy it, if you donΒ΄t mind... just donΒ΄t know if mine can reach 90 degrees, but if I get 60/70 is also good in a crow mix. I will try.
    Added to the right CG and a wheel brake system, it will be still better.
    Dave, nice job on that cockpit. I had a rear CG issue on mine.
    I installed everything less batteries more to the rear cause I thought it would need more weight on the tail. But that was a mistake in my falcon configuration. When it came time to measure CG to install batteries and switches, I could not reach the correct position even with 3 batteries near the nose, over the nose LG. So I had to move the pump and the UAT more to the front and only got CG at +/-350 mm. Now I will install brakes but its little extra weight wont correct CG, so I may unfortunately add some weight in the nose. Anyway it will still fly lighter cause I will change tank and save +/-500g of fuel weight.
    Ricardo
  19. #3319
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ricardo
    On the flaps, the taper on the bottom side of the flap does not allow 90 deg flap movement as standard, however if you use the left flap on the right side and visa versa, turn them upside down and the straight edge of the underside of the flap allows 90 deg movement when installed with Robart pin hinges.
    Mike
  20. #3320
    Shaun Evans's Avatar
    Join Date
    Jan 2002
    San Diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey,
    This thing is CRAZY!!! LOL, I had no idea how literally you guys meant "just pull on the bulkheads and they'll pop out..." How was this thing ever supposed to fly on glow power with the engine shaking everything?? It's amazing...
    Shaun Evans, Builder/Pilot
    Private Pilot
    Actor/Director/Singer
    AMA Contest Director #8574
    Founder/Artistic Director, California Youth Conservatory Theatre
    Ultimate Jets West Coast
  21. #3321
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't think anyone on here was under any illusion that these things are made to a very low standard, but personnaly I think it was very good of the manufacturer to make it easy for use to remove the suspect parts. LOL
    Just a heads up, when you install the UC in the wing, don't screw them on too tight, the bearers will fall out.
    Mike
  22. #3322
    Join Date
    Apr 2008
    Carlsbad , NM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: YellowAircraft
    Hey,
    This thing is CRAZY!!! LOL, I had no idea how literally you guys meant ''just pull on the bulkheads and they'll pop out...'' How was this thing ever supposed to fly on glow power with the engine shaking everything?? It's amazing...
    I think it would have been more of a problem if they would have put the bulk heads in a plastic bag.
    I looking for a carbon fiber wing spar. were do i get one.
  23. #3323
    Join Date
    Nov 2007
    West Palm Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  24. #3324
    Join Date
    Apr 2008
    Carlsbad , NM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ha! been pulling my hair out for nothing , thanks!
  25. #3325
    Join Date
    Nov 2007
    West Palm Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No problem.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
