Bob Cat Copy Falcon 120 Jet
Old 03-15-2010, 02:19 PM
  #3326
madfreestyler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Cat Copy Falcon 120 Jet
Hey Chaps,
Anyone else using the digitech ready built u/c set. I was wondering if you had to modify the mains bay to accomodate as mine seem to be short. Is this the norm or have i got the wrong ones?
madfreestyler is offline
Old 03-15-2010, 04:43 PM
  #3327
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No you have the right ones, they are shorter than the pusher prop set up as the excess length of leg is not needed to clear the prop, as you are in the UK go to Sainsburys and buy a small Steak and Kidney pudding the dish it comes in is the right size to make a wheel well, bonus is that Epoxy does not stick to it very well so it is removable and they also make a good mixing pot, just let the epoxy set and flex the pot and out it pops, if you go back on the thread you will see how I did it.
Mike
BaldEagel is offline
Old 03-17-2010, 01:51 AM
  #3328
atomicx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today was an absolute beautiful spring like day so I just had to get my Jet in the air. Ihad one camera mounted in the belly of the plane and another strapped to my forehead. I cut together a quick edit and posted it here: http://www.vimeo.com/10226417 So much fun! This was my first flight with onboard video. Great to see from the plane's perspective. This was also my first flight with my new JetCat P-80 SE (replacing the P-60 SE). I am totally thrilled with this new engine. 22 lbs of thrust is just perfect for my build and hardly drinks any more fuel.
If you want more details on my plane I posted a build .pdf earlier in this thread: http://www.rcuniverse.com/forum/m_59...tm.htm#9287830
Happy flying!
Christian
atomicx is offline
Old 03-17-2010, 09:38 AM
  #3329
Woketman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow! The on-board video was EXCELLENT quality!!! What camera was used, Christian????
Woketman is online now
Old 03-17-2010, 12:56 PM
  #3330
atomicx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. The onboard camera is a SONY MHS-PM1. I got mine last year from newegg: http://www.newegg.com/Product/Produc...2E16830179222R.Sonynow has a newer version with image stabilization: http://www.newegg.com/Product/Produc...82E16830179265. They are lightweight, record full 1080P, and most importantly have a rotating lens!
Christian
atomicx is offline
Old 03-24-2010, 02:38 AM
  #3331
Aussie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A bit off topic, but after flying my Falcon the other day, I decided to increase the thrust slightly on my PST600, while back at my home. That's when the trouble started! Here's a link to that thread and how I resolved it. Never know, but might help somebody else with engine problems.
http://www.rcuniverse.com/forum/m_9577676/tm.htm
Aussie1 is offline
Old 03-26-2010, 02:17 PM
  #3332
pulsar110
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys where is the best place to get a carbon spar tube here in the states for this plane? thanks
pulsar110 is offline
Old 03-26-2010, 02:38 PM
  #3333
littlepiston
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://rcfoam.com/cart.php?target=pr...category_id=94
littlepiston is offline
Old 04-02-2010, 02:46 AM
  #3334
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok guys I'm still making progress with my Falcon120. I will post some pic's on the internal layout soon, but i have just busted out the nose gear frames and looking at some different options for in the installation of the nose gear.
Anyone got any pic's of what they did with their setup? I'm trying hard to not have the nose wheel hanging down in the breeze. Mine is seemingly coming out fairly tail heavy so i'm happy to put some meat in there to support the nose retract.
dave
ticketec is offline
Old 04-02-2010, 03:16 AM
  #3335
fireblade5437
fireblade5437's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
this is how I did my falcon and it did add nose weight!
If you look further down the page you will see the woodwork which supports the JetA1 nose leg
[link]http://www.rcuniverse.com/forum/m_5913492/anchors_9380206/mpage_125/key_/anchor/tm.htm#9380206[/link]
Alan
fireblade5437 is offline
Old 04-02-2010, 10:04 AM
  #3336
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you have a firewall mounted or rail mounted nose gear?
See post #545 for how I did my rail mounted nose gear.
http://www.rcuniverse.com/forum/m_59...22/key_/tm.htm
Joe
joeflyer is online now
Old 04-04-2010, 08:34 AM
  #3337
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the pix guys,
I based my solution loosely on fireblade's effort, and i will box in the nose gear as he has done, I've just Hysol'd another frame in there so i'll let that cure overnight.
My retract is a rail mount design, but i have bulkhead mounted it!! The reason for this is that if i mounted it on rails then I would have had to really recess it into the airframe to make sure the nose wheel didn't stick out. with the way it is setup now, it fit's in really well, and i haven't changed the overal length of the strut either so all good. I will make a hatch forward of this bulkhead to get the li-po packs as forward as i can for CoG reasons.
dave
ID:	1411576   Click image for larger version
ID:	1411577   Click image for larger version
ticketec is offline
Old 04-04-2010, 08:58 AM
  #3338
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting approach to mounting a nose gear.
Don't bother. Even with a turbine mounted in the back these planes come out quite nose heavy. Most end up putting the batteries in the middle or rear of the fuse to balance it. Of course that is somewhat dependent on which engine you are using and the weight and placement of your accessories. I've built two of them and there are a number of Falcon 120's in the area. Except for maybe an airtank none of them have anything in the nose. When building shift as much weight as possible rearward.
Joe
Old 04-04-2010, 03:37 PM
  #3339
tim777jet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joeflyer, my first Falcon, needed my batteries as far forward as poss, to get the balance right. My home made engine is heavy, although the pivot arm is not massive.
My later Falcon did not need any weight at the front.
I suppose better to lay everything in loose and see how your install comes out, cheers tim
tim777jet is offline
Old 04-04-2010, 04:04 PM
  #3340
rivarella
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My falcon ended up tail heavy. I have a K80e on it, not a light turbine. I also did a heavy stab only one servo adaptation. I had to fit all 3 batteries around the nose gear and added more 90 grams of plumb in the nose to get 330cm CG. If I would build another falcon, I would leave all turbine accessories and batteries to be installed at the end of the work to try to get nearer to the right CG.
I think it mainly depends on the turbine weight as the engine is placed behind the CG.
Ricardo
rivarella is offline
Old 04-04-2010, 07:32 PM
  #3341
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Of course you guys are right, it depends mainly on the weight of the turbine. I have no idea what turbine ticketec is using. The best advise for him is to not cut out a forward hatch before knowing weather or not he will need it. Unless he is using a heavy engine (P-80, K-80, Ram750,...) he probably won't need the nose weight.
Joe
Old 04-04-2010, 07:49 PM
  #3342
booker-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using a Ram 750 in mine and early indications are that I'll need all the weight up front I can get.
booker-RCU is offline
Old 04-04-2010, 08:23 PM
  #3343
Johnny Isaiah Woods
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Ram 750 on my Falcon, and I added another header tank of 8 oz
on a tray over the nose gear formers (where the air tank goes) to provide the
correct CG. You will love the performance and the verticles you get from
the additional thrust.
Johnny
Johnny Isaiah Woods is offline
Old 04-04-2010, 09:09 PM
  #3344
booker-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Johnny Isaiah Woods
Johnny
It was the video of yours that inspired me to get one. Just got to get it finished.
Galen
Old 04-04-2010, 11:35 PM
  #3345
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: joeflyer
Joe
A Wren 54 Mk 2.5
I put in nearly all the major bits and pieces i needed and she looked to be tail heavy which is why I was thinking i needed the packs all the way up front, but you do have a fair point. not need to rush making the hatch, just as simple later on as well.
I've almost finished boxing in the nose wheel, just have to work out if i will glass in the inside of the box seeing as i fly from grass and it could get all kinds of things in there...
dave
ticketec is offline
Old 04-06-2010, 05:14 PM
  #3346
Mavrik!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For Sale my Falcon 120 Jet plus Jet Central Rabbit Turbine Bindnfly professional set up see link below; SOLD
http://www.rctrader.com.au/index.php...id,5/Itemid,0/
PM if interested.
Mav
Mavrik! is offline
Old 04-10-2010, 01:36 PM
  #3347
TCHIEF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
any one have a right wing panel for the black and orange they dont need
TCHIEF is offline
Old 04-11-2010, 07:24 AM
  #3348
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Mavrik!
PM if interested.
Mav
Mav, bit of a fire sale??? I see your stuff for sale everywhere!!!
dave
ticketec is offline
Old 04-12-2010, 06:26 AM
  #3349
Mavrik!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ticketec
Quote:
ORIGINAL: Mavrik!
PM if interested.
Mav
dave
Dave,
Yea I got to make room and raise funds for the next project
How is your Falcon going???? Will you travel down to Temora this year?
Mav
Mavrik! is offline
Old 04-24-2010, 08:08 PM
  #3350
chilechopper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
trying to post a picture
chilechopper is offline
Display Modes
