Bob Cat Copy Falcon 120 Jet
Reply
Old 08-29-2007, 04:35 PM
  #326
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Cat Copy Falcon 120 Jet
Ok, but whats the size ? since i might use wheels with brakes.
i3dm is offline
Old 08-30-2007, 06:16 AM
  #327
BiGToP
BiGToP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: i3dm
69.66mm all three!
BiGToP is offline
Old 08-30-2007, 06:18 AM
  #328
BiGToP
BiGToP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Woketman
Which ones? Do they fit well without a lot of re-work? Thanks.
I'm using 302's for my Falcon 120. They are the ones I used from my AMD Hawk.[&:]
BiGToP
BiGToP is offline
Old 08-30-2007, 08:46 AM
  #329
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: tim777jet
The pic of the inside fuse, shows where I cut the frame top web. I removed the pre-installed throttle cable and trimmed the 2 frames to the rear of this one. Afterwards I fitted a ply top web, held by 1 screw each side.
The nylon wing bolts were binned and I managed to buy some ally 7075 grade 6 mm bolts which weight nothing compared to steel bolts.
When I test ran the engine, I made up a .020" stainless plate to wrap around the tailplane and located it simply with 2 wire clips in case of a hot start. The engine would not light up, strange as for the past 10 years it has always lit up beautifully first time. I had to extend the glow plug leads by around 4 inches, but used high quality wire for this. I found that I had to increase the glow voltage 0.2 volts, then all was well. Strange.
I am using the spektrum 2.4 gig radio and am using DS 821 servos. (sorry i said DS 811 servos in my previous post). The DS821 is designed to run on 6 Volts, unlike other Digital servos. I am using a 5 cell nicad pack, direct into the receiver. Nicads are way fwd in the nose, ahead of the air tank, and receiver near rear of the canopy. I used heavy duty switch harness and wire, but havnt measured the voltage going into the receiver. Is it best to use a high current voltage regulator, or are these Digital servos ok at higher voltages when the nicads have just been charged?
. Recever pack was mounted on 2 carbon rod rails, which locates in a hardwood bearer on one frame ahead of the air tank (I removed the installed air tank holder) and another bearer block one frame rear of the first. My engine weighs @ 3/4 pound more than an MW 54, and this alleviates any nose ballast.
I was browsing today....
I dont think you ever got this answered. the 821's are fine on a raw NICAD pack. no regulator required, nor would I use one with the AR7000. its good also from 3.9 to 9 volts, and 0-30 amps.
Just make sure your setup doesn't allow voltage to drop below 4 volts at any time. it resets the receiver and goes stupid for several seconds. I think regulators that couldn't handle the demand was resposibile for alot of the problems. A good NICAD pack will have plenty of power with a 5 cell. If the wires are long, wouldnt hurt to use larger guage from the batt to the switch. I will say alot of folks are putting double output plugs on their switches where they plug into the receiver. One in the battery port and one in any open port, or on a Y cord with anything.
good luck.
gooseF22 is offline
Old 09-01-2007, 10:11 PM
  #330
454
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK I got mine flying 6 flights so far ( all of this came out of my yellow aircraft stare fire )(very fast and to small )
50 oz tank
10 oz header tank 6.5 minutes with plenty of fuel left
wren 54
funky re-tracks
9650 futabas digitals all around ( these work great )
robat struts
brakes and wheels from tam jet
futaba 5014 Rx and 12 z TX
I happen to have the wright length turn buckles In my shop these worked great and saved about 4 hours
in build time
THANKS to all that have posted it made the build go a lot faster bty the hatch mount suggested previously work awsome
Ill post pics an maybe a movie soon
no I don't know what it weighs yet and the cg is per the Manuel and needs to come back .25 in
the 45 deg of flaps would be nice but I only get about 30
I am going to try split rudders for More braking
thanks again guys
454 is offline
Old 09-02-2007, 07:44 AM
  #331
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
454, which size wheels did you use, and which model robart strtus fir the falcon ?
i3dm is offline
Old 09-02-2007, 10:08 AM
  #332
454
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my wheels are 2.25 but the came out of a stare fire
I do like the size though I think the are to small for grass
I dont remember the nummber for the struts
ill have to digg that up
454 is offline
Old 09-02-2007, 11:03 AM
  #333
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you can, please do.
A picture of the set installed could be great !!
i3dm is offline
Old 09-03-2007, 11:27 AM
  #334
454
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK guys heres the pics keep in mined that all this came out of a yellow aircraft stare fire .
The struts had been cut off and the retract air cylinder point the wrong why (for this airframe)
but it all works great.
One thing no one has mentioned,is that the nose strut need to be longer than the mains
this make the bob cat rotate more like a real airplane instead of jumping into the air
I also use the tail pipe out of the stare fire for starting it saves the weight of the alum tape and works very well
I have not weighed it yet but will let you know when I do
AND yes you need the down thrust , for full throttle flight .
The throws in the book are good but I have found that more elevator is needed for landing.
Do add 5 mm Of up or put it on a flight mode so you only get it with the gear down.
Flaps are not needed for take off . remember these are split flaps and only make drag IE no lift
I hope this helps you as much
as this thread has helped me
I took a grand total of 4 days to bulit my bob cat ,(yes I build fast )
ID:	755935   Click image for larger version
ID:	755936   Click image for larger version
ID:	755937   Click image for larger version
ID:	755938   Click image for larger version
ID:	755939   Click image for larger version
ID:	755940   Click image for larger version
ID:	755941   Click image for larger version
ID:	755943   Click image for larger version
ID:	755944   Click image for larger version
ID:	755945   Click image for larger version
454 is offline
Old 09-03-2007, 12:57 PM
  #335
preston_brown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bigplumbs
The prepared cut outs are too small for standard servos the HS225 fit perfectly and have enough power so why make life difficult...
Dennis/All,
I'm working on assembling my Falcon 120.
It doesn't appear to me that HS225MGs fit the cutouts for either the elevator or the rudder. They are *slightly* too big, and it looks like I'll need to use a dremel to open them up in both width and length.
Have they changed the size of the cutouts, or what happened here?
-- Preston
preston_brown is offline
Old 09-03-2007, 02:30 PM
  #336
Grodus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Preston,
I have recently started a Falcon as well. My servo cutouts were a bit to small on my kit also. I glued a piece of sandpaper to a 1/4x1/2 piece of balsa and sanded the cutouts a bit. It doesn take much. I also had to enlarge one of the flap servo cutouts for a std servo. the other flap and aileron cutouts were fine.
Cody
Grodus is offline
Old 09-03-2007, 04:40 PM
  #337
BiGToP
BiGToP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So was mine!
BiGToP is offline
Old 09-04-2007, 10:27 AM
  #338
Gary Szetlak
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It flies. RAM500 2x24oz tanks for fuel Robart spring down retracts and Jet1A struts. Gary Szetlak
Gary Szetlak is offline
Old 09-04-2007, 11:05 AM
  #339
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary,
So how does she fly with the RAM 500 ?
i3dm is offline
Old 09-04-2007, 02:21 PM
  #340
BiGToP
BiGToP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good Stuff!
BiGToP is offline
Old 09-04-2007, 02:24 PM
  #341
Terry Holston
Terry Holston's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ready to let it go yet???? LOL...........................
Terry Holston is offline
Old 09-05-2007, 11:08 PM
  #342
preston_brown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, my tail servo pockets were pretty darn undersized for HS-225MG servos. Maybe the guy doing the cutouts didn't drink his coffee and used the wrong template while doing the cutting, I dunno...
-- Preston
ID:	757360   Click image for larger version
ID:	757361   Click image for larger version
ID:	757362   Click image for larger version
ID:	757363   Click image for larger version
Old 09-06-2007, 05:07 AM
  #343
rcguy!
My Feedback: (69)
rcguy!'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: preston_brown
-- Preston
Hmmm... I just reworked only 2 sides of the pocket to get the servo to fit. I see you did all four! Maybe a cup of coffee for you too!
Dave
rcguy! is offline
Old 09-06-2007, 09:56 AM
  #344
preston_brown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did a little off all 4 sides so as to not thin any of the underlying support blocks too much in any one direction. They aren't too big...
-- Preston
Old 09-06-2007, 08:07 PM
  #345
angelrcdesign
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The set up for the ELE is 2 -81MGs as one, and the rudders are 2-225MGs , or
somthing in that area.
angelrcdesign is offline
Old 09-06-2007, 09:31 PM
  #346
454
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes the scale is good
mine is 14lbs 6oz
454 is offline
Old 09-06-2007, 09:50 PM
  #347
preston_brown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks like it might have been the case. I may be asking a dumb question, but wouldn't the elevator need more servo than the rudder? It would seem like it would be subject to more forces.
No matter, I've got HS-225MGs all around the tail now. Got to route out the holes in the fuselage and wait for my retracts. Starting to look like a real plane...
ORIGINAL: angelrcdesign
Old 09-07-2007, 07:26 AM
  #348
BiGToP
BiGToP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Winart will tell you I'm sure, that you need to have up elevator when it's in the neutral position, so as the trailing edge of the elevator is in line with the top of the horizontal stab. Otherwise take off is difficult?
Regards
BiGToP
BiGToP is offline
Old 09-07-2007, 10:21 AM
  #349
preston_brown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If up elevator is required at takeoff, it sounds like the decalage angle of the whole horizontal stab is incorrect? Is "neutral" while flying level still going to require up elevator, or is this a takeoff condition only?
-- Preston
Old 09-07-2007, 11:43 AM
  #350
Woketman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or perhaps excessive down-thrust (turbine nose-up) on the turbine is cuasing too much of a nose-down pitching moment and that, in turn, is causing the elevator up-trim. Might be worth a try to decrease the turbine angle.
Woketman is offline
