Bob Cat Copy Falcon 120 Jet
Reply
Old 12-29-2016, 06:52 AM
  #4926
sweetpea01
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Ed. I'm still thinking I'll try the direct link but not sure exactly how'll I'll make it work
sweetpea01 is offline
Old 12-30-2016, 03:51 PM
  #4927
sweetpea01
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a few things done this week.
1a. Got the nose wheel steering is figured out. It's going to look like the video below. Since the glue was crap holding in the braces I tore the whole front thing out and will attach the servo to the front of it. I used a temp servo for the time being to set it up. I'll post a video once I clean things up a bit.
https://www.youtube.com/watch?v=iE505LhvYrI
1.a I'm also going to Carbon Fiber glass the wheel mounts and create storage areas for my airtanks so they are upfront. Probably some Battery and weight holders (so I can change the CG easier)
2. I found 4 JR8611A's I had left over from other builds. So now I only need 3 servos (1 being nose steering)
3. I ordered my engine mount and ordered a centerline A4 tank that will be used for smoke (after a few flights)
4. I tore out the blind nuts in the booms and the wings and put 1/4x20 in. Then I cut and Hysol'd bolts into the wings. I use nylon wing nuts on them as attachment points in the fuse. Been doing that on 42% gassers for years and they never come loose and are easy to put on and change out on yearly maint.
5. I put a wood dowl in the boom hole on the wing. I want my bolts more flush and it will be easier to glass this way.
Old 01-10-2017, 12:23 PM
  #4928
sweetpea01
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Weather here has been horrendous! It's been 60, flooding rain, then zero, then snow, then zero, now wind and rain and going to upper 50's.
I finished creating my direct link to the nose gear but I don't like it. It will create a tiller bar that is longer than I want (otherwise the linkage hits the wood gear mount) which will require a really large cutout for the nose gear and I was going to do a gear door similar to the BVM Bobcat for ease of use. So I'm probably going with the wire pull-pull setup.
I installed my Turnigy lights in the wing just to see how it will look. They are really a night/dusk light system so I might pull that out and do something brighter before I glass things up. I'm still waiting on my small wingtube and some hardware to show up. I got my 5degree engine mount though. I sanded the wing dowl down and that is now flush.
Just hasn't been a good couple of weeks for me in the shop. This weekend though I will be at it.
Old 07-24-2017, 12:40 PM
  #4929
Dpienaar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kt p80
Originally Posted by Dr Honda View Post
For the new guys, just coming into the Falcon group... Todd at DreamWorks sells my motor mounts now.
Here are the 0 degree mounts. (what I use)
http://dreamworksrc.com/catalog/falc...ee-p-2405.html
Here are the 5 Degree mounts that most of the guys here use.
http://dreamworksrc.com/catalog/falc...ee-p-2406.html
Hallo what diferance does the 5dg down do vs the 0dg DW only have the 5dg mounts in atock
Dpienaar is offline
Old 07-24-2017, 12:41 PM
  #4930
Dpienaar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kt p80
Dpienaar is offline
Old 07-24-2017, 02:16 PM
  #4931
edwarda10pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you do not put the 5* of down thrust, you will have to re-trim the plane every time you make a change in throttle setting. A number of us have spent a lot of time making changes to the thrust of the engine to find the setting that requires NO TRIM changes with different throttle settings. That thrust setting is 5* of down thrust.
Ed
edwarda10pilot is offline
Old 07-25-2017, 04:06 AM
  #4932
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed
Not true. I fly mine with zero mounts, and there isn't any real change in trim. But mine is heavy... so that may make a difference.
Dr Honda is offline
Old 07-25-2017, 06:32 AM
  #4933
why_fly_high
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you always fly at one power setting you can trim for that power setting. With mine and a 100 I cruise at 1/4, sometimes buzz around at half, and sometimes I do full throttle high speed passes. I can tell you from my experience that 5 degrees is just about right to avoid trim changes with power changes.
why_fly_high is offline
Old 07-30-2017, 09:41 PM
  #4934
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you don't have a 5 degree mount I have found that a wheel collar under the the front mounting straps works about perfect.
Dieselman1220 is offline
Old 11-23-2017, 01:13 PM
  #4935
charlie turbine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Does anyone know if there should be down thrust on the turbine or should it be mounted parallel ie no down thrust.
thanks
charlie turbine is offline
Old 11-23-2017, 03:10 PM
  #4936
SeaHawk-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by charlie turbine View Post
Hi
thanks
Anywhere between 0 and 5 degrees has been used. My current Falcon 1.20 (no 4) has 3 degrees of down thrust (jet pipe end down) and flies well.
regards
Col
SeaHawk-RCU is offline
Old 11-24-2017, 05:58 AM
  #4937
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you read the threads you'll see that most use 5 degrees of downthrust. The real answer is that it depends on your engine and how fast you want to fly. Without some downthrust the plane wants to go up at higher speeds. The faster you go the more it raises. If you don't want to be re-trimming your plane at higher speeds then put in some downthrust.
I've had two of these and have flown them with several different engines. If you're using a 10# engine then it probably doesn't matter much. For 14 - 17# of thrust 5 degrees works fine. If you've got 18# or more go with 6 degrees.
joeflyer is online now
Old 01-31-2018, 04:10 PM
  #4938
Larrythelathe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default He!p
I know this old but hope some are around.
I have a new in box falcon 120. I want to go electric pusher for noise reasons. I however am finding the motor prop selection hard.
Can anyone help?
Larrythelathe is offline
Old 01-31-2018, 05:39 PM
  #4939
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the size of motor you will need for the weight of this airframe will preclude it being used as an electric pusher because of the prop size/diameter needed for the motor vs the ground clearance with the standard length undercarriage, on take off this clearance decreases quite considerably.
Mike
BaldEagel is offline
Old 01-31-2018, 08:17 PM
  #4940
hobbyaire
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I experimented with an 11 x 12 APC glow prop (they don't/didn't make that one as an e-prop) .. it was satisfactory .. it indeed did work .. not all that fast, but gave a cool turbine like sound, rather than a prop sound.
I had about a 2000 watt, 240kv motor on 10S ..
.. however, I didn't stay with that .. went on to turbines
hobbyaire is offline
Old 01-31-2018, 10:08 PM
  #4941
Larrythelathe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3000 watt is where I I think it needs. I just cannot figure out what motor go for
Old 02-02-2018, 06:54 AM
  #4942
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I remember correctly someone makes three bladed pusher props, that may be your best bet.
Mike
Old 02-02-2018, 11:52 AM
  #4943
Boomerang1
Boomerang1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike
Prop availability is wider than you think, direction can be reversed remember.
Any three blade prop is on the shopping list, just remember to put the 'curvy side' to the front!
Boomerang1 is offline
Old 02-02-2018, 12:45 PM
  #4944
Larrythelathe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was more asking what motor. I would do ic if electric is undoable but must be possible if you can do it with iIC
Old 02-02-2018, 01:28 PM
  #4945
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Need for remembrance, this airframe was designed in the first instance for an IC engine, go to page one.
Mike
Old 02-02-2018, 01:46 PM
  #4946
Larrythelathe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup agreed I have a noise sensitive site local. Also one I can fly jets turbines. Local one would be god hence the electric option.
What pitch was used for a three blade 1.20" glow engine? I assume /30cc petrol would be the same?
Old 02-03-2018, 05:06 AM
  #4947
david101
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fan conversion
I have seen here in FL a Falcon fly w a 5" fan successfully. Good speed etc. I have a new in box Turbax unit w neu motor and speed control for sale. $350 (all nib)
Dave
david101 is offline
Old 02-04-2018, 02:02 PM
  #4948
Larrythelathe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry if I went that way it would be a jetfan 120mm
One thing you guys may be able to help with. My wood work has been pulled from the front as it was a bit loose. Its left a run of resin. How did you all remove this? I have built up new former to allow for the steering servo. How did they intend the builder to do this?
Also how did you do the hatch and canopy?
Old 01-11-2019, 01:35 PM
  #4949
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys,
whats the recommended CG fir the falcon 120 jet?
i3dm is offline
Old 01-11-2019, 02:25 PM
  #4950
john491
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
C G is 12-3/4" to 13" aft leading edge of the wing at the root. Just about the leading edge of the belly hatch,
John
john491 is offline
