VELOX.. Build thread with Photo's..
Reply
Old 06-05-2007, 04:57 PM
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: VELOX.. Build thread with Photo's..
....Simmer down now you two...
O.K photo of the Mains gear mount to show why a new plate is needed to fit the JET-1A rtract units. The gear body like John said, needs to go right to the front edge of the ply + the pins and spacer need shortening.....this set of retracts was origonally destined for a Harpoon
The front gear body may well prove to be more awkward..[>:]
ID:	698242   Click image for larger version
TREADSTONE is offline
Old 06-05-2007, 05:17 PM
felker14
My Feedback: (50)
felker14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you post a picture of your front retract unit your going to use.
felker14 is offline
Old 06-06-2007, 12:02 AM
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...O.k ...front.....As you can see to get the retract body down onto the mounting plate would require removal of a section of former F1...Not good, in fact out of the qution really.
I could put a big spacer under the gear body side nounting plates but this would stop th front wheel retracting into the fuse completley....Any bright ideas..
Old 06-06-2007, 12:36 AM
SinCityJets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about cuting the former, and then creating a new former, like a bridge between the two sides. The new one will just be higher to allow for the retract.
Now, I have a question.... Can you use Jet-1A struts with the stock retracts??
SinCityJets is offline
Old 06-06-2007, 02:54 AM
john agnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
C2 / TS
Cutting the former and forming a new bridge is the way to go. Then the Jet 1A retract unit can be mounted on top of the gear plate. The Jet 1A struts supplied with the kit combo have stubs to suit the pinch type trunnion blocks of the Feibao retract unit. Sorry, I don't know what the diameter of the stub is. Sandor should be able to tell you. He is away for a couple of days.
John
john agnew is offline
Old 06-06-2007, 02:58 AM
  #31
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, what you suggest with the former is pehaps th only way forward..
And yes again the Jet-1A struts, oleo's, call them what you may will work with the stock retracts....in fact they come as standard in the kit..
Brg
Dave.
Old 06-06-2007, 10:44 AM
  #32
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: C2_Hobbies
1: Good idea
2: we made special oleo,s to fit the Velox...
digitech is offline
Old 06-07-2007, 03:30 PM
  #33
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
..Ready to fix the servo mount brackets to the servo's prior to installing the servo's +mounts into the aileron, flap & elevator recess.. pretty straightforward...
The chippies at work should have finished the former bridge piece & new retract mount plates tomorrow...
Old 06-07-2007, 03:44 PM
  #34
john agnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TS
Beef up the nosegear retract mount with some 3mm carbon fibre plate laminated to it or similiar, the plate is a little weak!
John
Old 06-07-2007, 04:43 PM
  #35
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
O.K. John, Thanks ...where did it split..?
Old 06-07-2007, 05:09 PM
  #36
john agnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TS
At the screw holes!
john
Old 06-08-2007, 03:40 AM
  #37
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
..Got to make a new gear mount plate anyways....The JET-1A retracts have a narrower body..Maybee bolt through the lot..
Old 06-08-2007, 07:14 AM
  #38
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would jr 8231 be enough for the flaps and ailerons and say a jr 8711 on the elevator?
Jeremy_D is offline
Old 06-08-2007, 07:28 AM
  #39
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Jeremy_D
that is overkill...
but yes you can probably fly without a engine by just wobbling the sticks
digitech is offline
Old 06-08-2007, 08:21 AM
  #40
SinCityJets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you guys put up some detailed pictures of reinforcing the mounting plates when you ge there?
Thanks.
Old 06-08-2007, 10:45 AM
  #41
Charts
Charts's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
Finally got chance to play with the Velox today and I am still very pleased with it, especially the paint job, but I've discovered a few little points I want to pass on.
I attempted to put the model together and found that the wing tube is very stiff in one of the wings. Not a major problem at all. Nothing a little sanding won't cure though.
On fitting the tail plane and securing screw, the socket cap just kept turning with no resistance when screwed fully home. After removal it became apparent that the socket cap slides into the blind nut. I cannot see any evidence of a stripped thread, but I suspect this is the case. A similar thing has happened with one of the wings as mine don't fit very well and need work to line them up. Although not hard to fix (re-tap and a 4mm socket cap) I thought I would point out that the metal used for the threads is very soft and care should be taken when securing the socket caps.
Other than that the kit is great and I look forward to getting on with it as soon as the rest of radio gear arrives.
Thanks for the update on the rams etc Sandor. This will be my first model with doors, should be fun!
ID:	699902   Click image for larger version
ID:	699903   Click image for larger version
Charts is offline
Old 06-08-2007, 11:41 AM
  #42
figueroa
My Feedback: (22)
figueroa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does any one know the wing span and engine size fot the Velox.
Thanks.
jef
figueroa is offline
Old 06-08-2007, 11:57 AM
  #43
rcjetmodels
rcjetmodels's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: figueroa
Thanks.
jef
Hi Figueroa please lock on my website http://rcjetmodels.com/index.php?act...&productId=266
regards,
rcjetmodels is offline
Old 06-08-2007, 12:10 PM
  #44
figueroa
My Feedback: (22)
figueroa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Than you, Wagner.
jef
figueroa is offline
Old 06-16-2007, 03:41 AM
  #45
TREADSTONE
TREADSTONE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whew....long w/end for me.....Phernominamanally....err V.buisy... at work...Boeing have a Dreamliner they want some earings for ..like yesterday.
Anyways. front new former done , photos later, Going out to get some carbon plate today & some other bits...
Sandors door rams arrived this morning....how are they mounted...any bright ideas...or even a photo...
Old 06-21-2007, 06:28 PM
  #46
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Jet-1A retracts appear to be a poor fit in this plane. Can someone confirm that the stock retracts are a drop in fit? Anyone have pictures?
It was my understanding that the standard combo package includes Fei Bao retracts/wheels/brakes and Jet-1A struts. As an option you can get the Jet-1A retracts. Is that correct?
Joe
joeflyer is online now
Old 06-22-2007, 02:58 AM
  #47
john agnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joe
In my Velox I modified the position of the Feibao main retracts to allow the wheel to centre in the wheel cut out. To do this you need to make up some plywood plates to glue onto the existing retract mount. The reason for this is that if you move the retract body forwards to centre the wheel there is not enough purchase for the rear mounting screws.
You could enlarge the wheel cut out and leave the mount alone but if you do this the gear door will not fully cover the wheel opening. All of this is caused by the trailing link oleo and I guess the model was originally designed for straight oleo legs. BTW the trailing link oleos are the way to go they are very strong and really work on grass strips. The Feibao retracts are also of excellent quality and I would not pay the extra for the Jet 1A retracts as good as they are too.
John
Old 06-22-2007, 03:05 AM
  #48
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: joeflyer
Joe
no this is very confusing
i will try to explain it:
we from Digitech deliver the velox different from others.
we use the stock retracts from Fei bao because they work ok , they are not proffesional but i use them since last year and still ok.
we decided to replace the stock oleo,s with customomised Jet-1A oleo,s since most pilots overhere fly of grass.
so using trailing oleo,s makes sence.
the stock oleo,s maybe are ok for some , but our experiance was terrible and you lose the joy of flying very fast.
also i land like i fly very confusing.....
now we have 2 options:
you can order :
1. landing gear standard
2 .or de luxe version wich has the electronic valves included.
we do NOT suply the whole jet-1a landing gear.
ONLY the 3 oleo,s and a new frontwheel.
now the us importer made a small mistake on his website.
he has the option jet-1a landing gear.
but it should be retracts including jet-1a oleo,s and front oleo incl wheel.
here is a picture how our package looks like:
Front retract and oleo , Main retract and oleo , normal landing gear , de luxe landing gear
ID:	708640   Click image for larger version
ID:	708641   Click image for larger version
ID:	708642   Click image for larger version
digitech is offline
Old 06-22-2007, 11:39 AM
  #49
SinCityJets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joeflyer,
Do you have Jet 1A retracts or the Fei Bao retract bodies??
Old 06-22-2007, 04:38 PM
  #50
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joeflyer,
they are only sold in europe sofar.
we are planning to deliver to our dealer(s) soon
digitech is offline
Contact Us Archive Advertising Cookie Policy
