Reload this Page >
Parts for AV8R? Where to get them....
Old 06-16-2007, 01:10 PM
dw_crash
Default Parts for AV8R? Where to get them....
Hello Jet Jocks,
I have a AV8R that had a bad wet start. The stab and rudders were burned off in the explosion. The rest of the plane is intact and the fuse under the tail is solid. The AV8R had a foam, balsa, carbon fiber tail feathers. I'd like to get these parts to repair this jet. Does anyone have these parts or know where to buy them?
I have check FLYPCM which used to be the manufacturers website. But, it is not a valid site. Anyone know what happened to PCM models?
DW_Crash
Old 06-16-2007, 02:49 PM
Shok
My Feedback: (28)
Shok's Avatar
Default RE: Parts for AV8R? Where to get them....
yeah he closed up and works for BVM now
Old 06-16-2007, 03:42 PM
dw_crash
Ronnie,
DO you know how to contact Patrick over at BVM, his home email or home phone number?
I'd really like to see if I could get him to make the 3 parts for my AV8R.
DW_Crash
Old 06-16-2007, 04:44 PM
Shok
My Feedback: (28)
Shok's Avatar
sorry, I dont have a contact, you might call bvm and ask for him
Old 06-16-2007, 06:47 PM
Boomerang1
Boomerang1's Avatar
Is it not a simple wood/foam plane? I'm sure one of the modellers with scratch building skills (try one of the older guys) could help you make some bits from scratch.
I built a smaller version of the DV8R from scratch, it's not as hard as you think. - John.
Old 06-16-2007, 07:02 PM
r3bldr
The tail parts should be pretty easy to make again if you have the plans, or actually the computer drawings, that Pat put in the kit. You could scale up the drawing and build new parts from it. I think www.flypcm.com is dead and burried. I've seen lots of questions posted over at rcscalebuilder go unanswered.
Old 06-16-2007, 08:27 PM
seanreit
My Feedback: (60)
seanreit's Avatar
If someone sends me the plans I can make parts on my CNC Router for you guys.
Old 06-16-2007, 09:20 PM
Kelly W
Dave, try contacting Wayne Beasley just outside of Edmonton (he works at Great Hobbies). He's got an AV8R that's almost finished, and could probably help you with making a new set for yours. I know he's kit bashed / modified it a fare bit, so he may have some of the exact parts you need, unused and without a home...
Kelly
Old 06-17-2007, 08:30 AM
DP01
DP01's Avatar
Here's some info that may help - dimensions from my AV8R plus a few build photo's.
Dennis
ID:	705601   Click image for larger version
ID:	705602   Click image for larger version
ID:	705603   Click image for larger version
Old 06-17-2007, 12:35 PM
Wayne22
Wayne22's Avatar
Correct-o-mundo Dave, I have a pair of vertical fins unused. The stab is a half inch flat plate and would be pretty easy to build up....
Old 06-17-2007, 08:56 PM
dw_crash
Thanks Guys.
Thanks Wayne22, I will sure be able to use the rudders. I just need to find a stab. The original is foam and fibre core sheeted with balsa. I might be able to make one out of just balsa. Build a frame and sheet with balsa. Any thought on whether this would be strong enough?
DW_Crash
Old 06-17-2007, 09:00 PM
dw_crash
DPO1,
Thanks for the photos and drawings. It will help the diassembly and rebuilding.
DW_Crash
Old 06-23-2007, 03:24 PM
dw_crash
Guys,
Thanks for the Help. With assistance from Pat and Wayne, I should be able to rebuild the AV8R.
I learned a good lesson, fule siphons. I did not close the manual fuel valve while I did some adjustments. Fuel siphoned into the engine and KABOOM on the next start. Always cut the fuel flow off, You never know were it may go!!!!
DW_Crash
