JetLegend F-16 Kit Build
#51
My Feedback: (57)
RE: Let Legands F-16 Kit Build
ORIGINAL: drdoom
Yep, Florida Makos. I like the shark.
Cindy at Aeroloft had this in her list of about 15 different F-16's.
And I found a great pix of it here on the web.
If all goes well I will be spraying My Clear Coat tonight LATE!
ORIGINAL: FalconWings
What are those, Makos? Where did you get those transfers?
My jet will be here any minute, can't wait!!
#53
My Feedback: (9)
Here is a picture of the control board layout. Ill remove everything and paint it black.
Need to install the fuel tanks , UAT, Propane can, aileron extenions, and the turbine.
shouldn't be much longer.
It makes it easier just to get an Idea where things need to go.
Ill post the back of it as well .
#55
My Feedback: (9)
Save the Pix in MS Paint and size it to the Origional and run it to the printer.
This is not the board that came with the jet.
Here is the side and bottom.
#56
My Feedback: (9)
After 4 months of Building I have the Fuel tanks in and the turbine mounting rails installed and I dicided to see if the P-70 would fit into those rails,
and found a couple of things.
1 I had to cut about 3/16th off of each side of the Jet Cat mount. to fit between the tanks and not touch,
2 The turbine had to be raised 1/4 inch so It wouldn't touch the main Landing gear pneumatic cylinder block.
3 Ill have to raise the exhaust tube accordingly.
Has anyone else installed a P-70 in this Jet?
#58
My Feedback: (9)
I just recevied the model last night. Looks really good. One of my 300 Gal tanks has someshipping damage, else looks pretty damn good!
Also Are you using a Jetcat P-70? and did you get the ARF?
#61
My Feedback: (9)
It will take a while to set up you control board. What are the fins made from on the rockets?
I may need to get the rodinance kit for mine. But Ill wait till after the Maiden..
It is ready to go.
It is ready to go.
#62
My Feedback: (57)
The fins seem to be glassed plywood, already cut to shape. I would prime them. The install, removal is easy. Two set screws hold the ordenance against the pylon, and two mahcine screw attach the pylons to the pre-installed hardwwod mounts on the wing. The location of the blocks is shown on the plans, and hole location is marked on the wng skin. Ta-da!
#63
My Feedback: (9)
Falconwing:
If you hold the wing so light bounces off of it, and Look real close, their is a 3 mm circle molded into the skin where the pylons go.
This keeps the pylons pointed directly into the wind. also allows for the screws to be centered in the hard points. I drilled a 1/32 hole in the center of all of those markings so they couldn't be sanded off.
Other things are also marked that way. but with the ARF. Most will already be used up.
Post Pix of your progress here as you build.
#66
My Feedback: (57)
Hey man, where did you install the nose gear cylinder, all the way inside the inlet fwd former?
I was going to do it similar to Yellow's, but now I remeber it was difficult to get it to shut the door all the way.
Started bondo work tonight, but my Evercoat Glaze is very rubbery (it's 2 years old). I need to go buy a new can tomorrow.
#67
My Feedback: (9)
Get what is called "ICING". You will love it. it is in a tube. On the Nose Gear I put the cylinder on a bulkhead about 2/3rd's of the way back from the front and hooked it to the hinge horn. Works great. The dorsal fin locations are also moulded in, on the fuse.
#69
My Feedback: (9)
I have mine pretty much completely finished. I added that heat shield to the upper aft of the fuse and Hatch. last night. I added a charge pigtail to the turbine Battery with 3 way switch. So I can charge without continuely unpluging the wires from the ECU. Is anyone flying this the OEM wire antenna? I am on 50 MHZ.
#72
Hi Guys:
I am selling my Jet Legend F-16 1:8 scale as I have decided to go a little bigger. Does anyone no of people who are interested in acquiring one without paying $1790.00 for one, and also not worrying about shipping all the way from China? I will be willing to part with $1600.00
Thanks.
Thanks.
#73
My Feedback: (57)
ORIGINAL: drdoom
