Reload this Page >
Futaba FASST feedback and TESTING
Old 11-22-2008, 11:35 AM
  #1451
Mr DJ
Default RE: Futaba FASST feedback and TESTING
Richard
I'll probably get there around 12 - that's where my CD flies. Was heading out there this morning but he called it off - too cold and windy
I'm a member of all there clubs, but I fly out of CCRC most of the time since I live maybe 10 miles away...
I'm the first and only tubine flyer at CCRC - I'll be flying my ShocJet there mostly since it flies off grass like nothing. Once I build my other Jets, I'll fly them at PGRC and DCRC:
Rafael
F-16
Old 11-22-2008, 11:50 AM
  #1452
av8rk
Mr DJ,
I hope you have better weather sunday.....But the forecast doesn't look promising right now....
It seems that you live very close to the old Doug,s hobby shop on 301...been there many times....
Richard
Old 11-22-2008, 12:07 PM
  #1453
Mr DJ
Yeah, Richard
The weather will be only slightly better
And yes, right next to Doug's Rip Off Hobbies
I'll let you know how it turned out...
BTW, what different birds are you flying?
Mr DJ
Old 11-22-2008, 12:19 PM
  #1454
afterburner
My Feedback: (18)
afterburner's Avatar
ORIGINAL: Mr DJ
Richard
My CD told me the same. I just wanted all of my turbines on 2.4 - I have 7 freakin' new 2.4 receivers just waiting to be installed...
I sent my turbine back to Jet Central - they ran it ten separate times with no problems. Since its return, I've cranked it up 4 times with no problems, but haven't flown it yet or put through a full tank, but it at least reaches its 180K rpms without shutting off like it did the first time...
Tomorrow I will fly it and see what happens. Will take my 9303 with me just in case I have to switch it...
Thanks...
It's a little strange that JetCentral didn't change anything and after your re-install install, it works fine. At the very least, I would start it up and jiggle the throttle connections to see if it's reliable. Did you swap out the 2.4 Rx for another one? Could be cold solder joint internally for the throttle channel on the Rx itself.
Marty
Old 11-22-2008, 12:30 PM
  #1455
Mr DJ
Hey, Marty...
I don't think they tested it with a 2.4...
I hadn't thought of a lose joint or connector on the 2.4 receiver and it is the same one. I have started it 4 times with no problems... I think I'll also carry with me another 2.4 receiver since I have 7 of those expensive mothers hanging around...
Thanks for the idea...
Old 11-22-2008, 12:51 PM
  #1456
mr_matt
My Feedback: (10)
mr_matt's Avatar
For this canopy locking issue, if you are using 2 electronic valves, plug them into the same channel and see if you can adjust their on and off points far enough apart.
If you can, then you can plug them both into one channel and just use a slow enough ATV setting and you can do it on one channel with no mixing.
Old 11-22-2008, 12:54 PM
  #1457
afterburner
My Feedback: (18)
Yeah they are pretty pricey. When I got my 12FG on 72Mhz, my thoughts were to migrate slowly to 2.4 once I got the module but after a few weeks I didn't like the idea of constantly swapping the modules. That coupled with the premise that once I got complacent about not having to worry about the frequency board, I didn't want to accidentally shoot someone down when flying on 72. Good luck with your flight and sign off tomorrow.
Marty
Old 11-22-2008, 12:56 PM
  #1458
Mr DJ
ORIGINAL: mr_matt
Sounds easy enough, Matt...
But I would need it to be reversed when closing the canopy... Canopy first then lock...
Old 11-22-2008, 12:59 PM
  #1459
mr_matt
My Feedback: (10)
mr_matt's Avatar
Sorry computer problems plus I am babysitting.
I am not sure why you need a sequencer. Here is the sequence (as I understand it) assuming the canopy starts in the "up" position with the locks "unlocked"
1.) The single "canopy channel" starts actuating slowly (in the "canopy down" direction).
2.) Canopy valve actuates and the canopy closes
3.) "Canopy channel" continues to move and the "canopy lock" valve now locks the canopy.
Canopy is now down and locked.
To open the canopy, the sequence is reversed.
1.) The single "canopy channel" starts actuating slowly (in the "canopy up" direction).
2.) First the "canopy lock" valve unlocks
3.) The "canopy channel" continues to move (in the "canopy up" direction) and then the canopy opens.
This ALL depends on being able to set the electronic valve actuating points far enough apart. This is basically what a JR channel expander does. But in some cases the electronic switches can be set far enough apart to accomplish the same thing.
Old 11-22-2008, 04:44 PM
  #1460
Ehab
My Feedback: (44)
Mr Matt; did you mention you have some fans for the 6014 Fut. Rx? If so, I need four...PM me plz!!
Old 11-22-2008, 04:54 PM
  #1461
Mr DJ
ORIGINAL: mr_matt
Hum, Marty
I'll give it a shot...
Many thanks...
Old 11-22-2008, 05:33 PM
  #1462
JCINTEXAS
Regarding FASST testing...
I tested my new 12FG yesterday.
Turned-on the transmitter, went outside and put it on the floor of my van.
The RF signal had to penetrate thru the steel in my vehicle...and thru both sides of my wife's Honda...
and then thru the exterior wall of my home. I went back inside and turned the receiver on.
The LED was red for about 1 second and then SOLID GREEN.
The FASST RF lock is amazing.
JC
Old 11-22-2008, 05:42 PM
  #1463
mr_matt
My Feedback: (10)
mr_matt's Avatar
ORIGINAL: Ehab
yeah they are all yours, nice 5v brushless. Just PM me the addy. Domestic I will pay shipping, if you are still hiding out overseas figure out a way to get them there!
Old 11-22-2008, 10:06 PM
  #1464
Woketman
Matt, can you divulge your source for these wonder fans? I hope that it is not Sean numerically machining them out of titanium! [8D]
Old 11-22-2008, 11:03 PM
  #1465
mr_matt
My Feedback: (10)
mr_matt's Avatar
They are 5 volt Sunon brushless fans, I used them on a design for GM. They cooled a unit that let you watch your Tivo files in your mini fan. I got a dozen or 2 left if you want one.
Old 11-22-2008, 11:24 PM
  #1466
Ehab
My Feedback: (44)
ORIGINAL: mr_matt
ORIGINAL: Ehab
Thx mr. Matt....
Just send to PST jets. PM ur payapl addy too plz. USPS international works great...
Old 11-23-2008, 03:41 AM
  #1467
GrayUK
GrayUK's Avatar
ORIGINAL: JCINTEXAS
JC
Yes, the lock is awesome, I have done ‘stupid’ tests but it just keeps working.
I had a ‘heated’ discussion with one guy who basically told me I was a liar! It was impossible; it could not work etc. etc. .
Well, as you have found, it does!
It is without doubt the best RF lock I have flown with.
In over a year of flying in all conditions, different locations, jets, props and heli, etc..
It has never missed!
Always locked on fist time, not a single non instructed command.
The 12FG is also just an amazing TX .
Paul
Old 11-23-2008, 05:35 AM
  #1468
Ehab
My Feedback: (44)
Just got my 12FG for less than $689.00[X(]. I took a chance on it, and it IS 14 channel just like the 14mz[8D]...Screen is a little small and dark after using the 14mz's screen, but for the money...one can not go wrong if one is not blindly brand faithful
Old 11-23-2008, 10:28 AM
  #1469
Ehab
My Feedback: (44)
Matt; here is the addy:
contents: Computer used parts
PST Jets Co., Ltd.
1111/1 Pattanakarn Road
Suanluang, Bangkok 10250
Thailand
Old 11-23-2008, 03:08 PM
  #1470
phjoker
phjoker's Avatar
I flew with the 12fg today for the fist time. I did a range check I had someone stand next to thehe plane with there
cell phone I walked and walked and walked and walked with my cell phone and my transmitter of course and it was like I was standing
right next to the plane whole time. No jitters no shakes nothing just a solid link. I walked father then I usually do for the 72 mhz stuff
and some of the people were shocked that I was so far out and it was still responding.
Very happy with the Futuba Fasst. I feel a safer at the field now. Now I can put in into the booemrang I needed to test it
out on something else first. I didn't want to put it into my first jet without checking things out.
now If I could get the programming figured out. It would be Golden
Old 11-24-2008, 07:49 AM
  #1471
GrayUK
GrayUK's Avatar
PHJOKER
Welcome to the FASST club. [8D]
Paul
Old 11-24-2008, 11:07 AM
  #1472
DougV
FYI:
More goodies:
http://www.rcuniverse.com/forum/m_8178215/tm.htm
-Doug.
Old 11-24-2008, 11:27 AM
  #1473
Ehab
My Feedback: (44)
Great, now we can transfer between 12FG and the 14MZ.......
Old 11-24-2008, 12:18 PM
  #1474
rhklenke
My Feedback: (24)
rhklenke's Avatar
ORIGINAL: Ehab
[snip] it IS 14 channel just like the 14mz[8D]...[snip]
Has software been released to make the 12FG 14 channels, or am I missing something?
Bob
Old 11-24-2008, 12:29 PM
  #1475
Ehab
My Feedback: (44)
My 12FG from tower is 14 channels already...
