BVM Hi Flow valve
RE: BVM Hi Flow valve
the air tank is attached to the center tube. From either end run a line to a "T" and from there to the up side of the main gear. From the adjacent tube go to the up side of the nose gear. From the other end of the valve go to the down side of the gear the same way you did the up side. That is all you do.
Steven
Steven
