What do you think about JETLEGEND L39?
#626
RE: What do you think about JETLEGEND L39?
Hi Andreas,
Put approx 6ozs of lead in the nose for balance. but don't forget I have the pilot & co-pilot fitted & they are fairley heavy.
Also in the nose on the ply plate is a 6Volt nicad, the other being fitted at the front of the main plate.
Still waiting for some decent weather, for the maiden flight.[&o]
All the best,
John C
All the best,
John C
#627
Hi Jeremy
I strapped my main tanks with cableties,through the speed brake access very simple then I run a long cable tie
to hold the extra tank on right around the 3 tanks it is very secure and easy if you have to take them out
have a nice day down under ,if u need water we can send you lots as we are not getting flying weather[&o]
regards
Andreas
regards
Andreas
#628
Hi Andreas,
Did you manage to load photo's after.
All the best,
John C
When the wind stops, the rain falls & vice versa.[:@]
All the best,
John C
#630
My Feedback: (47)
ORIGINAL: avicom
Hi guys, finally I got a new camera. Here are few pics of Hector's plane. The two fuse half with the carbon cloth reinforcement and SB. Carbon cloth is 5.7oz applied with west system.
Barry
#631
My Feedback: (22)
FL
That's a great idea . I did the same thing to my Boomerang XL , the weight from the glass and epoxy saved me having to add weight to the nose. I plan on doing the same to my L39 hopefully it will solve the "oilcanning" problem and the need for nose weight.
#633
My Feedback: (14)
Barry, I got your point. But for the bottom I'm thinking in using 5.1oz glass clotch instead of carbon. Like in this flash I'm repairing. Notice that the flash have the carbon reinforcement from factory and this one was broke in half. The owener of this plane was amazed when I show him the front part almost repair. My old boomerang XL almost lost his nose in a very hard landing. Here is the pic of the carbon reinforcement as you mention in the boomer, last two pics. In the boomer it only gets few hairline cracks to the gelcote not really broken. I like the idea of using carbon strips instead like some photos in early post here.
Rgs
Alex
Rgs
Alex
#635
My Feedback: (47)
Exactly....I did the same but also added two 1/2" wide strips along the length of the nose between the formers. Here's a pic of what I did in the rear - the longitudinal strips are 3/4" wide. I would not bother doing them diagonally next time, just laterally as is shown in the picture you posted.
Barry
Barry
#636
Jeremy,
Fuel tanks : with a long velcro band all around them ; put some foam under the tanks so they can't slide as well.
I tried first ZAP-A-GOO and then hot glue too but this fails (due to the kerosene).
Julian,
Superb set-up and installation ! That's how we like it !!! [8D][8D][8D]
Congratulations to everyone !
Nicolas.
Julian,
Nicolas.
#637
NJ
Hi everyone,
I just joined the ranks of the JL L-39 club.
I'd like to thank Todd from DREAMWORKS for the great service.
I would especially like to thank Nicolas for the beautiful job he did on my equipment tray, it really is a work of art and I would encourage anyone building the L-39 to get the tray. Nicolas service was great and I got it less than two weeks from the time I ordered it, can't beat that!
Thanks again Nicolas for the special engraving.
BRG,
Jon
BRG,
Jon
#640
Yes getting there
I no now what you mean about not being able to preview the pics [&o] I sure [&o]made a bu bu of this same pics twice[&o]I
hope this time you can see the turbine bay[:-]
regards
Andreas
regards
Andreas
#641
Hi Andreas,
I write down the number of the photo I want to upload that way you don't duplicate.(Well so far so good )
You can easily change it by going back into the post & edit it using the edit function top right.
All the best,
John
Nice installation by Julian. He must have left something out
All the best,
John
#642
Hello,
now, the first Albatros in Schallflug colour is flown, mine will follow in 2 weeks.
I use a Engel PMS light for battery management and FX 40 with RX 6014, FASST.
Further I installed the lights from flugmodellbau.de
I have only to balance the plane, all other is adjusted.
Christian
Christian
#643
ORIGINAL: jetjohn
Nothing left out, it´s all in there, even the cables/ecu for the flugmodellbau.de lights
The pilot on the picture must stay outside, "Gil", F 18 pilot from the "enduring freedom operation"......I will install the Camlex cockpit that includes two nice guys.
@ceffi: very nice cockpit!!! See you soon!!Skype?
Kind regards!
Julian
#644
Julian,
Have you flown your L39 yet?
I am still waiting for a break in the poor weather we are having.[&o]
All the best,
John C
p.s. Put my Elite force pilots in. They helped with the balance.
All the best,
John C
#645
Hi,
yes, maiden flight was last thursday.
Throws: ailerons 25mm, expo 30% elevator 20mm, expo 30%
Aileron throws were just perfect, but next time I will set elevator also to 25mm...
Awesome aircraft, smooth flying.....what else do you want? I´m happy!
Julian
Julian
#646
Juts made my cut out on the rudder. Thanks for all the photos guys, made the job alot easier. Next up is to add some carbon and then glue the servo in place.
#647
My Feedback: (36)
What's the final CG location ?????????? flying mine next week, no chance at Florida Jets.........need AMA 40 mph wind certicate to fly..........
#648
Hi
according to Nicolas as per plan I just done mine that way had to add 750 grams at nose to get it to balance right[&o]
that was with a full hopper tank under the cockpit at the rear
regards
Andreas
regards
Andreas
#649
If you want to see a fierce firecat , go to You Tube to Attitude Aviation, and you´ll LIKE IT.
Also the mig down by foamie is in Florida Jets 2008.
Also you can find the firecat at www. firecatjet.com
Hector
Puerto Rico
Hector
Puerto Rico
#650
I recently checked the incidence at the wing tips of my L39 and I was surprised to see that it had 1 degree of positive distortion on the left wing tip. That would explain why it has always needed a small amount of left aileron trim. it also had a tendency to perform better snap rolls to the left than to the right and was very ready to drop to the left near the stall. I was able to straighten this out with a weight to bend the wing tip and use of a heat gun. It could be worth checking this out on all models out there as it may be a mould fault?
The new paint scheme is almost done so I should have some pics next week.
Denny
Denny
