If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 65 of 75 FirstFirst ... 15556364656667 ... LastLast
Results 1,601 to 1,625 of 1865
  1. #1601
    Join Date
    Dec 2006
    harwich, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: What do you think about JETLEGEND L39?
    my controls are on the bottom where the hatch is
    I just ran out of talent !!!!!!!!
  2. #1602
    madmodelman's Avatar
    Join Date
    Oct 2006
    Corby, Northants, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I found it easier to control from the bottom of the wing, more movement, if you look closely you will see the engraving marks on the wings for the hinge positions, they are applied in the mould.
    You may find my build thread useful, link below.
    http://www.rcmf.co.uk/4um/index.php/topic,74291.0.html
    Gary.
    pic courtesy Neil Hutchinson
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Xcalibur+, Javelin, F16, L39, F86, Viperjet & F4.
  3. #1603
    RemoteJets's Avatar
    Join Date
    May 2006
    Huizen, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I also placed them on the bottom the first time but I wasn`t happy with the contruction, throw and play that caused this set-up.
    So I converted them to the original set-up from the top side.
    Throw is more then enough, just like mentioned here in the thread about 72mm I believe, and less play.
    Had to remove some material in the small wing part between the flap and aileron otherwise the flap jammed.
    Grt,
    Berto.
  4. #1604
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You've gone the full size way then
    I had no problems with the way I did it but I did reverse the flap horn to get the throw.
    Yes, because of the taper geometry it is neccessary to remove some material from the flaps, the JL hinges are great though because you can easily remove them to work on.
    Like the colour scheme on your FB L39,very nice.
    I was looking at the Tomahawk ones at Jetpower in the new Brietling scheme, wish I had a bit more cash!
    Brg,
    Gary.
  5. #1605
    Join Date
    Apr 2006
    private, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: madmodelman
    Brg,
    Gary.
    Gary
    we could all do with a bit more cash these days [&o]
    cheers
    Andy
  6. #1606
    Join Date
    Feb 2002
    Salem, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally finishing up my L-39. Any issues/concerns with the stock pipe ? ..... I thought I read something in one of the previous posts but I cannot find it.
    Thanks. Bob
    \" This plan is way too ingenious to fail for the fourth time ..... \"
  7. #1607
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i have a wren 160 in mine and no problems in over a year or so
  8. #1608
    Join Date
    Oct 2007
    sleaford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I also have a Wren 160 in mine and had 128 flights with stock pipe. The JL L39 is a superb, reliable, and excellent flying model which I am sure you will enjoy.
  9. #1609
    Join Date
    Feb 2002
    Salem, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also, when utilizing the fiberglass bypass .... should the turbine mount (JetCat P160) sit on top of the bypass (so that the bypass edges are between the plywood and the turbine mount) ..... or should I trim away the edges of the bypass where the mount is (so that the turbine mount is on the plywood) ? It's only a difference of 1/16 inch (perhaps it does not matter) ....
    I believe the recommended CG (per this thread) is about 6.5 inches back fron the wing leading edge .... is that still the consensus ?
    Thanks again. Bob
  10. #1610
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i have three jl jets and I have not used the bypass on any of them so I can't help you with that one
  11. #1611
    Join Date
    May 2009
    Pembroke Pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same here you want to keep back end lighter no need all that keep it simple and cooler lighter
  12. #1612
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not used one in mine either. My C.G is about 6.25" but 6.5" will be okay. Superb flying model. ENJOY.
  13. #1613
    Join Date
    Feb 2002
    Salem, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the responses guys. I usually only use the bottom half of the bypass .... primarily to protect the items under the turbine from heat. However, this fuse is so big, and there really isn't anything in close proximity to the turbine, I may not use it.
    Hope to fly it next month .... when things finally warm up. Thanks again.
    Bob
  14. #1614
    artchristic1's Avatar
    Join Date
    Oct 2007
    bois des filionQuebec, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys;
    I just got my first JL L-39 from Camlex,
    This plane is much bigger than I thought.
    It is the new version.
    Best buy for the buck I say.
    Well done.
    I will do a first out of the box reveiw later for everyone on Utube.
    Doe's anyone have a cockpit tub for the JL L39 for sale?
    I will pay for the shipping.
    I realy need one.
    So far I like the plane.
    Hope to get it up in the air soon.
  15. #1615
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used the supplied cockpit and just added some detail and paint
  16. #1616
    mdeseve's Avatar
    Join Date
    Dec 2005
    alma, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hope to see it FLY at louiseville.
    Salut
    Jet Central Rabbit, Superbee, kingtech k-80, cheetah, kingtech k-170f...
  17. #1617
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Michel;
    How are you.
    Do you still have your F-4?
    I will fly this plane at the end of july if time permits.
    It is very big but I like it. Just the right size
    to fill up the sky and have fun.
    It will be my work horse of the skies.
    Anyone have a cockpit tub for sale?
  18. #1618
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Scoobydoo;
    You have a Tub for sale
    Is that what you mean?
    The new JL L-39 doe's not come with a Cockpit tub
    You have to buy the full scale detailed cockpit from them.
    I just want any tub for the JL L-39.
  19. #1619
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got a tub from my L39 if it will fit yours.
  20. #1620
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Madmodelman;
    How are you?
    Sure I will try it.
    Can we arrange something
    Is it the JL?
    Let me know what you want to do.
    Life saver you are.
  21. #1621
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used a scale L39 cockpit tub so I have the original spare. Not sure if it fits the new one though.I'll do some pics tomorrow, getting late over here, bedtime!
    Yes its JetLegend.
  22. #1622
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you very much
    I will wait for your response.
  23. #1623
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Had to turn the place upside down to find the tub, as the new version has a different arrangement I'm not sure it would fit so a couple of pics and one of my expensive one lol.
    Gary.
ID:	1884745   Click image for larger version.
ID:	1884746   Click image for larger version.
  24. #1624
    Join Date
    Oct 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Madmodelman;
    It looks great to me.
    If you are willing to part with it, then
    let me know what arrangement you would like.
    I will try to make it fit in my plane.
    Can you e-mail me when you get a chance please.
    brisson.gina@videotron.ca
    Thank you.
  25. #1625
    Join Date
    Nov 2004
    Sao Jose dos CamposSP, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Buddies,
    Does somebody the box size (L x W x H) and weight?
    Regards
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
