jetjoes starters
Old 09-21-2007, 03:55 PM
John Casey
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default jetjoes starters
So.... for anyone thinking about upgrading there airstart turbine with a jetjoe starter,
both the $25.00 starter and the $60 starter have the same Motor..just the bullet nose is longer on the $60 model
otherwise there is no difference. The legs are also the same length and spred.
They are both 6v motors so watch your voltage output.
RK 370SD motors
save your money.... the $60 version "looks "better but internally no more horses under the hood.
There are a great value and will do the job.
John Casey is offline
Old 09-22-2007, 01:37 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: jetjoes starters
Any idea if we could convert an AMT 180 Mercury with one? reason i ask is the front nut is rounded and not pointed.
i3dm is offline
Old 09-22-2007, 04:35 PM
Ruizmilton
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I3dm:
You need to purchase the spinner nut, I used a Jetjoe spinner nut to convert my airstart RAM 750 to auto start
Ruizmilton is offline
Old 09-22-2007, 04:46 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ruiz, did the threads fit as it was ? how can we varify the threads before buying ?
i3dm is offline
Old 09-22-2007, 05:05 PM
Ruizmilton
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have no idea of what the thread gauge is, I just tried and it fit, it's a revese thread, maybe others here can tell if the thread is a standard size, your other option would be to machne the front of the current nut in other to add another piece of aluminum using friction fit and then machine it in the form of a cone, just remember you have to insert a magnet inside the cone for the RPM pickup sensor.
Old 09-22-2007, 05:24 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you advise how to machine it ? im not sure i understand.
Also, is there a way to remove the nut without taking any of the motor parts apart ?
i3dm is offline
Old 09-22-2007, 06:05 PM
Eric D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The JJ nut is 6X1.0 mm left hand thread. Most engines are that size.
Eric D is offline
Old 09-22-2007, 06:11 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still puzzled on my second question though - is there a way to remove the nut without taking any of the motor parts apart ?
Also, can anyone confirm if the AMT Mercury is the same 6X1.0 mm left hand thread?
i3dm is offline
Old 09-22-2007, 06:12 PM
Ruizmilton
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do not know how it is on the AMT, but on the RAM the compressor has a flat side on the front allowing you to use a wrench to hold it, it seems to also be pressure fit or keyed, so it did not loose alignment with the turbine wheel or axle when I removed the nut. I know there is a link here about a guy who builds his own turbines, the website shows how to do the machining and adding the magnet I mention, but I forgot where it is.
Old 09-22-2007, 06:27 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont think ill need to add the magnet, im thinking about converting the current nut somehow and it has its own magnet.
or maybe fitting a JJ one with the magnet already installed.
Maybe i shall remove the current nut, srill and tap it in the center and make an aluminum cone that will thread on it with a center bolt... hmmm..
i3dm is offline
Old 09-22-2007, 11:12 PM
Ruizmilton
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's basically what the machining does, but when you drill you'll run into the magnet, that's why you have to add it to the new part you'll add
Old 09-26-2007, 10:11 AM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The size of the AMT nut (from AMT themselves) is 1/4 inch x 28 UNF left
i3dm is offline
Old 09-26-2007, 10:15 AM
AndyAndrews
AndyAndrews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jet joes start?
AndyAndrews is offline
Old 09-26-2007, 12:42 PM
John Casey
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The nut on the Pegasus was rounded
enough to make good contact with the o-ring with no slippage,
but I shaved a little material off the front of the bendix to
make sure of no metal to metal contact. Like any of the starters centering
and distance set from the front nut is critical.
To really get a good grip, Auto shops sell spray on belt adhesive to keep your belts from slipping and squealing on your car,
put some on a Q-tip and coat the front of the nut and the o-ring. The oring is just a really small belt that grips the nut
... no more squealing starters. Saves on O-ring wear as well.
It turned the motor up faster than the stock starter I have on an another autostart 280.
I don't know about the nut on the mercury.
If you burn up the original motor (RK370SD), the 370c motors
that you find at the local electronic shop will fit
but will not turn motor up to the rpms needed.... so just order a new one.
For $25.00 plus shipping it was fun to play with.
I would not go around machining the nut on the front of the motor as the balance could be way off when you get done.
The starters disengage around 20,000 rpm so trimming the bendix is your safer bet.
Old 09-26-2007, 12:45 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John yes our nut is rounded in the same way.
did you use the JJ starter mount on the Pegasus ?
i3dm is offline
Old 09-26-2007, 12:54 PM
John Casey
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its been set up, I have not used it to start the engine as of yet,
I am using it as a "cooling motor" to save on air after a run
plus an aircraft blower to cool the inside of the plane.
I'm waiting to get the means to "turn down the voltage to the starter"
The AMT autostart ecus put out 12v to the starter and will blown up the jetjoe which is a 6v motor.
(thats how I found out, I blew up my first starter motor, but I had some spares.. so live and learn.)
I have no manual airstart ecus which would support manual operation.
You would have to watch your edt and turn the motor off at 20,000. otherwise it would be just like starting a wren.
The motor will only turn the engine up to around 20,000 by itself, after that is drag.
The stock amt autostart starter motor topped at around 17,000.
Old 12-07-2008, 10:10 AM
MattyC-130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes the JeJoe JJ1800 Bullit starter will work on the AMT Mercury with round compressor nut.
I have all my turbines set up for semi auto start with with eletric starter, I run the starter with a shunt switch. and control gas, fuel, glow plug ignitor manualy, I like to have full control of everything during the start sequence.
The only thing you will need to do is shorten the 3 starter legs so the bendix clutch will make contact with the compressor nut.
Just modded my AMT Mercury last night and tested it. The bendix clutch has no problem grabbing the round nut and spinning the engine with no slippage.
Hope this helps,
Matty
MattyC-130 is offline
Old 12-07-2008, 12:50 PM
Woketman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do not think that you need to worry about adding a magnet in the nut on an old manual air start AMT. IIRC, they have no magnet. The RPM sensor detects the compressor blades passing by it. No magnet is involved. At least that's the way I remember it.
Woketman is offline
Old 12-07-2008, 01:32 PM
i3dm
My Feedback: (51)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Woketman
Thats correct.
BTW - my friend's AMT Mercury has been modified with a JJ1400 starter and its working great.
i3dm is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
