Ducted Fan Fuel
Ducted Fan Fuel
DF engines run on high compression, like the engines designed for helicopters. Because of that, the generate more power, more heat, and more stress on the parts. I like to run a lot of castor to protect the piston/cylinder. It gums it up a bit, but I'd rather clean that replace.
The WildCat 5% is a good choice--lots of lubrication there. Its cheap and makes 'em go like hell.
Ducted Fan Fuel
Vinny,I like to use Wildcat 5% for my oOS 91 & Wildcat 10% for BVM engines and K&B. Lots of oil and a good smoke trail to let you know if engine is still running.
My Feedback: (7)
DF FUEL
If you are runing O.S.91w/dynamax fan I highly recommend Ritches Brew 10% nitro, 22 % oil ( 11/11) 11 castor, 11 synthetic. It has been exellent in my DF,s for many years.. I is also a lot less expenseve than Wildcat & others. It is manufactured in the Houston area, & is available in alot of hobby shops.. Mike's hobbies is in Dallas, sells it for $9.50 a gallon(last time i bought it)
Great stuff, never lost a rod or piston yet!! My .02 cents worth!!
Regards
Dan M.
Regards
Dan M.
My Feedback: (8)
What Ducted Fan Fuel
A couple of us in the St. Louis area have been using Magnum 5% and 10% fan fuel. Works great, and is extremely clean burning. We have to order it from Denver where it is made since none of the area shops carry it. As a matter of fact, now that I think of it, ducted fan fuel of any brand is very rare in st. Louis area shops.
