Reload this Page >
Skymaster F14 Tomcat
Old 03-30-2016, 11:23 PM
  #1601
WimB
WimB's Avatar
Originally Posted by FenderBean
The gear on mine has been a big issue as well, did SM send you the updated air lock cylinders? If so do you still need to slow the gear coming down? With my mechanical valves not sure how to slow down one side unless I can put some type of servo travel slow on one direction. Danny Diaz made a stop bracket for his I thought about trying that method. I have two valves for the mains with both feeding the nose.
Fender,
Updated lock cylinders??
I had the shaft on mine tear out of the piston when slamming down.... there should indeed be a mechanical stop to prevent these forces going to this tiny cylinder.....
Wim
Old 03-30-2016, 11:24 PM
  #1602
phantom_najd
Originally Posted by Zeeb
My builder guys changed out the Jetronic valve on the retracts to a mechanical so it'll leave air pressure on the gear
Jetronic closes the valve after retracting or extending the gears as a fail safe measure (so that the system won't lose air even if it has leaks in the cylinders or the tubes), they assume that the landing system will depend on the mechanical locking mechanism. You can turn off this fail safe feature by a programming procedure explained in the valves manual; I know because I had to turn off the fail safe function of the valve on one of my jets right after losing one gear door because one of the mains collapsed on the runway.
Azzam
Old 03-30-2016, 11:25 PM
  #1603
marquisvns
marquisvns's Avatar
Barry like said I already knew about your issue from your post, not trying to make you mad. The other unknown crashes are the ones I was curious about. Thanks
No worries Keith, I replied by simply referring to those posts and discussions.
Anyways, here it is again just in case, choose a JR compatible arm and cut them short would be the way to go, in my opinion - "maintaining the integrity of stab servo arm is paramount!"
As with flap slop, I had two pieces of brass plates glued into the slot and worked great!
Barry
Old 03-31-2016, 08:05 AM
  #1604
FenderBean
FenderBean's Avatar
Thanks Barry, a part of me wants to swap to a JR servo but with my current setup is futaba, I will roll with what I have an work on finding a replacement for futaba. The SWB is too thick, but maybe I can send him one of mine and have him make one.
Wim sm said they had a batch of bad lock cylinder and they sent me a new set. They have longer threads on the end
Old 03-31-2016, 08:26 AM
  #1605
marquisvns
marquisvns's Avatar
I'm sure you'll sort it out!
Old 03-31-2016, 09:52 AM
  #1606
WimB
WimB's Avatar
hey Fender,
Thx for the heads up. I'll guess I'll have to drop Anton a line, since moving and changing jobs both my adress and mail have changed....
Regards,
Wim
Old 03-31-2016, 09:56 AM
  #1607
FenderBean
FenderBean's Avatar
Originally Posted by WimB
hey Fender,
Regards,
Wim
I would talk to John, hes much easier to get in touch with and normally handles these type of things anyway.
Old 03-31-2016, 10:05 AM
  #1608
WimB
WimB's Avatar
Fender,
I'm afraid I don't have contact details for John anymore since changing jobs (and computers....)
Wim
Old 03-31-2016, 12:08 PM
  #1609
dubd
dubd's Avatar
Fender,
Wim
John's email address is: [email protected]
Old 04-01-2016, 03:31 PM
  #1610
FenderBean
FenderBean's Avatar
well broke another lock cylinder today just working the gear manually on the table, looks like the only way to get these things to work is with the airtronic valves so you can set a slow on the gear down. I wonder how SM delt with this issue?
I also just put a inline restrictor on the line the extends the gear, it doesnt seem to slow it much.
Old 04-01-2016, 04:32 PM
  #1611
Bobneal1
My Feedback: (21)
If you put a restrictor in the line with another valve to bypass it in the retract direction, that will give you two different speeds
Old 04-01-2016, 07:12 PM
  #1612
FenderBean
FenderBean's Avatar
Cool idea but at this point I think its easier to get two Jettronic valves and throttle the down only. The gear seems to close up now just fine even at pressures as low as 70 psi
Old 04-03-2016, 03:18 PM
  #1613
current control
Well haven't had a issue with this until today
broke 6 plastic ball links- no fun at the field
i think I have a fix
the bvm f-16 (jets legend) has metal ends on the gear door cylinders that are the same threads as the cylinder output rod ,this works ,may have to squish in a vise
it does not need to be a ball link as all travel is linear
bonus it's the righ t length
bonus you can put a spring on it from a ball point pen for positive locks with air off.
note put air restrictions on the down stroke
fixed this and broke a cylinder in half (poor threats contact)
Old 04-03-2016, 03:33 PM
  #1614
FenderBean
FenderBean's Avatar
I think this will fix breaking the plastic end but if I remember correctly this causes the air cylinder to pull apart. Not 100% sure but I think someone mentioned it, but it still be nice to have a metal end for added strength.
Old 04-10-2016, 06:33 PM
  #1615
dboyle
My Feedback: (58)
Has anybody used the xicoy CG machine on there F14?
if so, can you share your input data? Even if there is a couple of people with different numbers based on your CG, I'll take them all.
Thanks for any inputs.
Old 04-11-2016, 07:04 PM
  #1616
pilot tw
Nice color scheme for F-14
ID:	2156961   Click image for larger version
Old 04-11-2016, 07:28 PM
  #1617
dubd
dubd's Avatar
MK2! Can't wait to receive it!
Old 04-12-2016, 02:50 AM
  #1618
Levi Wags
Levi Wags's Avatar
You jump back on that horse D man. Great to see buddy. Love that scheme too.
Old 04-12-2016, 05:40 AM
  #1619
dubd
dubd's Avatar
Better late than never!
Old 04-12-2016, 09:24 AM
  #1620
ravill
ravill's Avatar
Can't wait to fly with my wingman again!!!
We are gonna have lots of great flights D!!
Old 05-11-2016, 12:56 PM
  #1621
FenderBean
FenderBean's Avatar
Needs some info from folks flying this thing, do you need the full 115 mm on elevator and 93 mm for ailerons?
I have no trouble getting these throws with my servo endpoints out to 135% but im just wondering if its needed? Stretching out the servo throw like this is much better on the servo and helps with even wear and lets you get the best response from the servo. I know when the wings are back you only need about 20% of the overall throw.
For those with gears issues still it looks like the air valve throttle on the down to about 7 secs is the ticket, im still working turning this function down or off in the up position but still works. I am also adding this to the gear doors so they dont slam like crazy. Thanks
Old 05-26-2016, 05:25 AM
  #1622
vatechguy3
Is it possible or has anyone converted to electric retracts?
Tony
Old 05-26-2016, 07:39 AM
  #1623
FenderBean
FenderBean's Avatar
Tony
due to the designs the main gear is just about impossible without some redesign.
Old 05-26-2016, 04:27 PM
  #1624
current control
found a good fix
hysol or jb weld both ends on the main gear small locking cylinders
on the down air line side before the y use robart adjustable bleed valves, they have neat festo fittings on both ends and a dial on the top you can adjust the amount of restriction.
this does not seen to affect the up stroke as much as a standard double nipple restrictor, tried that it did not work.
hope this helps.
Old 05-26-2016, 05:39 PM
  #1625
FenderBean
FenderBean's Avatar
best thing I have seen so far is what i switched mine to, Jetronic valves with the throttle function is a winner
