Reload this Page >
PST F-84G Build Thread
Old 02-17-2010, 08:59 AM
  #401
chrigui
Default RE: PST F-84G Build Thread
modified trust tube
Old 02-18-2010, 02:34 AM
  #402
Stratotanker
Wish I could see the pictures, I am gettting X's
Old 02-18-2010, 03:01 AM
  #403
chrigui
HELLO....
pic's about?
Old 02-22-2010, 03:03 PM
  #404
chrigui
other little work (to be finished)
Old 02-26-2010, 01:47 AM
  #405
chrigui
radio bay access completed
Old 03-06-2010, 12:34 PM
  #406
chrigui
First roll out to test engine, rx 2,4 ecc
wheigt 16kg empty, no warm in trust tube zone with tube modify
next time first flight..
Old 03-07-2010, 09:17 AM
  #407
B777
Very very nice....
Old 03-07-2010, 12:44 PM
  #408
chrigui
many thx...i'm waiting air trap from you
ciao
Old 03-07-2010, 04:20 PM
  #409
oistein
oistein's Avatar
Hi,
Could you please tell me how you modified the thrust tube. Very interested...
Thanks a bunch
Old 03-08-2010, 05:30 AM
  #410
chrigui
simply i added the external tube to cover the trust tube like previous pics
http://img30.imageshack.us/img30/9326/hpim1639g.jpg
Old 03-12-2010, 11:15 AM
  #411
chrigui
many tanks to PST JET for customer service, very fast delivery and shipping...
Old 03-19-2010, 07:05 AM
  #412
argyris
argyris's Avatar
STRATOTANKER THIS IS THE MEAN OF THE WORD -SCALE.AWESOME ,SUPERB,EXELLEND,SPEECHLESS,.......TALEND.X FACTOR BUILD.
Old 03-19-2010, 07:49 AM
  #413
K.Nielsen
My F-84G will also soon be ready to test fly, with all the update recommend by Oliver and Chris.
Thanks Oliver and Chris for share all your building info with us.
Now I am just wating for Chris to come home, so he can make a set of his rotating main doors mechanism for me.
Old 03-19-2010, 10:25 AM
  #414
Stratotanker
argyris,
Thank you!
Old 04-01-2010, 01:01 AM
  #415
chrigui
i moved from original gear to ROBART RS635 (modified) and them work wery well (at 0.5bar) with EV5U valve.
Old 04-02-2010, 05:29 AM
  #416
Stratotanker
Doing some retract work in Kyrgyzstan! Winter was tough on the old girls struts!
Chris
ID:	1409951   Click image for larger version
ID:	1409952   Click image for larger version
ID:	1409953   Click image for larger version
ID:	1409954   Click image for larger version
Old 04-02-2010, 06:39 AM
  #417
chrigui
Robart???
Old 04-02-2010, 06:54 AM
  #418
Tango Juliet
Tango Juliet's Avatar
Things don't change much in the good ole AF . We used the same blue panel trucks for Bomber Maintenance in Min(dr)ot, ND.
Old 04-02-2010, 09:24 AM
  #419
Stratotanker
635's indeed haha! Those old blue trucks are crazy, horn goes off when you turn the wheel, lights are off when the switch is on!!! The jets still get it done on a daily basis though!!! Almost time to go home!!!
Old 04-06-2010, 11:59 AM
  #420
chrigui
i finished the model and it's ready for first flight
the weight is 15kg + 1,2kg nose ballast with full bubble trap
Old 04-13-2010, 01:28 AM
  #421
chrigui
here the simply solution for main gear panel
Old 04-21-2010, 02:20 AM
  #422
chrigui
finally flew my f84g
home build 160 turbine downrated at 14kg (115.000rpm) to preserve it
very stable in the air, slow landing, it flew well with 1/3 of throttle..
long take off (100mt) maybe due to cg very forward 110mm
with a full tank fuel should be much force on the tail plane for the rotation
I'll try to change the cg at 120 / 125mm removing 200g from the nose and change the AOA reducing diameter wheels with lathe
what type of hard rubber was used on the front gear to sobstitute the original sullivan??
Old 04-23-2010, 06:12 AM
  #423
chrigui
i put some modify on my plane like Oliver indications.
i moved down the front gear system add 1cm lenght nose
i reduced the main diameter wheels from 115mm to 105mm
i modified original brake and cleaned it from grease ..
i removed 200g of ballast in the nose
then i will try to take off with 50% main tank full (like sm f-86 1/5 cg problem)
many thx for indication to Oliver and Chris
Old 05-16-2010, 05:07 AM
  #424
grahamaberdeen
hi chris ,
mine in sprayshop just now should be ready for dave wilshire to maiden for me at the scottish heli nats in july (sorry for using that swear word there)
be great to get you back here on forum with your next build, me and her indoors just back from 6 weeks in thailand, and the events here now happening each weekend so ill keep you up to date with the pics etc
graham
Old 05-16-2010, 11:01 AM
  #425
Stratotanker
Graham ,
Good to hear, what scheme did you go with?
Chris
