Reload this Page >
PST F-84G Build Thread
Old 05-31-2008, 09:45 PM
  #101
Stratotanker
Default RE: PST F-84G Build Thread
I miss that plane, was a pain in the backside at times but well worth the effort. Thanks for letting me experiment on your baby!
Chris
Old 05-31-2008, 09:55 PM
  #102
B777
Hi Steve,
Yes, we are seeing the ram-air resistance on customers' F-84Gs fitted with main gear doors. On our F-84Gs, we made spring-loaded swivel gear doors (for scale) that coincidentally neutralized the ram-air effects and we also used 120+psi pressure which helped to take the gears in. The 2nd F-84G has the doors removed due to some damages and not because of the ram-air. However, we are designing a new and larger retract cylinders to get more pulling strength. When this new design is finished, we will send them to all F-84G owners.
Regards,
Kraivuth S.
Old 06-01-2008, 02:38 AM
  #103
Stratotanker
Ok, here is how far I go tonight. just need to figure out a way to bolt the lower tank in place and build header tank mounts. Once all that is done, I can start dumping components in and moving them around to work the CG as I bulid.
Chris
ID:	961328   Click image for larger version
ID:	961329   Click image for larger version
Old 06-01-2008, 02:40 AM
  #104
Stratotanker
more
ID:	961331   Click image for larger version
ID:	961332   Click image for larger version
ID:	961333   Click image for larger version
Old 06-01-2008, 02:41 AM
  #105
Stratotanker
Last ones for tonight.
ID:	961335   Click image for larger version
ID:	961336   Click image for larger version
Old 06-01-2008, 09:02 PM
  #106
Stratotanker
Lower main tank installed, just have to get the header tossed in!
Chris
ID:	961822   Click image for larger version
ID:	961823   Click image for larger version
ID:	961824   Click image for larger version
Old 06-03-2008, 10:37 AM
  #107
Aquilon
Aquilon's Avatar
Hello All,
There is now some PST F84G in flying condition.
Could you please confirm me the dry weight of this plane ? And the amount of nose lead for correct balance if required.
Thanks.
Stéphane
Old 06-04-2008, 01:14 AM
  #108
Stratotanker
Here is the last of the fuel system install. Took some shoe horning to make sure the canopy mechanism would clear everything. Starting to lay out radio and turbine components now to see what I am working with then it is on to getting rid of those nasty hatch latdhes and coming up with something that is concealed, once that is complete, it is on to the wing pylons and releaseable ordinance!!!!!
Chris
ID:	963379   Click image for larger version
ID:	963380   Click image for larger version
ID:	963381   Click image for larger version
ID:	963382   Click image for larger version
Old 06-04-2008, 04:33 PM
  #109
RC_MAN
Is the nose gear OK? just the main cylinders need replacing. Are you sending out complete retracts or just the cylinders. I'm getting close to test flying mine.
Peter D.
Canada
Old 06-08-2008, 02:58 AM
  #110
Stratotanker
Well, herre is how th ebatteries will be installed. I removed PSTs stock mounting trays to do my own thing to get the weight transffered to the front.
Chris
ID:	966144   Click image for larger version
ID:	966145   Click image for larger version
ID:	966146   Click image for larger version
Old 06-08-2008, 03:01 AM
  #111
Stratotanker
some more
ID:	966154   Click image for larger version
ID:	966155   Click image for larger version
ID:	966156   Click image for larger version
ID:	966157   Click image for larger version
Old 06-08-2008, 03:04 AM
  #112
Stratotanker
time for bed!
Old 06-08-2008, 05:23 PM
  #113
Stratotanker
Voltage regulators going in.
ID:	966533   Click image for larger version
ID:	966534   Click image for larger version
ID:	966535   Click image for larger version
Old 06-10-2008, 01:50 AM
  #114
Stratotanker
Here is tonights progress, wanted to get the power distribution figured out. I have five more leads to build and install and then I can start tinkering with turbine components followed by pneumatics and fuel system.
Chris
ID:	967765   Click image for larger version
ID:	967766   Click image for larger version
ID:	967767   Click image for larger version
Old 06-10-2008, 12:11 PM
  #115
Chris Nicastro
Chris Nicastro's Avatar
Looks awesome Chris!
Cant wait to paint it!!
Chris
Old 06-10-2008, 07:16 PM
  #116
Stratotanker
Get your behind over here and help me finish her! I want to do the Panther at the same time.
Chris
Old 06-11-2008, 12:57 PM
  #117
Chris Nicastro
LOL ok will do, more beer?
Call you later!
Old 06-11-2008, 02:30 PM
  #118
Stratotanker
Never turn down the magical elixir! Got a LOT of stuff to do in a very sshort time!!!
Old 06-23-2008, 10:08 PM
  #119
samo
Chris,
I love what you did to the nose compartment. I probably wouldn't need so much "catfish lead" if I would have placed my batteries where you did []
Finally modified the gear plates and locked them in with CF plates. She's ready for another voyage -
Steve
Old 06-24-2008, 12:47 AM
  #120
Molar mender
Molar mender's Avatar
ORIGINAL: samo
Steve
Got any photos, would love to see what your mods look like and how it turned out.
Roy
Old 06-24-2008, 07:46 AM
  #121
Tango Juliet
Tango Juliet's Avatar
Thank you so much for this build thread. I've built models for years and am still nowhere close to being able to produce the quality of workmanship that you display. I am in awe! The pictures always teach me something new to attempt even in my sport models as far as setup and running wiring. The tidyness of all that wiring is to be commended. Keep posting and I'll keep wiping my chin!
On a side note, I was ADAF as a mechanic on B-52's and B-2's. I was never stationed at Fairchild, but did a few TDY's there and always enjoyed it. I even got to spend some time out in the mountains for some training I needed for a crosstrain into helicopter flight engineering.
Old 06-24-2008, 05:01 PM
  #122
Stratotanker
TJR1, Thanks for the compliments! I will be hitting it pretty hard over the next couple of days so I hope to have some pictures updated. I will definately be revisiting the main gear plates and am istalling 635 Robarts. Steve, would like to see what you did to the plates so we can compare notes.
Chris
Old 06-25-2008, 11:29 AM
  #123
olnico
olnico's Avatar
ORIGINAL: Stratotanker
I will definately be revisiting the main gear plates and am installing 635 Robarts. Steve, would like to see what you did to the plates so we can compare notes.
Hello Chris.
Installing the Robart 635 RS is a wise choice. In fact it is the only possible choice.
The original mechanism is totally useless. I have tried to modify it to make it work but the pistons are leaking...
So I droped this project after about 30 hours of hard work and tried different mechanisms.
300 dollars later and after the wise recommendation of Barry, I tried the 635 RS. Bingo !!!
Big pistons, big trunion arm. Oversize square brass trunion slides. The heavy main gear is retracting at 60 PSI vs the original requiring 160 PSI to merely go up...
After 2 months of fiddling around I know that I now can retract the gear in flight !
The main gear plate design is amazingly wrong. Beginners mistake. Unbelievable.
The torsion effort induced by the main gear will almost certainly unglue the plate at the first hard landing and ruin the wing sandwich.
Here is my design modification:
No need for carbon fabric reinforcement: The idea is to connect correctly the front plate to the oversized gear ribs.
The same plywood reinforcement goes on the outer rib. It is a bit difficult to Hysol due to the room restriction.
Concerning your work, congratulations. It is beautiful.
Just one remark: keep it light. A scale F-84G will easily hit the 45 lbs barrier and need a 160 N class engine.
Another remark: the cooling design at the rear of the plane is minimal: I have recorded inner temperatures in excess of 300°F in the tail area.
Check your plastic tanks empty first to make sure you're not gonna melt them at the first engine start and during taxi.
This plane is an amazing flier: I've had an engine flameout in a low level roll, I managed to land on my feet. It is a true glider...
It performs all the conventional aerobatics in a beautiful old fashion way and is very impressive by it presence in flight.
lands like a pattern flier as well:
Check my article in the next RCJI issue for a complete build report and more.
Old 06-25-2008, 04:15 PM
  #124
olnico
olnico's Avatar
Here is the 635 RS installed ( gear not fully slided in )
This requires a lot of adaptation work. All the plywood parts have to be machined including the outer rib ( check the picture ).
I have placed a big carbon roving along this rib to reinforce it.
The 635Rs itself is modified: shortened and reinforced.
The unit is very good: bigger piston, no leak, bigger arm, smooth operation.
The gear will retract and lock with 40 PSI of air.
From 100 PSI to 50 PSI ( Tam failsafe setting ) I have 5 full extend/retract cycles available with a very high power.
Beautiful.
Now I can start to concentrate on the finishing...
Old 06-25-2008, 11:58 PM
  #125
samo
I agree with you regarding the gear plates. They are seriously wrong. Per the advice of Molar mender (thanks Roy), I rebuilt the gear plates with ply and carbon fiber and lengthened them so that they extend beyond the wing ribs. I then sandwiched them with laminated 1/8" x 1/2" carbon fiber glued and screwed to the top part of each rib. We took the jet out this afternoon to try it out. They're so much stronger now. I also shimmed the aft part of the retract with 1/8" ply to rotate the strut forward so it's more perpendicular to the wing. Not only did this make it stronger, it really improved the take off by changing the moment of rotation of the nose. We put on 2 flights but we're still having trouble with the gear retracting. I'm using 120psi and 2 large tanks for volume. It's really frustrating. ( PST needs to get it together and provide some equipment that works! ) Hopefully they'll get the "new and improved" retracts out soon so we can finally enjoy all aspects of this jet. By the way, I agree that it (even with the gear down) flies and lands nice.
Here's a few pics:
ID:	978694   Click image for larger version
ID:	978695   Click image for larger version
ID:	978696   Click image for larger version
ID:	978697   Click image for larger version
