PST F-84G Build Thread
Old 07-22-2008, 07:49 PM
  #151
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: PST F-84G Build Thread
Well, it took a couple days to figure out the fins but I have a good start. I just need to refine the design a little to make them a little more user friendly.
Chris
ID:	995843   Click image for larger version
ID:	995844   Click image for larger version
Stratotanker is offline
Old 07-22-2008, 07:51 PM
  #152
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a few more and bomb #2 in the mold...
Chris
ID:	995850   Click image for larger version
ID:	995851   Click image for larger version
ID:	995852   Click image for larger version
Old 07-24-2008, 10:05 PM
  #153
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been bouncing around doing different things since the bombs are figured out. I decided to finish up the main retract installation and shave the tires down to increas the AOI on the ground. I had to first machine a simple tool to hold the wheel assembly in the lathe and then it was off to sanding! I hope to finish mounting the pylons tonight ans start on wing tank installation.
Chris
ID:	997047   Click image for larger version
ID:	997048   Click image for larger version
ID:	997049   Click image for larger version
Old 07-25-2008, 05:29 PM
  #154
Shok
My Feedback: (28)
Shok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very cool!
Shok is offline
Old 07-25-2008, 10:48 PM
  #155
Kevin Greene
My Feedback: (85)
Kevin Greene's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since the Robart 635 gear seems to work well-Could Robart 1/2" struts be used instead of the PST scale struts???-This would make for a good model for someone that doesn't require Top Gun quality scale gear for the every day sport flier...Offset struts for the mains and a forked strut for the nose....How many degrees does it take to tuck the nose strut into the fuselage-Would a 90 degree retract work???
Kevin
Kevin Greene is offline
Old 07-28-2008, 11:43 PM
  #156
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin, I see no reason that robart struts would not work. I did find however that the 635s had to be shimmedto keep the wheel from contacting the inner wheel well, not a big deal though. I am not sure on the retraction angle on the nose, have not messed with it too much lately, trying to get these mains and doors finished up. Maybe PST can chime in on the retraction angle????
Chris
Old 07-28-2008, 11:49 PM
  #157
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As I mentioned in the previous post, I had to shim the main retracts a bit for proper function. In doing that, it affected the way that the doors operated so I got to start all over on the strut door!!!! As I was beginning to deal with the strut door again I was hating the angle that it sat at and was thinking of all the retraction issues and an idea popped into my head. I got to thinking of a way to have the door parrallel with the airplane when it was extended and fit flush when the gear came up and locked. After many hours thinking of a simple, light and clean way to do it, this is what I came up with...
Chris
ID:	999876   Click image for larger version
Old 07-28-2008, 11:51 PM
  #158
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, so the first try failed, had to tweak it a bit...
Chris
ID:	999878   Click image for larger version
ID:	999879   Click image for larger version
ID:	999880   Click image for larger version
Old 07-28-2008, 11:56 PM
  #159
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like it is going to work!!! I still have some refining to do to get it where I want it. Until next time!
Chris
ID:	999884   Click image for larger version
ID:	999885   Click image for larger version
ID:	999886   Click image for larger version
Old 07-30-2008, 07:48 PM
  #160
samo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chris,
PST ought to be kissing your hiney for coming up with this innovative solution! Thank you for your inventive and creative work to refine this model into the awesome jet that it was intended and represented to be. The scale features that I have purchased from you have been well worth it and have really enhanced the quality of my F-84. As far as I'm concerned PST's complaint dept. needs to hire your services at a premium .
Steve
samo is offline
Old 07-31-2008, 10:04 PM
  #161
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, this should be the final version...
Chris
ID:	1001701   Click image for larger version
ID:	1001702   Click image for larger version
ID:	1001703   Click image for larger version
Old 07-31-2008, 10:19 PM
  #162
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and a few more with the latch.
Chris
ID:	1001712   Click image for larger version
ID:	1001713   Click image for larger version
Old 08-03-2008, 05:35 PM
  #163
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Switching gears a little. I wanted to get back in CAD and knock out some of the other little mounts that I will need. Bombs are being assembled today so I wanted to build the release trigger. This design will allow the bombs to be released one at a time.
Chris
ID:	1003665   Click image for larger version
ID:	1003666   Click image for larger version
Old 08-04-2008, 07:10 PM
  #164
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is one of the bombs roughed out and fitted to the release.
Chris
ID:	1004618   Click image for larger version
ID:	1004619   Click image for larger version
Old 08-07-2008, 09:32 PM
  #165
samo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOVE the BOMBS!! Nice work.
samo is offline
Old 08-18-2008, 08:53 PM
  #166
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am nearing the home stretch finally!!! I have started to concentrate on the system installation in the past week. I am shooting for systems completion before my deployment, all that will be left is the paint job when I return in January. Here are a few pics of electrical, and pneumatic stuff in work. The gear valve mount took a while but is working flawlessly, I have installed a micro switch that will open the circut to the lights and canopy system when the gear is retracted, better safe than sorry!!! More to come soon....
Chris
ID:	1014419   Click image for larger version
ID:	1014420   Click image for larger version
ID:	1014421   Click image for larger version
Old 08-18-2008, 08:56 PM
  #167
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some more.....
Old 08-18-2008, 09:00 PM
  #168
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oops
ID:	1014431   Click image for larger version
ID:	1014432   Click image for larger version
ID:	1014433   Click image for larger version
Old 08-19-2008, 04:18 PM
  #169
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plugging along, here are a few pics of stuff getting shoe horned in the nose. Fuel Shutoff bracket is also complete. Off to design the Speedbrake valve mount!
Chris
ID:	1015059   Click image for larger version
ID:	1015060   Click image for larger version
ID:	1015061   Click image for larger version
Old 08-22-2008, 10:56 PM
  #170
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, the carnage continues in the nose but I am getting close. Cramming the air fill valves and gauges has been a serious pain in the backside but I finally have the part small enough to house them under the hatch. The brake valve is the only thing to mount and should drop in above the receiver(I hope).
Chris
ID:	1017110   Click image for larger version
ID:	1017111   Click image for larger version
ID:	1017112   Click image for larger version
ID:	1017113   Click image for larger version
Old 08-23-2008, 12:35 AM
  #171
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FINALLY!!!!!, This little mount is complete and fitting. I think I will tinker with the fuel system a bit.
Chris
ID:	1017169   Click image for larger version
ID:	1017170   Click image for larger version
Old 08-23-2008, 12:41 AM
  #172
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And one last one from the top.
Old 08-23-2008, 02:40 AM
  #173
ianober
My Feedback: (12)
ianober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW[X(]
ianober is offline
Old 08-23-2008, 02:56 AM
  #174
Stratotanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My brain hurts!!!
Old 08-23-2008, 07:48 PM
  #175
Wildcard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought I would mention in case any of you wished your plane could look like that is...he is available for hire. [sm=wink_smile.gif]
Wildcard is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
