Reload this Page >
BD-5J Project
BD-5J Project
Old 06-12-2012, 06:55 PM
  #151
FormerCA.
My Feedback: (8)
Default RE: BD-5J Project
Frank
Question
How does the JC Rabbit compare to the Jetcat P100? This Gen2 version is supposed to be a couple pounds lighter.
Thx
Ron
Old 06-15-2012, 02:32 PM
  #152
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
ORIGINAL: FormerCA.
Frank
Question
Thx
Ron
Ron,
Actaully the JC rabbit is too mch at 20#. I only used full throttle for take off, then I leave the throttle at 5/8. You can do what every you want at 5/8 throttle. BTW if you go this route (20lbers+) you need to redo the thrust line or you will have trouble. I have a post here showing what I did to change it (post #139)
Frank
Old 06-15-2012, 03:22 PM
  #153
BluFox
My Feedback: (10)
Hello Ron:
Our Jet Central Rabbit 100 develops 22.5 lb thrust at 6000 feet. This is real thrust. The turbine weighs 2lb 3 oz. all up and averages 7 oz per minute. It is full auto kero start. The start takes about 40 seconds on the average.
This Rabbit 100 is delivered in ks start mode however, gas start is also programmed in the FADEC. Simple change over for those who wish to use gas as their choice for starting.
Side by side, the Rabbit is smaller than its competitors, generates more "real thrust" and is as user friendly as one could want. Reducing thrust takes less than a minute. A thrust / RPM chart is included in every manual. A thrust reduction to a suitable wide open throttle thrust for the BD-5 does not in any way affect any other operational parameter.
We will be offering a Show Special at Jets over Kentucky. . .you may purchase even if not in attendance.
Thanks for the question. . .
Regards,
Eric Clapp
Managing Director
Old 06-15-2012, 07:44 PM
  #154
FormerCA.
My Feedback: (8)
Frank
Thanks for that info, I read your mod post very carefully and I intend to follow it by the letter. This Gen 2 BD is supposed to be a couple pounds lighter, I had already went with the Jetcat P100. Already looking down the road to another jet, so I will definitely be looking at the Jet Cental turbines.
I'll keep you guys posted with build pics and detailed data when the build begins.
Ron
Old 06-15-2012, 07:48 PM
  #155
FormerCA.
My Feedback: (8)
Eric
I really appreciate your response and all the info. It really speaks well of a product when potential customers can get a response from a manufacturer like the one you provided. While I missed you on this purchase, you probably just sold another engine down the road on one of my future projects.
Thank you sir
Ron
Old 07-15-2012, 12:49 PM
  #156
FormerCA.
My Feedback: (8)
Got the shipping notice on the P100 Jetcat-it will be here on the 18th, havent heard on the BD5 yet. Already have the Jetcat smoke pump.
And were waiting...........................
Ron
Old 08-24-2012, 03:32 AM
  #157
FormerCA.
My Feedback: (8)
Shipping notice received, plane on the way.
Old 08-27-2012, 06:56 PM
  #158
rick hamel
Bds are always a great project-with the straight wing they fly wellhere is a pic of a 55% I designedfull motion stab-nomex construction-jetcat power
ID:	1795929   Click image for larger version
Old 08-27-2012, 08:37 PM
  #159
invertmast
My Feedback: (23)
invertmast's Avatar
Great looking BD rick, do you own the molds to that? If so, would you be interested in providing a short kit? I love BD's and yours looks to have the most accurate outline.
Thomas
Old 08-28-2012, 05:35 PM
  #160
rick hamel
I was planning to-but my plate is so full right now I could screem trying to get the batwing ready for Toledo this yeareventually I'll be laying them up-the unit you see is all composite Nomex construction (same as dragon) I'm currently switching out the robart struts for trailing link
Old 08-28-2012, 05:37 PM
  #161
rick hamel
And yes They are my molds
Old 08-28-2012, 05:51 PM
  #162
rick hamel
You know as far as scale goes I stuck with Byrons shape-the exhaust in true scale would be smaller but then it would be too small for the 400 AMT I installed in mine. Besides I really like the look of the larger exhaust tube over scalemy 2 cents
Old 08-28-2012, 06:45 PM
  #163
invertmast
My Feedback: (23)
invertmast's Avatar
Rick,
Sounds good. When you get around to doing some short/full kits count me in on one. Matter of fact, if your interested, i could work on doing some scale main/nose gear cad drawings. Ive got a good bit of full-scale Bd5 experience (i have built 4), so it would be pretty simple to do the cad work.
Thomas
Old 08-29-2012, 01:58 PM
  #164
rick hamel
Cool!-but how bout some CNC gear for this
Old 08-29-2012, 05:57 PM
  #165
rick hamel
Here are some pix of the original foam plug of the 55% sacrificed a byron bd (got the molds so I didn't care) to generate the sections for scalingalso the finished model other than paint
ID:	1796565   Click image for larger version
ID:	1796566   Click image for larger version
Old 08-29-2012, 08:48 PM
  #166
invertmast
My Feedback: (23)
invertmast's Avatar
Rick,
Send me a pm with what kind of gear design you want for the beast and i will see if i can work something out . I can do the cad design, but the actual machining i dont have the abilities for currently.
Thomas
Old 08-30-2012, 05:16 PM
  #167
rick hamel
I was just kidding -the dragon uses carbon/Kevlar flex plates
Old 08-30-2012, 08:11 PM
  #168
invertmast
My Feedback: (23)
invertmast's Avatar
Ahh ok.. i was wondering what could of been CNC'd on that thing. lol
Old 10-17-2012, 04:41 PM
  #169
Kevin East
How much weight did you guys flying the Skymaster version have to add in the nose?
Kevin
Old 10-18-2012, 02:05 PM
  #170
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
I had a A123 pack, the duralite pump 4300mah pack, and a nicad 5 cell (3000mah, C cell size), plus 1-2lbs of lead in the nose.
Old 10-19-2012, 04:01 AM
  #171
Kevin East
Thanks, that is what I'm finding also.
Kevin
Old 10-23-2012, 02:26 PM
  #172
FormerCA.
My Feedback: (8)
Hey Kevin
I found the throws frank is using and someone on here said the cg is at 4 3/4 aft the leading edge at the root. Looking forward to getting her maidened this hitch home. Thanks so much for all your great work.
Ron
Old 10-23-2012, 02:28 PM
  #173
FormerCA.
My Feedback: (8)
Photo as it left the factory
Old 10-23-2012, 02:30 PM
  #174
FormerCA.
My Feedback: (8)
Another
Old 10-24-2012, 07:40 AM
  #175
FormerCA.
My Feedback: (8)
The astute viewers on here will be able to notice no provision for a rudder servo. One of a few things that can be improved on future versions.
