turbine location on the 1/8 F16
Hello,
Do you have some experiment of turbine location on the 1/8 F16 (JL, skymaster...etc) : on the center, with tail pipe, or in the tail, without tail pipe?
Wheight in front? flight characteristic?
Merry christmas,
Sébastien
Merry christmas,
Sébastien
RE: turbine location on the 1/8 F16
Hi, on the JL you can only install the engine on the center. On the SM, you may choose but it will depends which engine you have. If it's a lighter one, you can put it on the tail, if it's a havier one , better put it on center for more precisely GC alignment.
Regards.
Achilles.
Regards.
Achilles.
hello,
it's a lighter engine of course (P60/simjet1200/JJ1200..etc) not P80/ k66 like
My question is, there is some difference in flight and on the total weight between these two solution?
Sébastien
Sébastien
Question is what F-16 do you have? The Skymaster allows for an engine on the tail, not sure about FB or JL.
I had an F-16 1/8 with a Super Bee on the tail. Perfect combination.
hello,
I have the eagle jet, same as skymaster.
i think to put a JJ1400 or simjet 1200, so a little more heavier (850 grs) that the super bee.
Do you have trying your F16 with center turbine location?
Thanks for your answer.
sébastien
sébastien
