4th gen A-10 by Mibo jets
#976
I got new pipes from MIBO (Oliver) to replace my old ones (the ones that were repaired with 4/40 screws at the spot weld line).
On the new ones, I reinforced the seam with 3 layers of aluminum tape on the outside. That should hold ... let's see.
Also, I applied 2 coats of BVM Heat Shield to the inside of the tail cone to protect it in case of pipe failure.
Stan: Yes, the carbon bell mouth is not affected by the temperature. It still looks brand new on mine.
#979
the 3 carbon pieces frame in the little square section directly behind the canopy. you have to cut the former that sits right there and add these. this makes that area open for the scale canopy operation. there is a sketch of this earlier in this thread.
i think the long carbon piece is for ??
I have the operating canopy already done (by an Austrian company, Kager Modellbau) and I think they used their own stuff for that ?
I have attached a few pictures of my canopy, can you tell me if these 3 carbon parts are needed or not from these ?
I'm still wondering what the long carbon piece is for ?!
(maybe also in the canopy section?)
Threads like this is worth a million. We are a bunch of guys building the same airplane and even though we are seperated by 1000's of miles (and different languages) all works out perfectly
#980
Quote:
One conclusion is that A-10 owners respect each other and don't use insults as their normal communication method
#981
My Feedback: (61)
TX
Thanks a lot Kirk!
#986
Stan,
isn't your engines too deep into the thrusttube ?
Normally the P160SX needs to have it's end of the exhaust around 1/2 to 3/4" from the mouth of the thrusttube ?
(See page 9 in this PDF file: http://www.jetcat.de/downloads/rx--e...manual_eng.pdf)
PS: I know the manual is for the RX turbines but as far as I remember, the numbers are the same for the "old" turbines
I cut 3 inches of the exhaust tube ( it was damaged on the last 3 inches ), then I move it back ward ( as I can not move forward the engine ).
Now the tube is at the same angle as the engine, and there is approx 3/4 inches of gap.
Next step I'll paint the inside of the fiber scale exhaust with 2 coat of BVM heat shield.
instead of that :
#987
For those who are interested in the "nuclear" version...
http://www.schuebeler-jets.de/hdt-im...4-dia-hdt.html
#988
Nice Stan, will be interesting to see if there is any difference with the new setup!
I did a lot of soldering yesterday, the connection to the engine nacelles consists only of a 4mm Festo bulkhead connector and a Multiplex connector. This is all that is needed to connect the P100RX engines. Makes it very easy to disassemble if needed. I have made an extension cable inside the plane, this is 1.2 meter long and will allow me to have the ECU/pump just behind the canopy. I asked JetCat of the max allowed length of the cable between then engine and ECU and was told that max i 150 cm and the 3 thick wires needs to be beefed up a bit.
I will make a cable of approx 40 cm length and put that into the nacelle so I will end at a total of 160 cm. The standard cable uses 0.75 mm2 wires for the heavy one, I have used 2.5mm2 for the heavy wires in the extension cable.
The cables from each wing uses a SUBD-15 pin connector (3 x servos and the lights needs a total of 13 contacts). Both the female and the male part are both of good quality and gold plated contacts
A few pictures of what I have done
#989
My Feedback: (15)
Hey Carsten,
That all looks great! I had been rehearsing the "how do I slide the turbine in and plug things in neatly since I can't reach anything once it is installed?"....
I am trying the opposite approach so we will have to compare notes later. Since the 100Rx is small and has the relatively small and light ECU, I am putting them on a small (sliding) tray just aft of the tanks to try and use the standard Wire harness. I think with the better batteries these days and the longer run with larger wire should be fine. A friend of mine had some trouble with long runs in his SR71 a few years ago. Seem to be solved with battery and wire size.
Stan, you get things done so quickly!!! Did you change the spring or fluid in the shocks for your A10 with twin 160s?
DD
DD
#990
Hi Carsten
Just a suggestion. When you will slide-in your engine, you will have to pull on both electric and fuel tubes to avoid them going on hot parts of the engine.
The only way to do that is to pull from inside the fuse. But with your connectors it's not possible to do that.
This is also another reason for preferring the " conventional " engine mounting with a large door.
Stan
Stan
#991
Hey Carsten,
DD
DD
Yes of course I changed the springs and fluid on my 2 A10. They are weighting 70 pounds (35Kg) at take off and with original spring/fluid the gear was largely in the red zone.
Earlier in this thread I discuss of that with Roger Shipley and he send me a set of springs more thought.
I also change the fluid, using absorber miniature car's fluid. They have a large choice in all hobby shop. I used a very more viscous fluid.
Moreover I change installation of springs and install them into the upper chamber of the strut ( out of the fluid ) so that the volume of fluid is far more important.
200 Flights later everything is perfectly working.
#993
My Feedback: (15)
Hi Carsten,
i am not sure if these will help but here are a few pics from the aft end of my canopy/fuse.
Thanks a lot Kirk!
#994
Hi Carsten
Stan
Stan
#995
Anyway, I will see when I get to that if it is possible to fit the pieces in there!
Thanks for the picture!
#997
I made a heat shield using the damage part of the exhaust tube I cut.
I screwed some bolts between the shield and the fiber to manage a cold flow of air.
#999
My Feedback: (15)
I also am not sure what you guys are using to mount the pylons to the wings? I did not receive any metal screws. For the pylons I received white metric plastic screws and then the gray pieces and antisway mechanisms. Are the white plastic scows for mounting the pylons or for mounting the antisway bars to the pylon?
