I got a Hornet!
I got a Hornet!
Fei Bao F-18F. Just got this bad boy this weekend. I hope she flies as good as she looks.
I got her together for a quick photo shoot with my new and yet unflown TJ F-16.
Raf - I don't want to hear about evil Super Hornet landings!
RE: I got a Hornet!
Some hints on the "bug"
Inspect the way the plane sits on the ground and if you identify that the plane sits at "0" AOA or -AOA try to reposition the height of the nose retract so when looking at the plane from sideways it has to have a positive AOA( something like +2 degrees)... I added wood shims to accomplish this. It adds for a smoother takeoff behaviour. My C of G is at 135mm behind the leading edge measured at wing root. My "Bug" flys on a RAM 1000 (more than enough power).
My Feedback: (13)
RE: I got a Hornet!
ORIGINAL: dubd
I have a P-120SE for the F-16 and I will be buying a Titan SE for the Hornet.
Have you started building the F-18 yet? If so, any issues?
Also check the main gear gear doors. the smaller rear ones needed to open first, then the bigger one. On closing, its the other way around. Makes for some interesting sequencing[X(]
good luck,
Edgar
RE: I got a Hornet!
ORIGINAL: jetspud
Looks Good,
I got mine not to long ago.. I am ordering all the stuff to stuff it... I will be using a super eagle for power..
Looks Good,
I have the stencils 213 squadron for you and the paint that I'll send to you tomorrow.
RE: I got a Hornet!
ORIGINAL: Edgar Perez
I choose to put some carbon to reinforce in high stress areas...
good luck,
Edgar
ORIGINAL: dubd
good luck,
Edgar
I have the paint touch up for you, when you can pick it up
Kidding I'll send to you tomorrow
RE: I got a Hornet!
Thanks Wagner,
Do you have any extra light grey that the bottom is painted. I want to paint the nose on mine I dont want the nose to be the silver that they painted it.. Also are you going to send me my UAT and extensions...
Thanks for you continued help
David
David
RE: I got a Hornet!
Also check the main gear gear doors. the smaller rear ones needed to open first, then the bigger one. On closing, its the other way around. Makes for some interesting sequencing .
I,m just about to start installing the gear doors on my SM F18E. I don't know if the doors are the same as the Fei Boa but why are they sequenced, do they overlap? What valve did you use to achieve this?
John
My Feedback: (13)
RE: I got a Hornet!
ORIGINAL: johnls
John
John
Since I already had an UP-3 and the tamjets failsafe, I needed a solution that could take a single retract signal. Ended up taking the smaller doors into a separate robart valve and using micro switches to sequence the servo connected to the robart with the servo connected to the UP-3. Both servos are connected to the tamjet failsafe.
My Feedback: (7)
AL
RE: I got a Hornet!
Hello,
I have the FB F-18F, which is the same as the Skymaster. The doors work fine for me without a sequencer. You may also want to try a BVM air micro switch on the nose gear to close all the doors, rather than an electronic valve.
Rob B.
Rob B.
