Reload this Page >
What do you think of FORMOST 150 ?
Old 08-15-2008, 02:45 AM
  #626
mikedenilin
My Feedback: (67)
Default RE: What do you think of FORMOST 150 ?
Hi Sandor,
Nice meeting you soon too! I will stop by Amsterdam next month. Could you hold up a jet in front of the Central Train Station, so I can find you easily?
Thanks for the advise. If they can copy Boomerang, Bobcat and all these nice sport jets, there is no surprise that they will do the same to ours. I am doing this as a hobby and just want to see how to turn a ugly plane into something nicer. If it works that would be nice, if not, no big deal.
Mike
Old 08-16-2008, 01:42 PM
  #627
SpiderJets
SpiderJets's Avatar
I am selling my (second) Formost, because I sold the turbine.
This plane is with my completely reinforced wings as described in this thread (one set), a new unfinished fuselage, the retracts+Jet 1A oleos+wheels, the main fuel tank, and all the rest of a kit in double.
No turbine, no radio.
Please PM me if interested.
Best Regards,
Nicolas.
Old 08-17-2008, 02:14 AM
  #628
igorcar
I need too know where I can buy cheaper and ship1s too Brazil.
Tahks and best regards
Old 08-26-2008, 05:11 PM
  #629
Osnabruecker
Hello,
last week i made a few changes on my formost...
With a Friend i tried to put some pu-foam in the middle-wing-section. The section is now very solid. I also put some pu-foam into the wings (be carefull, if you do so) After 1 hour i could see some "bumps" at the wing surface (hopefully you can understand my bad english ) But over night these bumps disapeared.
The whole wing section seems very stable now.
I had also problems to land this floater on our landing field... I put the ailerons up at 65% at the landing. Now you can easy land this jet...
With regards
Dirk
Old 09-05-2008, 08:02 PM
  #630
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Well my #2 Formost is ready to rock and roll, all I need now is a break in the weather, maybe this Sunday
Old 09-05-2008, 08:57 PM
  #631
idleup1
robart struts on springair retracts. eurokit wheels on homemade axles. turbine connection tank.
I
Old 09-05-2008, 09:29 PM
  #632
idleup1
I think the pictures upload this time.
ID:	1027042   Click image for larger version
Old 09-05-2008, 10:30 PM
  #633
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Here are some shots of my Formost #2
ID:	1027118   Click image for larger version
ID:	1027119   Click image for larger version
ID:	1027120   Click image for larger version
ID:	1027121   Click image for larger version
ID:	1027122   Click image for larger version
ID:	1027123   Click image for larger version
ID:	1027124   Click image for larger version
Old 09-07-2008, 05:36 PM
  #634
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Well I just got back from the field, the second Formost flys great, just needed a bit of right trim 1/8" [X(] and a bit of up elevator, its too bad they can't get the wings straight in these things.
Other than that it flys great!
Old 09-07-2008, 06:22 PM
  #635
robwill
RCISFUN;
Did you do the same mods on your second foremost?
Robert Williams (robwill)
Old 09-07-2008, 06:32 PM
  #636
robwill
RCISFUN;
Did you do the same mods on the second as the first?
Robert Williams (Rob Will to pay Paul)
Old 09-07-2008, 10:46 PM
  #637
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Yes the same mods were made.
Old 09-11-2008, 06:57 PM
  #638
igorcar
Hello
I need same help with the fuel tank! Can same one help me?
Old 09-11-2008, 07:29 PM
  #639
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
What specifically do you need help with?
In my photos above I am using a Du_Bro 50 Oz Tank with a Wren 54, I can fly for 6 minutes and still have the bottom part of the tank full (The shelf area of the tank)
Old 09-11-2008, 08:43 PM
  #640
igorcar
Hello again
Im puting a JJ1800 is 50oz is enough?
What do you think of puting 2 of this http://www3.towerhobbies.com/cgi-bin...&I=LXFU32&P=ML
Old 09-11-2008, 09:14 PM
  #641
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
The Sullivan tanks you mentioned have the following specification:
Height: 3" (76mm)
Width: 3-11/32" (85mm)
Length: 7-1/2" (190mm)
These tanks would fit stacked on top of each other.
My recommendation when interconnecting the tanks is to use .187" dia tubing.
At 64 oz you should be able to get a 7 minute flight
Old 09-17-2008, 07:22 AM
  #642
david101
I have started a F 150, strengtened the booms, have a p60 and 64 oz tank and will order a set of spring air retracts(as on my baby b). What mods to the wings do you recommend for this combo????????
Is it necessary to redo the fuse formers?????
Dave
Old 09-17-2008, 07:40 AM
  #643
SpiderJets
SpiderJets's Avatar
- No, you could do without the improved fuselage formers, but they would only make your life much easier and also accomodate the Digitech tank perfectly.
Be sure you glue everything all over again, the used glue is crap.
- Spend some extra care on all wooden retract mounts.
- As for the strengthening of the wings, this is an absolute must, and explained in detail.
Nicolas.
Old 09-18-2008, 09:49 AM
  #644
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Nicolas, covered the highlights ...
Fuselage modifications are a mater of personal preference, I preferred not to use the CRAP plywood
And of course I like my layout
If you want to see your landing gear come out on landings then you can leave the mounts alone, here again I prefer to have my gear stay with the aircraft
I think all of the critical mods and reasons have been thoroughly discussed in this thread.
Rich
Old 09-18-2008, 11:00 AM
  #645
SpiderJets
SpiderJets's Avatar
ORIGINAL: RCISFUN
Rich
See you tomorrow in Germany !
Old 09-18-2008, 11:06 AM
  #646
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Hello Nicolas,
Actually it will be Saturday morning...unless I can get done early with work and get my flights changed
Old 09-19-2008, 05:27 PM
  #647
igorcar
Hello RCISFUN
I have 2 problems can you help me if possible?
First one I can get the DPF folder can you send be email?( [email protected] )
And second think I need to buy the Extensions do you know how big and how many?
Thanks the help.
Old 09-19-2008, 06:28 PM
  #648
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Igor, I emailed my PDF document to you.
As far as extensions, I will have to go from memory
I used a Y harness in the center section for the flaps, the flap servos leads were long enough without extensions to plug into the Y.
The Aileron servos needed 6" extensions, the same for the elevator.
You will need one 36" extension for the elevator down the one boom.
You will need a 24" extension from the elevator boom extension to the receiver.
Depending on the length of your Y you may need short extensions to reach the flaps, you will need 24" back to the receiver
The steering, brake and retract servos will need short extensions, I believe 6" should do.
Depending on your aileron setup you can use either a Y or run individual leads back to the receiver, follow the flap recommendations if you use a Y.
I hope this helps, you may want to order a variety of extra extensions just in case
Rich
Old 09-19-2008, 11:45 PM
  #649
igorcar
Dear Rich
Are you using flaps? Does it helps a lot?
Dou you have any picture so I can have a idea? And copy you!?
Thanks again and have a nice trip
Old 09-20-2008, 04:15 PM
  #650
Instructor
My Feedback: (16)
Instructor's Avatar
Hi Igorcar,
Rich copied his flaps off mine. They are cut from the orginal ailerons. His are 13" long with 10" ailerons. I also added speed brakes to the top of my flaps. They are maid from 1/16" plyoow and glued to the top of each flap. They are 3.5" long and 2.5" wide. They are covered in Monokote. Here are a few shots of them:
ID:	1036897   Click image for larger version
