Reaction ARF - PST/BTE All-Composite Sport Jet
#552
My Feedback: (69)
RE: Reaction ARF - PST/BTE All-Composite Sport Jet
ORIGINAL: av8rk
to rcguy (dave)...i like your idea of the hinged elevator servo cover.....but if you install the metal heat shield above the turbine, it may or may not interfere with the servo cover.....i would check it out on my model, but i'm not at home...........
Richard
Richard
Good point. I'll check it out.
Dave
#553
My Feedback: (69)
ORIGINAL: B777
I like Dave's front hatch and we will evaluate all comments and suggestion to improve the Reaction ARF.
Thanks, Kraivuth S.
Thanks, Kraivuth S.
The hatch is needed in my opinion. The absolute need for batteries and weight in the nose dictates a hatch. I don't charge my batteries in the jet so easy removal is a must. On another point, I'd move the fin bolt back some to ease access to it during assembly. Maybe 1" or so? You'll need to stay away from the servo arm getting in the way.
Dave
#555
My Feedback: (69)
I've changed out the tank plumbing to use a Sullivan super clunk. It has pleny of "clunk" to it! The taper does seem to fit very well to the bottom of the tank. Nothing wrong with the supplied clunk but this may allow that 30 seconds needed for a go around.....
"No I didn't do any drain and fill tests as I mentioned above."
Dave Rigotti
Dave Rigotti
#556
My Feedback: (10)
ORIGINAL: rcguy!
Dave Rigotti
Dave Rigotti
this is a clunk:
one is 17mm and weights 50 grams
other is 20mm and weights about 90 grams
#557
My Feedback: (69)
ORIGINAL: digitech
thats not a clunk
this is a clunk:
ORIGINAL: rcguy!
Dave Rigotti
Dave Rigotti
this is a clunk:
Dave
#558
My Feedback: (10)
ORIGINAL: rcguy!
What's your point?
Dave
ORIGINAL: digitech
thats not a clunk
this is a clunk:
ORIGINAL: rcguy!
Dave Rigotti
Dave Rigotti
this is a clunk:
Dave
#559
Supplied brass clunk has a slot notched at the end to prevent fuel blockage against the fuel tank liner. Weight is needed to keep the pickup line at the bottom of the tank Sorry, but I don't see any benefit in replacing it.
#560
ORIGINAL: B777
Since you've already installed your clunk, I'll throw this idea out. I had been having a hard time draining my fiberglass tank, from day 1. I like to drain the tank after a day's flying so I don't have residual fuel sloshing around... The last 1/4" to 3/8" though, I cannot pump out of the tank. It is therefore, unusable fuel. I in fact started to partially drain my UAT a few flights ago, and while taxiing back from a long flight, my turbine died, while still showing this amount of fuel in the tank.
I've recently replaced the large brass filtered clunk that came with the model, with a Sullivan Super Clunk - whatever it's called, it is more of a large plated cone shape. I can now drain practically all my fuel out, which should increase the amount of fuel that is burnable in flight.
I don't know if others had a similar issue. I think the large dia of the supplied clunk just means the clunk hole is that much farther away from the tank floor.
#562
to rcguy (dave)....did you get the preformed lead nose weight with your kit?.....it weighs 20 oz.....with all nicad batteries in the nose, and the preformed nose weight, mine balanced perfectly at the aft most position.....at first i was a little intimidated with all of that weight up front in the nose to get it to balance, but as soon as it lifted off on the 1st flight.....well, it was perfect......the aft CG position is great.....i use a P-120 in mine, and it's a great combo.....i would like to see a Reaction ARF with a 60 inch wingspan, and a 2 piece wing, suitable for a P-60 size turbine.....i am the guy that started the removable tail feathers thing for this model on RCU.....i had to make mine removable to get it into my little vehicle......you'll love this model, i think it flys better than the wood version of bruce's.....
Richard
Richard
#564
My Feedback: (69)
All assembled on the bench less servos and P80SE. The 3" nose wheel modification worked out well. The wing leading edge is 1/16" higher than the trailing edge at the moment. Looks kinda nice with the anti-glare paint! The 3 1/4" main wheels fit perfect.
Edit... Forgot to mention I used "Gorilla" glue to attach the brake line clips to the MLG struts. Rough sanded the clips and they are there to stay. I used to use CA and once in a while they would come off.
Dave Rigotti
Dave Rigotti
#566
My Feedback: (69)
ORIGINAL: av8rk
dave,
it looks better with the larger nose wheel too.........
Rich
dave,
Rich
An easy mod to do especially if you have access to a milling machine and a 1/2" diameter ball nose endmill! No offense to anyone, BUT that 2 5/8" nose wheel looks way too small. It's OK I'm sure for pavement, but not to my liking for grass fields around Ohio. If there is enough interest I'll post a diagram of the exact modification. A few minutes work with a Dremel would also work. Very little material is actually removed. TamJets has the 3" wheel for 3/16" axle at 30 bucks. I just bandsawed off 3/16" from the top of the strut to make everything all the same again.
Dave
#567
My Feedback: (69)
Here's a question for the group,
Does anyone have a decent lead to have wing, stab, and fin covers made for the R54 ARF? Anyone have some made for them?
Todd does not stock them and all is quiet from across the pond on another source.
R/C Armour who made the covers for my R44+ is only doing prop covers at this time.
I'm really wanting them custom made for the R54 ARF not any generic type stuff that may or may not fit well.
Dave Rigotti
Dave Rigotti
#568
My Feedback: (44)
I have discussed this issue with B777 and he will be looking into it very soon. I know this does not address your immediate needs, but the covers may be coming from PST...
#569
ORIGINAL: rcguy!
Dave Rigotti
Dave Rigotti
Yes the German co Pull over do them, http://alshobbies.com/shop/search.ph...ags&NumShow=20
The link is to Al's hobbies pages, there half way down the page, i beleave very nice, and top quality product, intend to get a set for my one also-
Thats the only ones i know off.
Your progress looks great, couple questions for you.
What batterys you going with ???
And what did you use to cut out your front hatch ???
Cheers Jeremy.
#570
My Feedback: (69)
Hello Jeremy!
I'm switching to A123 packs this year. I'll run 2pcs 2 cell 2300Mah for the radio via 2 switch harnesses dircetly in the AR9000 RX. NO regulators what so ever. This will give 4600Mah. Probably good for 10 or more flights.
For the ECU I'll run a single 3 cell 2300Mah. "Maybe" a dual pack in parallel, depending on weight needed and Mah used per flight. The P80 SE may be upgraded to kero start in the near future. I asked if anyone had a JetCat with kero start in their R54 ARF with no reply. I'm not sure the kero plug will fit without hacking up the heat shield. :-((
I have enquired about the Pull Over product without response to the link above. Looks like the fin cover will need changes to accomodate the fin tube. It does look like the control horns are putting some stress on the covers 'eh?
I'm not sure what Ehab means by "looking in to it soon" Getting covers later in the Summer or early Fall won't be acceptable as the traveling damage will already be done. If anyone knows of a custom maker please let me know.
The front hatch is cut out with a Dremel tool using a diamond grit cutoff wheel. I found it makes very clean cuts and is very narrow, on the order or .030" [.75mm]. I cover the area with masking tape and then draw the cut lines with a ball point pen. I tape a cheap metal ruler (scale) down to help guide the cut. I usually get 5 or 6 cuts before throwing the ruler away and getting a fresh one, thus the requirement for "cheap". Works out well to keep the lines straight. A few passes with sandpaper and you're done.
Dave Rigotti
Dave Rigotti
#571
My Feedback: (44)
In Thailand things "sometimes" take longer than expected so the covers may be a loong wait....
FYI, I use dual batts for the RX and the ECU (PST 1600R and the Jetcat 120SE) and no nose weight at all. I get easily 8-10 flights with plenty of juice left, but I am tired after 8-10 flits...
#572
ORIGINAL: rcguy!
P80SE for power if it ever gets here!
Hi Dave.
I think my 80 SE is on the same boat yours is . I called Bob yesterday, he told me the ship's container is in customs.
The purple gems will be here in less than a week.[8D]
#573
OR
I found a nice wing bag for the Reaction 54 wing. Got it from Hobby-Pak. Item# WBS04, 85"x 24.5", $59.99.
http://www.hobby-pak.com/
It fits the Reaction 54 balsa wing, and should also fit the ARF wing. I've got another one for my Balsa Nova 1.20,
and it is a great size for that, too.
Chris Shaker
Chris Shaker
ORIGINAL: rcguy!
Dave Rigotti
Dave Rigotti
#574
Hi Dave
How are you going to regulate the A123 for the servos...the max rating for most servos is 6volt and some of the smaller ones are only 4.8. This means fully charged A123 packs will be around 7v which is fine for the RX but what about the servos?. I think you may experience some servo failures unless you put a couple of diodes in the +line to the servos to drop around 1.2 v to bring them back a bit. I have seen a few seros stop operating when used above 6v...considering that the loaded voltage of the packs will be 6.6v most of the time after initial usage
Mark
Mark
#575
My Feedback: (69)
ORIGINAL: Ehab
Thank You for the "update" on the covers. Hopefully no additional nose weight will be necessary! I'm sure the removeable tail mod did add some weight at the farest point away from the CG. I did remove some of the extra epxoy applied and drilled a 1" [25mm] hole in the aft plywood piece. An ounce or 2 adds up.
Dave
