Reaction ARF - PST/BTE All-Composite Sport Jet
#852
My Feedback: (44)
RE: Reaction ARF - PST/BTE All-Composite Sport Jet
Hey Bob
I made a balsa disk for the bottom and used 1/64" plywood wrapped 1 3/4 turns around the disk.
I then made balsa doubler's with the same size opening as the hole in the wing, these were glued underneath the skin to create a gluing surface, I then dropped the assy into the hole and hysoled it into place
#854
My Feedback: (13)
I used a plastic 'for sale' sign cut to size and formed as a cylinder. Added a few verticals pieces of wood from top/bottom of the skins in order to CA the plastic cylinderto it.
worked good, and I'm using a Super Eagle so going fast
#855
My reaction is on the way . Thanks Bruce at BTE even when im in Australia giving me great help and service in getting my new model happening . Dealing with PST has been a pleasure fast friendly service . Thanks Again
#856
just recived my orange reaction, great condition it arrived in , fantastic service 2 weeks from ordering time to my door . Cant wait to start to put it together , well done pst !
#857
ORIGINAL: cassiemitch
How about a pic or two of your Orange Reaction... What production number are we up to with these now ???
I have a all yellow one, currently under build, number 134...
Cheers Jeremy.
#858
My Feedback: (12)
CA
how does this plane fly with 18 pounds of thrust? I have been flying mine for 2 years with a p-120 but want to install my P-70 as I need the other turbine for my Flash. take off distance still good? I am assuming removal of the nose weight might be necessary, mine has the giant lead block in the nose. wonderong if I can leave both tanks as well for really long flight times, 3.5L and still get it in the air.
Kevin
Kevin
#859
My Feedback: (135)
MA
I saw one fly with a P-70 (yellow, long nose) at Big Apple Jets in June.
It looked as fast as my buddies with a P-80 SE in it.
3.5 L, you must want really long flights.
My Shokjet with a P-70 carries 93 oz.
After 7 minutes of mixed flying I land with just a little less that half a tank.
Bob
Bob
#860
Hey Kevin, you saw mine fly with a PST J800R, 18 lbs thrust. Performs well for me, suits my style. No issue with takeoff distance. It has the standard 2.5L tank only, flies eight minutes with reserve.
Also assembling another Reaction ARF with P70 and expect it to fly pretty much the same as my current one.
#861
My Feedback: (12)
CA
I guess I did Bruce, age catching up with me, lol, going to install the P-70 for some relaxing flight time and probably leave the extra tank for longer flights. Meesh, my shockjet is the same way, going to add a bomb type tank on the bottom.
Kevin
Kevin
#862
Just fitted bruces sticker kit to my orange reaction , blinged it up really good just the wings to finnish before my maiden..
#863
My Feedback: (21)
Just logged flight #97 on mine yesterday. 63 of them with a slightly detuned Jet Central Super Eagle. Tuff bird once you fix the wing leading edge and get the trailing links on it.
[youtube]http://www.youtube.com/watch?v=20e5iLjgb_8[/youtube]
#864
Nice flyin' Zonk
I have 17 flights logged on my X series to this date , here's is a vid (not a close up shot) of my Reaction w/ smoke @ about 57 seconds in... that flight I believe was #9 at the time.
[youtube]http://www.youtube.com/watch?v=NArjYEgAyUQ[/youtube]
#865
ORIGINAL: seflyer
Kevin
Kevin
Fuel: 2.5 L
Smoke: 1 L
I think your P-70 will have no sweat pushing it to rotation.
#866
My Feedback: (12)
CA
I will finish fitting the P-70 this afternoon, trying to figure out how to remove the lead weight I glued in the nose as it most certainly will not be needed.
Kevin
Kevin
#867
My first Reaction (snub-nose) had the lead weight and I buttered it up with uncle Bob's AeroPoxy and I can see how it would be a b&*#ch to get to, you have a small challenge there I guess.
Besides trying to drill out the body of the lead from the interior, I wonder if you'd be able to drill a small hole dead-center on the nose and tap it out with a drift pin/ rod and patch the hole later?
.... Good luck Kev [8D]
#869
I don't know Kevin... I wouldn't attack that lead until I knew for sure that it's way too much. If it's just slightly nose heavy, it might not be worth the effort to remove. If you're using lightweight batteries (lipo, A123), you will probably need the lead.
#870
My Feedback: (12)
CA
hoping to use my current 2700NiMh cells and lipo ecu pack, will drag the wing out today and check the balance.
Bruce, do you happen to have a O ring size for the PST valves, I have one that leaked from new and replaced with a Robart valve, but need and extra valve for another project and would like to use it.
thanks Kevin
thanks Kevin
#873
Sorry Kevin, I just don't have an answer for you. Orings are one of those things I just try to match up at a car parts store or hardware store. They are probably metric, might be tough to find.
Edgar, really sorry to hear about your Reaction. Must have been in a bad spot, because they do glide well. Reaction X is the same bird with longer beak. Makes it easier to balance. Guys really like the longer look - can't remember selling a short nose version since the X was introduced...
#874
My Feedback: (12)
CA
well on my way to retrofitting the P-70 to the Reaction, anybody using crow to help with landing, I have a ton of flights on it with the 120 and my only gripe ever with the airframe is that even heavy it would float on by on a slightly high approach. hoping a healthy dose of crow will help settle it in a little quicker.
also, anybody have a size for the pst retract and brake valve o rings. I need to replace them on one valve.
thanks Kevin
thanks Kevin
#875
Kev,
I don't know the size... but I did have the same problem you have (Both on a BVM and PST brake unit), to fix it I didn't replace the o-rings. I slathered O-ring lube on the rings and now it's as tight (airtight) as the day it was born.
Todd has the stuff.
Todd has the stuff.
