If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 37 of 46 FirstFirst ... 273536373839 ... LastLast
Results 901 to 925 of 1142
  1. #901
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Reaction ARF - PST/BTE All-Composite Sport Jet
    hello guys i am looking into a reaction x(long nose) for short field flying...how do you suppose a new jetcat p 100 would do in this plane.. very light setup and no smoke...also i plan on using the dreamworks gear.. is there any mods for the gear compared to the short nose or is it just drop in....thanks ...pat
  2. #902
    BruceTharpe's Avatar
    Join Date
    Nov 2003
    Rogue River, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Might be a nice combination, depending on how you like to fly. A turbine with 22 lbs of thrust on a 25lb plane (ballpark, dry) won't give you vertical out-of-sight performance. But it will still blast around and fly through big, beautiful jet-style aerobatics. Great for short field!
    Here are pics of my Pro-Links installation (Dreamworks gear). Very minor mods required.
    https://picasaweb.google.com/1063081...ksInstallation
    BTE - Home of Quality-Minded Model Aircraft Kits.
    www.btemodels.com
  3. #903
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks bruce.. another question.. is there a package i can get with reaction x dreamworks gear with all electronic valves and kevlar tank?? also whats a good servo you guys are using on this plane... thanks pat
  4. #904
    Meesh's Avatar
    Join Date
    Jan 2003
    Dracut, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a P-80SE in mine and it flies fine off of grass. Also have the Dreamworks gear. Had to drill two extra holes in the mounting flanges on the nose gear and had to extend the relief notches (towards the rear of the plane) in the nose gear mounting beams for the steering tiller clearance. The notches are already there but I had to make them about 1/4" longer.
    If it's worth doing, it's worth doing it right.
    AMA 779352, JPO 1965
    Kingtech K-80, K-100, K-140
  5. #905
    Join Date
    Nov 2003
    Rogue River, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ricardinho
    Will send PM on package deal (plane + gear). Sorry, don't know of any kevlar tank made specifically for the Reaction ARF. The glass tanks that come with the ARF are pretty tough - have not heard of any ruptures. Recommended servo list here:
    http://www.btemodels.com/Downloads/servochart2010.pdf
    www.btemodels.com
  6. #906
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sorry bruce meant to say for the upgraded 3.8 liter fuel tank....thanks
  7. #907
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks ... i think i may go with a 140rx now that i think about it..price is not much more ...unlimited verticle
  8. #908
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hello bruce thanks for all the info.. i think i will go with the jr 8411s all the away around.. are they aa good fit..? also could you give me an ideal of what size metal servo arms to get.. i like swbs ...thanks...pat
  9. #909
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    just pulled the trigger on a white and orange reaction x......will be powered with the new jetcat 140rx...duralite batterys and powerbox..jr8711s all around...this is going to make a great short fielder...i figured i go with larger motor for the smaller fields...i have flown many reaction but never owned one...cool plane...
  10. #910
    Join Date
    Nov 2003
    Rogue River, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Since you mentioned servo arms, not sure what to recommend as far as SWB. I used the metal arms that came with my Hitec digitals. All pushrods connect to the first or second hole from the end, which is a length of 3/4" or 5/8" from the axis
    www.btemodels.com
  11. #911
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i got all 1" swb and full arm for steering...i think that will be fine...thanks again bruce
  12. #912
    Join Date
    Feb 2005
    southamwarwickshire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I`m just finishing my ReactionX,(P100,Electron Electric Retracts/Pro-link gear).This is my second jet but the first that I have built.Just wondered how you go about checking the CG as its too large/heavy to flip over and use your fingers[:-]?Any help/advice would be appreciated.
    Steve
  13. #913
    Edgar Perez's Avatar
    Join Date
    Dec 2001
    Gurabo, PUERTO RICO (USA)
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: steve2972
    Steve
    I sometime use an inverted chair. Put some foam on the two higher legs and they act as your finger.
    Otherwise, do a search here for the options were you hang the plane by the target CG.
    Edgar Perez
    Puerto Rico
  14. #914
    Join Date
    Feb 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I`ve done a search but cannot find anything
    thanks
  15. #915
    Meesh's Avatar
    Join Date
    Jan 2003
    Dracut, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This should help you!
    Attached Files Attached Files
  16. #916
    Join Date
    Feb 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks great meesh,but I don`t really want to start constructing things.Hows everyone else balancing their Reactions?
    Cheers
  17. #917
    Join Date
    Jun 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got the giant scale EZ balancer from Southwest Systems. Works great on my giant scale airplanes, and worked on my Reaction 54
    http://www.ezbalancer.com/
    Chris Shaker
    ORIGINAL: steve2972
    Cheers
  18. #918
    Join Date
    Feb 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the link Chris,this may be a solution.Did you balance your reaction inverted or upright?
    Cheers
  19. #919
    Join Date
    Nov 2003
    Rogue River, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For the record, I think Edgar's idea of an inverted chair is brilliant!
    I built the stand in the pic for my jets. Low-wing jets like the Reaction balance easier upside-down. Position the balancer so the fin won't touch the table. Plywood pads (foreground) are taped to the wing surface at the balance point to protect the wing from dents. The plane balances on the upper edge of the short dowels in the center of each upright. The little foam pads keep the jet from rocking too far.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    www.btemodels.com
  20. #920
    Join Date
    Feb 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Bruce
  21. #921
    David Gladwin's Avatar
    Join Date
    Feb 2002
    CookhamBerkshire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Do it the very easy way. :
    Easy and accurate C of G calculation:
    Place model nose against wall, measure the distance of each wheel axle, main and nose, to wall. (you can use any other datum point you wish but a wall is often convenient) Place scales under each main wheel and pack up nose so that the machine is level, note weight.
    Then measure weight on nosewheel.
    Multiply TOTAL weight on main wheels by distance from wall= Moment A.
    Multiply weight on nose gear times distance from wall= Moment B.
    Add A + B to obtain total moments.
    Divide value of A+B by TOTAL weight and that will give you exact distance of C of G from wall, i.e. nose, or other chosen datum.
    To adjust, I tape a paper cup to nose or tail and add fishing weights to get C of G exactly correct.
    Easy , quick accurate and free, can easily be done by one person, and prevents hernias. Works on A380s too, !
    David.
  22. #922
    Join Date
    Feb 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi David,
    So do you need to place scales under nose leg also,ie use 3 x scales otherwise how do you measure the nose weight? I only have 1 x scales and these were £120.00 (digital upto 40kg) What scales would/do you use? Thanks for the info.
    Kind Regards
    Steve
  23. #923
    Join Date
    May 2010
    Herveybay, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I need some help with some photos of extra air intakes fitted behind the cockpit for a large sized turbine .If some photos could be posted that could help me out , Thanks
  24. #924
    Meesh's Avatar
    Join Date
    Jan 2003
    Dracut, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hope you can see this OK.
    It's a NACA duct on the top of the Fuselage.
    Not my plane but my my buddy Mike's.
  25. #925
    Join Date
    May 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
     any chance of a close up photo , thanks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
