Reaction ARF - PST/BTE All-Composite Sport Jet
#951
RE: Reaction ARF - PST/BTE All-Composite Sport Jet
ORIGINAL: E.N.T.
Which parameters are you using for crow?
E.N.T.
E.N.T.
Would you like to know how much flap and aileron up movement I am using?
Paul.
#952
My Feedback: (13)
ORIGINAL: paulhat
Hi Edgar,
Have watched your video a few times.
It was quite windy on the approach.
Maybe the wind just caught it for a second?
You recovered well and it flew the rest of the landing fine.
Paul.
Hi Edgar,
Paul.
Last flight I was unable to recover well. Ended up wheels up and needing a new vertical fin. BTW, got excellent service from Bruce Tharpe. Recommend him 101%!
fiberpro (01-10-2024)
#954
My Feedback: (28)
Looks to me that the airplane is out of trim. The nose dropped with a small relaxation of up elevator during the approach. Add some more up elevator mix with the full flap position and I bet that helps. To make sure you have the right amount, get the airplane to a decent altitude an slow it down to an approach speed. Add up elevator trim until you can maintain level flight without adding up elevator. After you land, measure the amount of up trim in the elevator and then mix the same amount into the full flap position with your transmitter.
#956
ORIGINAL: tp777fo
Hi Tom,
Another way you could do this is to run a separate flight condition for landing and just trim this condition. That way you dont have to do any guessing with mixes after you land. That's what I do on my Futaba.
Regards,
Paul.
#957
ORIGINAL: E.N.T.
Paul: yes I would like to now. I'll be giving mine the maiden
most prob. this weekend.
Thanks;
E.N.T.
Thanks;
E.N.T.
I have 10mm of up on my crow and 40mm down on flap.
For take off I have no crow and 25mm of flap.
Paul.
#958
Maiden Flight for my 2nd Reaction Long Nose Orange/White tomorrow 1/1/13.
Kingtech 140F, Running on diesel and DTE light, Electron ER40 retracts first time to use them and Tornado Electric Brakes upgrade to Electron brakes when they arrive. No air leaks possible. How many touch and go's can one do now.
#959
ORIGINAL: number27
REGARDS
#960
ORIGINAL: number27
How did the maiden go?
I have just installed a set of electron brakes in my Ultra Flash. These things are amazing!!
Paul.
#961
maiden went fantastic. gear up gear down. never have to worry bout air or whether it is loaded in the trailer for next time. have ordered another set er50's for my next project a eurofighter.
not used to the scale speed of the up and down as yet. no more slam open or slam shut with the air.
#962
ORIGINAL: paulhat
Hi E.N.T.
Paul.
ORIGINAL: E.N.T.
Thanks;
E.N.T.
Thanks;
E.N.T.
Paul.
Peter
#963
Hi Peter,
I have elevator mixed in with that flight condition.
Um I think its down elevator. Cant remember right now.
In any case its not much.
That probably doesnt help that much. I will measure it next time I have it together.
Paul.
Paul.
#964
ORIGINAL: number27
The Electron retracts are amazing. Have go them on the UF and they work great!!
Paul.
#965
Anyone have any idea where on the wing tips the cg is. Trailing edge would be a good starting point. So how far forward measured from the trailing edge on the wing tips is the cg?
Thank
Jerry
Thank
Jerry
#966
Installed the electron brakes over the weekend and tested great, they are fantastic compliment to the Electron ER40's. Prolink Oleo's the weak link in the system. The twisting of the legs , e clips come off bolts come loose. etc. Looking for alternatives.
#967
ORIGINAL: paulhat
Nice reaction pictures there mate.
Just wanted to report on my experience using crow breaking on the reaction.
Tried crow for the first time today and did 8 landings with crow active.
Here are my initial observations -
Definately helped to slow the model down. I had zero wind blowing and touching down where I wanted seemed easier.
Aileron sensitivity was decreased by about 50%. I think it would be good to reduce expo in the landing condition (this is the condition I have crow on).
Elevator sensitivity was also decreased. Maybe by about 30%. This caught me out a little at first and I ended up over correcting a bit. After a few flights had it sorted.
Overall I think crow works great. With a bit of fine tuning it should help alot here. We have hardly any wind in the mornings which is when I usually fly.
On another note I now have 40 litres of diesel through the K140. I am using mobil DTE light oil. The reason I am trying diesel is that its so hard to get jet fuel where I am living.
I am pretty pleased with the performance really. Starts take a bit longer and when you shut down there is a bit of white smoke. Apart from that it runs perfect. I was really worried that
there would be that horrible diesel smell but its actually quite the opposite. Hardly any smell at all. One thing I would say, if you are thinking of running diesel, make sure you try it on the bench first.
The ECU default parameters work fine with kero but not with diesel. You will get a mighty big flame out the back at startup on default parameters.
Lightningmcnulty posted these parameters in the Ultra Flash build thread. They work great. Perfect starts every time.
Regards,
Paul.
I heard that some guys are sturggling to get a good diesel start working so I thought i'd post my parameters here
Here are the parameters as you scroll through the start menu
Auto start 2, pump start ramp 7, glow plug power 7.5, starter power at ignition 140, starter power at ramp 160, rpm starter power 15000, rpm ignition k 3.000rpm, pump PW at ignition 014, engine min flow 19%, egt end preheat 100c, rpm preheat k 5.000 rpm, rpm fuel ramp k 6.000 rpm, fuel preheat 20%,
you really need a 9.9v life battery for this, its important that you allow the fuel and turbine to really get up to temp before it starts adding large amounts of fuel.
Make sure you test all this on a stand before putting it in a jet or you could end up with a crispy exhaust pipe
another thing that is really important is to restrict the air that is blowing through the turbine on pre-heat, if you allow air to blow through it will put the flame out, when on your test stand keep it side on to the wind and once in the jet cover the intakes with your hands until your out of pre-heat.
with these settings expect it to take 30seconds to start.
Kim
Kim
Regards,
Paul.
Just something a little bit different would crow work on a large J-3 CUB or do you have to have flaps, The cub has no flaps so wonder if it would work,maybe have the ails down would that increce lift
REGARDS JOHN
#968
Hi John.
To be honest I dont know what would happen if you put up ailerons on a Cub.
I guess you could try down and see what happens. Dont see why down aileron wouldn't work.
Guess you would have to mix a bit of down elevator in.
Give it a go
Paul.
Give it a go
Paul.
#969
Hi Number27,
I have 2 sets of Prolinks and both do the same as yours. Clip comes off and bolt starts to work its way out.
Jet 1-A's that Digitech used to make (well I dont think he makes them anymore) are awesome.
If you find a good alternative I would like to hear about it.
Regards,
Paul.
Regards,
Paul.
#970
Hello I am French,
I am in the process of mounting the X Reaction tank with 3.8l, retractable landing gear and brake Pst. I told him up a turbine jet-munt VT80.
I can ask if I can trust the instructions and clearances for the components?
I'll have to add lead (much) to get the CG to 15cm.
Thanking you and wishing you good flight to France!
Julien
#971
Just joined all you Reactionaries, test flew my all yellow long nose version yesterday in a wind that would blow a dog off a chain, flew very well reminded me of my pattern models very smooth (even in the wind) very minor aileron and elevator trim corrections required. Powered by a Kingtech 140, Pro Link retracts, JR 8911 servos, DX18QQ Tx and lots of Intairco goodies, looking forward to some more flying with the model and experimenting with flap settings (maybe even crow). Appears that there is a diversity of flap recommendations here, I am able to achieve up to 90 degrees movement, according to Ali this is what he used; any thoughts?
#972
I'm flying mine with a VT-80. Flies really smooth, trainer type.
If you want a Sunday flier, this is it. BUT floats like HELL.
Had to use 90 degrees flaps with elevator, as Ali said.
Do not expect a rocket with this engine.
I like it that way.
ENT
I like it that way.
ENT
#973
ORIGINAL: paulhat
Hi Number27,
Regards,
Paul.
Hi Number27,
Regards,
Paul.
Tony at Trim Air is now making trailing link struts.
There not on his website but he is starting to make them.
Hope this helps.
Mario..
#974
My Feedback: (24)
ORIGINAL: number27
#975
Thanks for the information Todd.
I will make sure everything is loctite'd.
Paul..
Paul..
