Byron F20 builder/owners, what am I doing wrong?
My Feedback: (60)
RE: Byron F20 builder/owners, what am I doing wrong?
Can you tell what the purpose of this piece of wood is? Your airplane does not have "intakes" for ducting a bypass because it is DF, I have full intakes that slide into the molded intakes.
I have not glued them in yet, but if there is structure needed from the top of the piece to the bottom, I want to do it now.
I was just going to tie the whole device into the fuse with wood and glass.
My Feedback: (10)
NE
is this what you wanted?? as for the wood inside, it ties to the inlet fin to help support it from tearing off. that is glued to the inlet fin on the inboard side. my knowlage from the guys that were test pilots for byron, they had a problem with them tearing off in flight because there is hardly any surface to glue them on.
My Feedback: (10)
NE
where are you placing your turbine?? i seen carl sperlock's f-20 turbine converson, and his turbine is places clear back by the vert. fin. the plane is nose heavy to begin with, so if you can move the turbine back and set your tanks on the cg that will help you out also.
#33
Turbine conversion
The F20 is an awsome plane, I have had two of them that I converted to turbine. The point Id like to make is about the elevator stabs. If your going to go scale with it, Keep the flying stabs. If not go with joining the whole stab to the fuse and cutting in elavators yourself. There is a world of difference in the way it flys, (Much smoother)
Keep up the good work Sean!
Ben
Ben
Cheers
